Toymods » Tech & Conversions » changed: cam timing query on 5ME
changed: cam timing query on 5ME Sat, 01 January 2005 09:11 Go to next message
anyone got a 5ME manual handy?
i'm just about to remove the head from the 5ME and am undoing the camshaft bolt that attachs the camshaft sprocket to the cam.
fixed: it's reversed (and the thin metal plate with the security tab has a slight gouge in it now)
btw: the cam timing mark on the sprocket is 1/2 a link away from top centre - is this acceptable for this engine? for comparison my 18R was degree'd in to suit the turbo cam, so this amount of variation seems unacceptable - but maybe not? advice most welcome.
tia,
charles.
[Updated on: Sat, 01 January 2005 09:21]
wilbo666
Re: changed: cam timing query on 5ME Sun, 02 January 2005 00:37 Go to previous messageGo to next message
Ahhhh! that left hand thread will get you :S
Hmm, so the cam is showing half a link away from TDC when the crank is at TDC? That sounds wack to me Confused
EDIT/UPDATE: Could it have something to do with the tensioner? (guessing that u have the tensioner out...and maybe the chain 'appears' longer as its not tensioned now?...not sure which side that would make the chain goto tho? suspect the right looking at the motor?)...
Is the timing chain idler pulley in ok nick?! Mine was shagged (as was the MTEU one), but seeing as the motor was rebuilt not long ago u might be ok...? If you get really stuck take the front timing cover off and line the timing up via the timing chain marks?
ps, I'm not at home atm as u know! but I have my mx62 haynes manual if u want go round and grab it? (the TSRM is all 5mge...),
OT: anyluck with that bellhousing? I suspect its a 3Y one actually (can see some pink wrecker looking pen on it :S) and I think starter and clutch slave are on the wrong side! Crying or Very Sad
So the BHG fix is already well underway?!
[Updated on: Sun, 02 January 2005 00:44]
Re: changed: cam timing query on 5ME Sun, 02 January 2005 02:02 Go to previous messageGo to next message
hi will! ... the link was half-link out when at full tension... maybez i do need the manual ? (shame i now have to catch 2 buses to get there) It might explain why it had lotsof power down low but ran out of puff before yours did.
i have ziplock thru link that sits on the timing mark - i'll score the link with a file before re-assembly.
idler pulley appears to be in good nick - chain is very flexible but no obvious stretch (not that you can easily tell when half the chain is still in the guts of the timing cover).
i never got around to look at the bell-housing - i left to head up to Maleny for NYE and got as far as Shane's place. engine ran fine under power, but at idle it was rough and at shanes place we clearly observed bubbles in coolant and steam at exhaust. temp got up to 3/4 mark after fuel stop at a servo (when i first noticed the rugh idle) near shane's place
BHG fix is well underway - the failure came from minor mods made to the water gallery in the head - on the exh side (on the block) has a fairly wide channel with a sort of bridge halfway along - the matching 'bridge' on the head had been machined away - end result being a weak point in the water-jacket seal about 5mm away from the fire ring... you can imagine the rest.
I'd say they machined the head out to ensure that both sides of the channel flowed (one side in the head is a dead end and fills up with junk)- downside was weakening the seal around the water jacket. idiots.
I'm stil a little unsure of how water vapour got to the oil - there's no obvious join between water and oil galleries - however the gasket left lots of silvery shit on both faces and lifted off very easily so i suspect it travelled thru the gasket and also via piston blowby at idle and decell (high vacuum, low fueling, retarded ign timing). it also could have got in during the few engine shutdowns i had that day.
now that i think about it, for the last few days it hd been starting rough - i had simply put that down to being cold and uncleaned injectors. until NYE, there was no sign of gunk on the oil filler cap.
i also doubt that head was re-tensioned after burn-in. The cam bolt was the tightest thing on the engine - followed closely by the banjo bolts on the fuel filter (which i suspect is as old as car). Sure there's 40psi of fuel beind them joins- but to do them up to same torque setting as a Mitsu head bold (approx 120 lb/ft) is fuken stupid.
When i got the head off, #6 had water sitting in the piston dish and the chamber/piston crown are clean from water being introduced into combustion process.
btw: previous owner must have some cooling issues - the lower section of a thermostat was wedged down inside the housing - the bit you rip off when you want a free-flowing thermostat - fuken lazy work. It also had functioning thermostat in place... v.weird.
plan is to get new gasket set (VRS), clean up the the head/block faces and re-assemble. There no visible damage to the head surface at #6
btw - now is reasonable opportunity to insert slightly larger injectors? Wink
every injector plug has some damage (as has the temp sensor socket) and plug for #2 was held in place with blue gasket gunk. Shocked
cheers,
charles.
wilbo666
Re: changed: cam timing query on 5ME Mon, 03 January 2005 00:32 Go to previous messageGo to next message
hmm, yeah bugga about the buses! Sad (i'd offer to drop it round if I was in the state Razz)
I still don't see why you want these bigger injectors Razz
A: Your going to sell it one day soon...
B: Even if you still get around to MS it, it'd be good if it had tables for a stock 5me...as opposed to a hybrid Razz
C: I doubt that you will max out the injectors without massive head work and a cam, or a turbo (hey on that note, why don't you put the MTEU manifold I have in the shed on it, and the t25 you have Wink)
ps, did you have fun pulling the inlet manifold off in the car Confused I had a 'great' time when I did mine...
(btw, might be interesting to see how much ur on the cheap BHG repair costs, might be worth fixing the supra one (mine) if its only $100 for the HG and selling an 'OK' 5me...)
Re: changed: cam timing query on 5ME Mon, 03 January 2005 04:07 Go to previous message
part costs so far:
VRS kit from repco $150 - isn't monotorque but is ACL
copper max and blue gasket goos - $26
gasket paper - $5
bottle of hylomar (was out of this anyway) - $13
buses and courier - $9
needed: ECU temp sensor (busted the plug dammit)
already have: thermostat, oil, coolant, oil filter
manifold was a bitch - i left the inner part attached to the head until head was removed - the lower stud holes were filled with crap and were not allowing the manifold to slide off... grrr
i dismantled as much of the manifold as i could while head still on engine - i figured all those bolts were put there for a reason Wink
The reason for considering injectors was all the stuffed plugs... also, i'll have little use for gen 1 1G-GTE units Wink
It would be a lift form 182cc/min (grey 5ME plugs) to 220 cc/min (yellow 1G-GTE).... i've got a day or two to decide Wink
as for the t25, i'm not going to soil it by bolting it onto a grubby 5M? Razz Laughing
plus i'd then be up for the costs of dump pipe? ... however, a low boost high compression supra would be fun (while it lasted) Wink
cheers, charles.
Previous Topic:Taking the head of 7M- advice for 1st timer??
Next Topic:ECU swap from ST to BT 20V
Current Time: Mon Oct 26 06:00:56 UTC 2026
Total time taken to generate the page: 0.22039890289307 seconds
