Toymods » General Car Talk » Aluminum Welding
Ge_x
Brisbane - Aspley
Aluminum Welding Fri, 31 December 2004 01:54 Go to next message
Hey I'm Jason, I'm doing a 4AGZE into a Corolla Spirit.
Check out member rides, by teddy
I just got a 'new' front mount inter cooler yesterday. But it would be easier to cut off reweld the up bent part.
Ive goggled Aluminum welding with the result of only commercial, i would like to attempt it my self, and its only small. Any suggestions
http://community.webshots.com/photo/226235370/2403 49940PaVGNn
[Updated on: Fri, 31 December 2004 02:03]
Camry_omega
Campbelltown, NSW, Austra...
Re: Aluminum Welding Fri, 31 December 2004 03:00 Go to previous messageGo to next message
A process that is used to weld aluminium that would proably work is called TIG (tungsten inert gas) welding. However TIG machines can be quite expensive to buy, im not sure about renting one, it takes some skill to do nice welds though.
Re: Aluminum Welding Fri, 31 December 2004 04:19 Go to previous messageGo to next message
cost for a TIG machine is around $4000+.
you can do aluminium with a MIG, but TIG is much much better.
there are a number of people on toymods who do this for a living...
granmra40
Re: Aluminum Welding Sun, 02 January 2005 00:33 Go to previous messageGo to next message
I weld and I have to say TIG is the most difficult of the manual welding processess. Oxy welding experience is good for TIG as you have a torch and filler wire that you have to coordinate. If you can get your hands on a machine, get some scrap and try to join it, good luck. Pipe is also more difficult than flat. I would be getting someone with experience to do the job. It should not cost all that much and it will be alot more expensive if you bodge the job.
Re: Aluminum Welding Sun, 02 January 2005 00:56 Go to previous messageGo to next message
I know someone at Redcliffe that can do some pretty sweet alloy welding for you.
Ge_x
Brisbane - Aspley
Re: Aluminum Welding Sun, 02 January 2005 08:46 Go to previous messageGo to next message
OK thanks for the replies, Redcliff thats not that far away. Whats the name ?
Re: Aluminum Welding Sun, 02 January 2005 12:39 Go to previous messageGo to next message
Send me a PM.
Toobs
Re: Aluminum Welding Mon, 03 January 2005 04:27 Go to previous message
TIG is the preferred method for welding alloy, however, it can be done with an Oxy.
I have difficulty using a TIG because I can't see the tungsten tip properly (colour vision issues) so I use an Oxy most of the time.
That and when you accidentally touch the filler rod to the tungsten tip (due to reason mentioned above) you get a mighty big jolt!
Previous Topic:My 990cc 3 cylinder ran a 14 !
Next Topic:BHG in 5M supra- do i fix it or get a 7M?
Current Time: Mon Jun 15 07:30:17 UTC 2026
Total time taken to generate the page: 0.0061299800872803 seconds
