Toymods » Tech & Conversions » can any1 in Vic get custom mounts and crossmember for 1jz into a 1ggte soarer?
Esselte
can any1 in Vic get custom mounts and crossmember for 1jz into a 1ggte soarer? Fri, 31 December 2004 06:35 Go to next message
I'm hoping to put a 1jz into an mz soarer, it's currently got a 1g in it, i'm looking to get some custom engine mounts and a crossmember made up for the conversion, just thought i'd ask if anyone in Vic has done this conversion before and can help me out with measurements, or a place to get them made up, or even if someone has done this conversion a few times before i'd be interested in buying them?
Thanks for any help, Dan.
JAZE
cronulla
Re: can any1 in Vic get custom mounts and crossmember for 1jz into a 1ggte soarer? Fri, 31 December 2004 09:56 Go to previous messageGo to next message
all your questions have been answered via reply to your pm, the details on how to do the conversion and everything you need is listed, best of luck with it.
For anyone else attemping or considering doing this conversion, pleases do some research and save yourself time and money:
This conversion does not require custom mounts!
the JZA70 chassis and the GZ/MZ 21 soarer chassis are identical. making this a straight swap from the JZA70 halfcut. If anyone needs any further details on the costs and other little bits and pieces to remeber please pm, and i am happy to answer any questions.
you will need onl the following major items:
wiring
tailshaft
and exhaust.
and a coupple ofother little bits and pieces here and there.
also time and mechanical knowhow to do it will help.
Esselte
Re: can any1 in Vic get custom mounts and crossmember for 1jz into a 1ggte soarer? Fri, 31 December 2004 10:46 Go to previous messageGo to next message
Awesome thanks heaps JAZE.
Danish
Re: can any1 in Vic get custom mounts and crossmember for 1jz into a 1ggte soarer? Sat, 01 January 2005 04:23 Go to previous messageGo to next message
www.users.bigpond.net.au/soarer
73ke25
adelaide
Re: can any1 in Vic get custom mounts and crossmember for 1jz into a 1ggte soarer? Mon, 03 January 2005 12:20 Go to previous messageGo to next message
Danish wrote on Sat, 01 January 2005 14:53
Why post that ? i cant find anything that explains the conversion with any detail ? Confused
Danish
Re: can any1 in Vic get custom mounts and crossmember for 1jz into a 1ggte soarer? Mon, 10 January 2005 05:58 Go to previous message
Why post that? Because I explain what I did and used?
Join the dots perhaps?
Or better yet, use the search function, it has been explained many times that JZA70 crossmembers are interchangable with GZ20. As are most parts.
Previous Topic:2000 hilux front lowering
Next Topic:ae92 levin rear strut replacement
Current Time: Thu Oct 29 23:54:41 UTC 2026
Total time taken to generate the page: 0.0062949657440186 seconds
