Classifieds » Parts Wanted » injector plugs for 4agze (or 7mgte) & Igniters from 1GGZE and 4AGZE
injector plugs for 4agze (or 7mgte) & Igniters from 1GGZE and 4AGZE Thu, 30 December 2004 14:41 Go to next message
i'm after the plugs that connect to 4agze injectors (4 of them).
The injectors are similar to 7mgte and 1g-gte gen 1 injectors (yellow ones) and other hi-po units.
If you look at this page: http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Injectors.html they're a type 'E' connector.
(updated to fix info, thanks wil8115)
I'm also after Igniters from 4cyl and 6cyl Waste spark system - 4AGZE and 1GGZE would be ideal.
(updated to include igniters)
tia,
charles.
[Updated on: Tue, 25 January 2005 03:47]
wil8115
Seattle area, USA
Re: injector plugs for 4agze Sat, 01 January 2005 06:19 Go to previous messageGo to next message
these are the round type LOW ohm. the HIGH ohm plugs won't fit.. they are all the F type. you could try a engine importers especially ones that install engine. They would have extras such as this and probably just throw them away..
4agze, 7mgte, 3sgte, 1jzgte, 2jzgte come to mind as low ohm round type connectors. good luck.
Re: injector plugs for 4agze Tue, 25 January 2005 03:48 Go to previous messageGo to next message
bumped
people100
Rocklea qld
Re: injector plugs for 4agze (or 7mgte) & Igniters from 1GGZE and 4AGZE Thu, 27 January 2005 09:45 Go to previous messageGo to next message
im also chasing a set of 4 to if someone has some...charles ive found that the 3sfe engines u can get away with using those injecter plugs if u break off the clip that holds them on. then just doing something like the 5me to hold them one..SILICON Rolling Eyes not ideal but will get you out of trouble to atleast try to get the engine running again.
Re: injector plugs for 4agze (or 7mgte) & Igniters from 1GGZE and 4AGZE Wed, 02 February 2005 12:51 Go to previous message
bumped again
Previous Topic:Geez
Next Topic:WTB: AE82 panels
Current Time: Sun Nov 1 05:45:21 UTC 2026
Total time taken to generate the page: 0.0049388408660889 seconds
