Toymods » Tech & Conversions » T50 weak 5th gear
Celica73
T50 weak 5th gear Fri, 31 December 2004 06:32 Go to next message
Hi
Just wondering if anyone else has has this problem, I have had a search for "T50 Weak" and didn't come up with anything about 5th gear.
Anyway I had a wine in my gearbox in 1st, 2nd, 3rd and 5th gear. Suspected a worn input bearing from the noise. Once pulled apart discovered the bearing was fine but 5th gear was about to let go. The spine in the gear and on the shaft were both flogged out and just holding.
I was wondering if this a common fault with the gearbox
Jason
EMP-2TG
Carlingford, Sydney
Re: T50 weak 5th gear Fri, 31 December 2004 10:46 Go to previous messageGo to next message
isnt the 5th gear like half as thick?
IRA11Y
Club Member
Re: T50 weak 5th gear Fri, 31 December 2004 21:48 Go to previous messageGo to next message
Ive never heard of 5th being a problem, 2nd is usually the weakest point in the T50 as it gets most of the work. 2nd particular doesent like compression braking Sad
TE72_Turbo
Re: T50 weak 5th gear Sat, 01 January 2005 01:11 Go to previous messageGo to next message
I've never had a drama with 5th in the past, then again, i'm rarely flogging the car at those speeds anyway. Third gear has always been my problem once you put a decent amount of torque through it.
Celica73
Re: T50 weak 5th gear Sat, 01 January 2005 02:59 Go to previous messageGo to next message
Spine and gear on counter shaft were worn, output shaft was fine. The noise developed in the last 12 months and the car hasn't been driven hard in that time. All other gears were fine.
As to the 5th gear thickness can't remember being a huge difference in thickness between the gears.
FKN16V
NSW, East Coast
Re: T50 weak 5th gear Sat, 01 January 2005 07:34 Go to previous messageGo to next message
I had my t50 rebuilt about 12mths ago and the 3rd gear was worn to all hell, i dont see how, it only had a 4ac infront of it.
The dude that did the rebuild says normally when a gear is about to let go/break you can usually see a worn pattern on the other surrounding gears, but my 4th and 2nd were fine, no obvious signs of wear.
Doesnt make sense really does it.
Steve
schnitzel
Bendigo
Re: T50 weak 5th gear Sat, 01 January 2005 08:15 Go to previous messageGo to next message
HAs your car got a towbar if so would suspect someone has been towing in 5th which normal;ly causes the wear you a describing.
(overdrive shouldn't be use when towing according to owners manual)
regards
gold28
Madrid - Spain
Yeah I had this problem with my old RA28. The spline on the 5th gear only covers about half the gear width. A bit of a design fault in my opinion but who knows why they did it that way. I guess thats why they didn't use this box in the GT celicas.
It will cost you a lot more to repair it than it will to buy another one.
Driving around in 5th at 60km/h is the best way to kill it too. Use 5th on the freeways where it needs higher gearing. Thats why it's there.
Celica73
Re: T50 weak 5th gear Thu, 13 January 2005 09:19 Go to previous message
A bit delayed the reply but anyway.
I don't use 5th are 60 don't normally get to fifth till about 80 or more.
Never towed anything with this gearbox but not saying it's never towed anything due to been in a few cars this engine and gearbox.
As for fixing i had a spare gearbox already so just put that in.
Main reason i was asking cause never sure anything about a weak fifth before just about a weak 2nd mainly. Thanks for all your info too people.
Jason
[Updated on: Thu, 13 January 2005 09:20]
Previous Topic:box probs
Next Topic:camber angles
Current Time: Mon Oct 19 06:04:55 UTC 2026
Total time taken to generate the page: 0.095879077911377 seconds
