Toymods » Tech & Conversions » Coilcover Q
Alchemist
Coilcover Q Sat, 01 January 2005 01:25 Go to next message
Hi Guys,
Now this is a rather embarrassing question, but I may as well ask it here...
Am I right to assume when you use coilcover suspension you no longer need to use a separate set of spring springs like with a normal shocks setup, because the springs are already attached to the shocks. I could be right, or totally wrong.... Embarassed
So if I bought a set of coil covers and got them fitted I wouldn't need anything else...
Also whats the benefit to coil covers, is it just there adjust ability, or is there something else?
Embarassed Yay embarrassing question over, least I'll know in the future
bathurst-91
Re: Coilcover Q Sat, 01 January 2005 08:21 Go to previous messageGo to next message
Theyre not attached as in welded. But they are in a sense that they are completely captive to the strut. Coil covers as in a coilover sleevekit? If they include the springs (which they should) they should mention it. If they dont then its just the kit minus springs... and you'll need to get some.
Coilovers are a mechanical advantage in the way they're designed to simply give better suspension response. Simply put it's just a better design and works better. Adjustability is just a byproduct/plus.
Jonny2TG
Tasmania
Re: Coilcover Q Sun, 02 January 2005 05:45 Go to previous messageGo to next message
Sorry, but coilovers do not give a mechanical advantage as you say. Adjustablility is the main advantage, not a by product.
To answer the original question, it depends what type of supension you are replacing. It's best to understand looking at pictures.
The main reasons for "coilovers" is:
-you use a standard diameter spring, so you can easily use any generic race type spring to swap around and change your spring rate. The spring is not model specific, just a 65mmID spring for example.
-The smaller diameter spring can allow for more clearance, sometimes needed for different camber/caster angles.
-The ride height is adjustable.
Coilovers will not change the way your car handles at all if you use the same spring rate and shocks. But once you go to a coilover setup, you have a greater choice of springs and other aftermarket things.
bathurst-91
Re: Coilcover Q Sun, 02 January 2005 08:11 Go to previous messageGo to next message
Byproduct was the wrong word to use there.
However a coilover setup is definately an advantage of design.
Take an older car for example.
And old worn top hat and non-captive lower cup design
vs
A totally captive system.
Adjustability is not the only factor.
Re: Coilcover Q Sun, 02 January 2005 08:21 Go to previous messageGo to next message
I guess we should also ask for what reason most people get 'coilovers' fitted. Maybe it's got something to do with shiny bits and colourful springs??
Think of turbo timers here - is it anything to do with making your turbo last longer, or something to do with suckers getting sold a cheap timer with coloured lights that they've been told will do something...
Alchemist
Re: Coilcover Q Sun, 02 January 2005 08:57 Go to previous messageGo to next message
I guess the reason for asking the Q was there is a set of coilovers for the SW20 on here for sale at the moment, seem to be a similar price to a new set of shocks and springs(which I had on my mind anyway as 15 Yo. suspension is getting a little creaky and jittery), wondering if they are worth the investment Smile
Trust me I'm very anti unnecessary shiny bits, if it makes my car handle better, then I'm interested Smile
[Updated on: Sun, 02 January 2005 09:00]
SXY184
Re: Coilcover Q Sun, 02 January 2005 09:09 Go to previous messageGo to next message
Oh yeah , they will make that beasty handle like a dream, a bit how you going on sydneys great roads...lol.
but on a good road they are great , i got a set on the ST184 and they are jus gold....
hope ya buy and if ya do , you will enjoy cornering very fast!
Re: Coilcover Q Sun, 02 January 2005 10:01 Go to previous messageGo to next message
Take a coilover strut with a spring rated at X lb/in. Then take a conventional McPherson strut with a spring also rated at X, and with the same strut insert. The difference between the two will be ZERO; there is no "mechanical advantage", they both work in exactly the same way.
The advantage of the coilover strut is adjustability, and the ability to easily purchase springs in 25 lb/in increments. This is very useful on the track, but on a street car it's little more than wank factor.
Arch
Re: Coilcover Q Sun, 02 January 2005 23:09 Go to previous messageGo to next message
Another advantage of coil overs is that you normally run a shorter strut, with a short stroke shock inside. this is better for handling, the only other way to get a short stroke shock in a normal length strut is to put something inside the strut to give the shock something to sit on, and ive heard that thats not good to do.
shinybluesteel
melbourne
Re: Coilcover Q Mon, 03 January 2005 01:14 Go to previous messageGo to next message
i was going to say something before, but other people have summed up my thoughts pretty well.
there IS an advantage running large diameter springs, as you can have the spring axis offset to the strut axis, which reduces the side load on the shock absorber shaft, making them last longer.
i suppose one "advantage" of coil overs is that when the spring goes "uncaptive", it wont fall off the perch, but if your springs aren't captive all the time, then you have designed your suspension wrong.
[Updated on: Mon, 03 January 2005 01:15]
turbokid
Re: Coilcover Q Mon, 03 January 2005 07:14 Go to previous messageGo to next message
The basic answer to this thread is;
"If you don't know what coilovers are, you don't need them!"
Alchemist
Re: Coilcover Q Wed, 05 January 2005 14:09 Go to previous messageGo to next message
But there is certainly no harm in trying to learn, is there? Anyway thanks for the help guys.
Starfire
Re: Coilcover Q Wed, 05 January 2005 15:39 Go to previous messageGo to next message
Another thing about coilovers is that they tend to be aimed at performance and race customers.
As a result they are generally very well made and of a very high quality. They can generally be serviced as opposed to being a consumable item like conventional struts.
Standard type suspension tends to cover the low to medium performance while the coilovers tend to cover medium to OH MY GOD WHAT THE FUCK IS THAT!
Check out some of the options being packed in to the fightex range here:
http://www.todaracing.com.au/html/body_details_dam pers.html
Now if only they werent so damn expensive I'd get a set for my MR2...
[Updated on: Wed, 05 January 2005 15:39]
NAMDAMAMI
England
Re: Coilcover Q Wed, 05 January 2005 19:43 Go to previous message
I have adjustable coil overs on my Datsun 260Z. Now I can get the car corner weighted for better distribution. Better weight distribution = better handling Smile
Previous Topic:AE86 Jap and Aus spec tanks
Next Topic:That Shell Helix 20-70 "sport/high revving" stuff
Current Time: Mon Nov 2 12:50:03 UTC 2026
Total time taken to generate the page: 0.0073621273040771 seconds
