Toymods » The Outhouse » Help with my PC IDE problem, please
river
Land of Oz
Help with my PC IDE problem, please Thu, 30 December 2004 22:23 Go to next message
My PC has gone all stupid, and hope someone here can help me or offer some pointers before I pull it apart to find the fault.
It's an old Asus A7V m/bd, running 1G Athlon, Win98, IBM 40G HDD, Sony CD-ROM and a Sony CD writer. The HDD is attached to the Primary IDE Master port and the CDs are attached to the Secondary IDE master.
The BIOS msgs on power-up used to display "Sony CD" on the Secondary IDE Master, but now it displays something like "!ONY >>>!>>>!!>>!!". WTF does that mean?
Win98 used to show the D-drive as the CD writer and the E-drive as the CD-ROM, but now only shows D-drive as an audio-only device, and this device is the CD-ROM. So, the CD-ROM has gone from D to E drive, and is audio-only, and the CD-writer is not there anymore.
I think it may be a hardware fault with the m/bd or maybe a BIOS problem. Could be a blown CD unit, but I'm not sure.
I could reload the m/bd BIOS again to see if that fixes it. I'll be bummed if it's a m/bd fault. I might remove the CDs and see what happens. But, I'm asking for you guys assistance before I get down & dirty with this old box.
seeyuzz
river
bathurst-91
Re: Help with my PC IDE problem, please Thu, 30 December 2004 22:43 Go to previous messageGo to next message
Did your pc recently freeze/hang while burning something? then you had to reset?.
Sometimes intermittant errors like to popup like this. It usually comes down to the drive (I used to get problems like this with an older cdrom unit I had).
Go into Bios> select primary ide master and scroll through the options (autodetect) then hit enter on autodetect so it'll showup the drive. Then do the same for secondary and whatever else your running.
Save and restart, if it doesnt fix the problem try flicking them off autodetect and set them manually, if this fails go back to autodetect.
If that doesnt fix the problem. check cabling. It could be the cd drive or perhaps a ur powersupply is dieing.
[Updated on: Thu, 30 December 2004 22:44]
4AGE
Re: Help with my PC IDE problem, please Tue, 04 January 2005 02:16 Go to previous messageGo to next message
Rip out the drive
Throw it in a experimental comp.
Same problem?
Rip it out again.
Throw it in the bin.
IF problems prevail. i'd be deeply shocked.
Toobs
Re: Help with my PC IDE problem, please Tue, 04 January 2005 06:18 Go to previous messageGo to next message
I bet you Witzl's left testicle its either a dodgy IDE cable or the cable isn't plugged in properly.
Note: Any claim to Witzl's left testicle can be taken up with him.
mikey93
Re: Help with my PC IDE problem, please Tue, 04 January 2005 07:35 Go to previous messageGo to next message
sorry to hijack but ive got a similar problem.
my dvdr doesnt work.
ive changed mb's into a new case.
and the drive works when you goto eject the rom. but once you plugin the ide. it wont even power up
doesnt detect in bios either..
plugged the ide in backwards same thing. no avail.
4AGE
Re: Help with my PC IDE problem, please Wed, 05 January 2005 01:22 Go to previous messageGo to next message
if its a newish dvdr i don't see why its a issue.
secondly i'm not too sure. but plugging the ide cable in the wrong way around can't do it much justice in any sense. Are u 100% u got the ide cables are in the right way around. And the jumpers are right?
If so. Jump into bios.
With the ide cable out of the dvdr.
Go into the config screen where it has the voltages of the psu.
*It should be a alternating figure where the voltage/current is constantly changing.*
If the voltage completely drops to like 6 or 8 when u eject the tray.
It MIGHT be a psu issue.
or your mb is cactus already.
Imho. I think it might be a faulty mb.
thu187
Re: Help with my PC IDE problem, please Tue, 11 January 2005 04:32 Go to previous messageGo to next message
Try going to the manufacturer of your CD-RW and downloading the driver again.
I've got a similar problem.
I got some spyware and got rid of almost all of it but couldn't find what kept re-installing the files.
I went into recovery console and Windows XP wouldn't boot and I thought "uh oh.. doesn't like DOS".
I tried everything and got really pissed off and tried installing 2000 but got the same error and Windows ME or 98 wouldn't install because my partition of C was NTFS not FAT32 Sad
In my rage I deleted the directory C:\Windows\System32 (where the spyware was located) and as you'd expect I got f*cked.
Later I chucked my hard drive in my mate's computer and XP wouldn't install again. I realised that both my Windows 2000 and Windows XP CD's were FAULTY!
Inserted another copy of the same disc and it worked.
I wasted so many hours Mad
Oh, and yeah now the CD-RW isn't detected at all but when I shove an audio CD and hit the next track button on the drive it plays!
river
Land of Oz
Re: Help with my PC IDE problem, please Tue, 11 January 2005 04:46 Go to previous message
Thanks guys for your help. It was a faulty CDRW. I tried it in a few other machines, but it wouldn't work in some machines, or in some machines it wasn't even detected. I found three other machines with suspect CD drives, so I bought me a bunch of drives and a new CDRW. Should be here by the end of the week so I can get the beasts going again.
seeyuzz
river
Previous Topic:Best value DSL?
Next Topic:Win ME Right click Help
Current Time: Sun Oct 18 22:58:32 UTC 2026
Total time taken to generate the page: 0.0043849945068359 seconds
