Toymods » Tech & Conversions » 3SGTE Questions
GT4BOOSTD
3SGTE Questions Thu, 30 December 2004 21:09 Go to next message
Hey guys i was wondering what the normal operating temperature is at idle and while driving on my 94 model 3SGTE motor. At the moment it is running at 90 degrees celcius at idle and have yet to take it out to check the temp while driving. Also can anyone tell me what psi i can run with a stock motor with a 3 inch exhuast, top mount cooler, vl turbo fuel pump, k&n filter and a bov and roughly what power outputs a 3SGTE in my tune would make.
Also as i have only just put my car back together my engine is in need of a descent tuning. I am running a stock 3SGTE ecu can anyone recomend a workshop preferably on the south coast or wollongong to take it too and if possible a contact number.
Cheers lads
djcougar
Sydney, Australia
Re: 3SGTE Questions Thu, 30 December 2004 21:18 Go to previous messageGo to next message
i have a funny feeling that nothing is good at 90 degrees celcius, but i could be wrong
cycleofabuse
Re: 3SGTE Questions Thu, 30 December 2004 23:13 Go to previous messageGo to next message
90 degrees maybe slightly warm but not by much. In the summer mine will sometimes get up and stay up around there. Doesn't worry me too much. It depends whether you have a ceramic turbo or a steel turbo in regards to safe levels of boost. I have a ceramic turbo and ive heard they're good for about 15-16 psi. The steel ones can handle more.
GT4BOOSTD
Re: 3SGTE Questions Fri, 31 December 2004 21:33 Go to previous messageGo to next message
Can anyone with a gt4 tell me what running temperature their engines produce as i am unsure what temperature my engine should run at. Can anyone help me as i am becoming a little paranoid
YelloRolla
On your mum!
Re: 3SGTE Questions Fri, 31 December 2004 23:05 Go to previous messageGo to next message
Wont the operating temps be listed in a tune up guide?
90 doesn't sound too bad to me as most thermostats that I have seen in modern engines tend to be around the 88deg mark.
GT4BOOSTD
Re: 3SGTE Questions Sat, 01 January 2005 07:59 Go to previous messageGo to next message
Yes it would be in an owners manual or something similar but i do not have access to one thats the only problem. so can anyone with a gt4 owners manual tell me the operating temps that the manual has listed as i have only just got the motor put in and dont want to do any damage to it.
Aust162
Melb, Victoria
Re: 3SGTE Questions Sat, 01 January 2005 08:50 Go to previous messageGo to next message
well my thermo fan switches on at about 92degrees and drops down to 84 degrees when the fan switches off. i'd sat the temps are normal.it gets really hot under the engine bay of a 3sgte!
GT4BOOSTD
Re: 3SGTE Questions Sat, 01 January 2005 09:06 Go to previous message
Cheers again it will give me peace of mind for the moment
Previous Topic:Need help with Supra 5 spd box
Next Topic:Can't find it... need help
Current Time: Sun Nov 22 20:53:46 UTC 2026
Total time taken to generate the page: 0.0091071128845215 seconds
