Toymods » Tech & Conversions » 3S-GTE rebuild parts
rokusan
western queensland
icon5.gif  3S-GTE rebuild parts Thu, 30 December 2004 13:33 Go to next message
i searched old threads on this subject but i have more questions
I have started putting together my engine, and i have snapped and stretched two main cap bolts, so i am buying new ones from Toyota. Is this sufficient and should i buy new rod bolts too?
I will be giving this engine a hard time so is there anything i have missed?
List so far,
bored & honed block, decked (skimed?)
bal. crank, std rods and forged ACL's
new bearings, head studs, rcoed head with good stuff (ta josh)
also can i use the 205 steel headgasket on a 185/mr2 engine?
any past experiences and known weaknesses would be appreciated.
TA22-3SGTE
MACKAY
Re: 3S-GTE rebuild parts Thu, 30 December 2004 21:01 Go to previous messageGo to next message
I have refreshed my 3SGTE a couple of times and have used the standard main and rod bolts , The week point I have found is the head lifting and pressurizing the cooling system if you run over 30 lbs boost and I am using a ST205 head gasket and ARP head studs .
Trevor
rokusan
western queensland
Re: 3S-GTE rebuild parts Mon, 03 January 2005 01:59 Go to previous messageGo to next message
ah cool, sounds like your engine is holding together nicely Cool Cool got any other tips for me? i'm still a bit of a novice but i do have to build this engine strong! 270 rwkw's must be fun Smile i need about 2oo rwkw's and heaps of torque. What plenemn set ups have you seen work?
thanks Razz
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 3S-GTE rebuild parts Mon, 03 January 2005 11:02 Go to previous messageGo to next message
I'm in the same position myself at the moment.
@TA22-3SGTE So you've used the ST205 headgasket without problem? i thought some of the water galeries didn't line up? Any more info on mods? I'm after around the same amount of power, except at 4 wheels.
rokusan
western queensland
Re: 3S-GTE rebuild parts Thu, 20 January 2005 09:23 Go to previous messageGo to next message
ok i have ordered an ST205 HG, are these multi layer stainless?
-==L=a=N=c=E==-
Re: 3S-GTE rebuild parts Thu, 20 January 2005 09:30 Go to previous messageGo to next message
rokusan wrote on Thu, 20 January 2005 19:23
Yes, take your old gasket in, and make sure that lal the coolant holes line up. If not, look elsewhere.
rokusan
western queensland
Re: 3S-GTE rebuild parts Thu, 20 January 2005 09:39 Go to previous messageGo to next message
what holes in which models dont line up? my engine is mostly gen2, but thanks i'll check.
off-road
Alice Springs
Re: 3S-GTE rebuild parts Thu, 20 January 2005 11:38 Go to previous messageGo to next message
Interested to know what compression ratio and what fuel enables you to run 30 pound of boost?
rokusan
western queensland
Re: 3S-GTE rebuild parts Wed, 26 January 2005 01:26 Go to previous message
Ok i have got my 205 gasket, yes it is multi layer metal. BUT yes the hole are a little different, 1. The oil feed to the head is really small? can i just die grind it out or is there some reason for the restriction?? 2. the water jakets are slightly different but should be ok apart from one overlaps the casting, will this be a weak point in the seal? I have pics if some one has a good host?
Previous Topic:Advice on driving a VERY cammy car.
Next Topic:4age 20v silver
Current Time: Sun Oct 18 08:03:54 UTC 2026
Total time taken to generate the page: 0.077560186386108 seconds
