Toymods » Tech & Conversions » Car alarm
Frenzyd
Car alarm Sat, 01 January 2005 05:50 Go to next message
Brought a second hand car 2 weeks ago Camry 2001 model v6 conquest. when I lock / unlock the the door. there is a beep beep sound. how can I turn it off? how about next time I want to that asund again. how can i do it.
Thanks for your help
Dust
Re: Car alarm Sat, 01 January 2005 06:05 Go to previous messageGo to next message
if its the standard car alarm (from factory) should be info int he owners manual.
If its anything like our Celica alarm then there should be a button inside the car near that red flashing light, If u push it, it will cycle thru different modes, one of ours is, no beeping.
Hope it helps some.
Dust
Frenzyd
Re: Car alarm Sat, 01 January 2005 06:50 Go to previous messageGo to next message
I wil give it try and have looks. thanks
73ke25
adelaide
Re: Car alarm Mon, 03 January 2005 12:11 Go to previous messageGo to next message
take a picture of the remote or find out what brand it is . If its a cyclops i can tell you. A later cyclops that is.
Celica_John
Re: Car alarm Tue, 04 January 2005 06:21 Go to previous messageGo to next message
if it's factory i thought that means a door is open.
Callifo
Gawler, SA
Re: Car alarm Tue, 04 January 2005 07:03 Go to previous messageGo to next message
On mine you just press the second button then the unlock/lock button and that mutes it.
shaneblack
Albion Park, NSW
Re: Car alarm Wed, 05 January 2005 06:19 Go to previous message
Celica_John wrote on Tue, 04 January 2005 17:21
It also wouldn't lock the doors if that's the case. Well that's the way it works with my 97 Camry.
Anyway, the procedure for disabling the horn chirp on arming and disarming is as follows:
1. Turn headlight switch to OFF
2. Cycle the ignition from OFF to ON three times (within 5 seconds), leaving it in the ON position. The security indicator on the dash will light contninuously for 5 seconds.
3. Press the horn within 5 seconds of the indicator illuminating. The blinkers will flash once to confirm success.
4. Turn ignition to OFF and give it a test.
To turn it back on you do the same thing again.
Previous Topic:Toyota Century 4V-E engine info wanted
Next Topic:CT20B
Current Time: Sat Oct 31 05:32:41 UTC 2026
Total time taken to generate the page: 0.0082070827484131 seconds
