Toymods » Tech & Conversions » gz20 IRS diff into ra28
jcmunga
adelaide
gz20 IRS diff into ra28 Sat, 01 January 2005 11:58 Go to next message
does anyone know if this can be done and how hard it would be???
V8_MA61
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:01 Go to previous messageGo to next message
yeah it could be done. but itll be VERY expensive. FYI, Gz20 rear end is the same as MZ21 and MA70 rear ends. Same crownwheel size and interchangeable with hilux centres...
you are better off putting either a live hilux rear end or a 9" Smile
jcmunga
adelaide
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:02 Go to previous messageGo to next message
i already have a wrecked soarer in my front yard
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:05 Go to previous messageGo to next message
If you're a fabrication genius with a lot of time on your hands, sure why not, it could be interesting.
On the other hand if you just happen to have a GZ20 rear end and a Celica lying around and thought it might be a good idea to combine the two, think again.
V8_MA61
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:13 Go to previous messageGo to next message
mine is gonna be a big enough PITA replacing the F with a G series...the centres are entirely different and a LOT of work and money needs to be spent to do it properly....(if in fact i do go the G series)
jcmunga
adelaide
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:16 Go to previous messageGo to next message
yeah, i just thought it would be cool to have irs in the 28, ill probably abort the idea when i have a serious look
brett_celicacoupe
townsville NQLD
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:20 Go to previous messageGo to next message
i would expect the celica chassis would be too weak in the centre to have a diff just bolted there. the GZ20 would probly have extra thick metal around wher the diff bolts in so it doesnt just tear out when u nail it
brett
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:25 Go to previous messageGo to next message
Actually the diff and suspension in a GZ20 are mounted on a subframe, and from memory there are 4 giant bolts attaching the subframe to the chassis. The hard part is getting those attachment points in your chassis and making it strong enough to handle the loads.
jcmunga
adelaide
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:29 Go to previous messageGo to next message
so if its all on a sub frame and all came out in one peice, couldnt it be positioned in the 28 and then reinforced where it needs it?
V8_MA61
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:32 Go to previous messageGo to next message
re-inforcing a 30 year old celica chassis to handle 100kg+ of diff subframe, which is supposed to be built so it can cop a lot of torque and power is not going to be an easy test. I seriously doubt it would EVER get approved...
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:35 Go to previous messageGo to next message
V8_MA61 wrote on Sat, 01 January 2005 22:32
Its easy to do and will easily be approved. I had a IRS setup made to temporally suit a TA Celica so see if it would handle ok. The car handled like shit so the project was abandoned Confused
jcmunga
adelaide
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:37 Go to previous messageGo to next message
why did it handle so bad? so your saying not to bother trying?
V8_MA61
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:38 Go to previous messageGo to next message
well ill be fucked...who ever thought that would be allowed on the streets Surprised
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:48 Go to previous messageGo to next message
Its kind of hard to explain but i'll give it a go.
At first we set it up so that both wheels had 0 camber. This was fine when driving in a straight line but when taking off hard and the rear bogged down, it was only the inside edge of the tyres that made contact! So traction was a bit on an issue. Cornering was almost impossible with this setup also.
We changed the setup around a few times to try and get the tyres to have 0 camber when accelerating and cornering with some success but incountered problems elsewhere. The rear end of the old Celicas is to light for a convectional IRS setup. A control blade setup like on the newer Jags and on the BA Falcoons would be a different story but by the times you get it all fitted, the car would be heavy enough to suit the old IRS.
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:50 Go to previous messageGo to next message
V8_MA61 wrote on Sat, 01 January 2005 22:38
A full rollcage is enough to enforce a car! Done correctly the body has no effect on the strength of the car anymore.
jcmunga
adelaide
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 12:55 Go to previous messageGo to next message
what was needed to set it up? the ra28s are heavier in the arse than the TAs but how much weight would be needed? is it worth f@#$ing around with?
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 13:01 Go to previous messageGo to next message
The car we had it in was just a test car so it was bolted to the current shock, swing arm and rear tow points aswell as through the floor.
I dont think its worth it! I think conventional IRS is ghey and and a waste of time. Thats why you find it still used in Holdens. Control blade is the way of the future.
jcmunga
adelaide
Re: gz20 IRS diff into ra28 Sat, 01 January 2005 13:04 Go to previous messageGo to next message
yes well i dont think ill be bothered trying to fit control blade so i guess ill stick with the g series cinversion, much easier and cheeper
Re: gz20 IRS diff into ra28 Sun, 02 January 2005 07:51 Go to previous messageGo to next message
It could be done and made to work fairly well, but basically would involve cutting the floor out of the whole back half of the car and fabricating everything to be spot on. A lot of effort, but then if you enjoy the challenge....
indigoid
Canberra, ACT
Re: gz20 IRS diff into ra28 Sun, 02 January 2005 11:36 Go to previous messageGo to next message
so does anyone have a diagram of a control blade style setup?
I did some googling and also looked on the ford australia website. found some pics, but they weren't very good. It does look quite compact, which I guess is good for family cars
Purple_Beasty
New Zealand
Re: gz20 IRS diff into ra28 Sun, 02 January 2005 21:10 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=27918&rid=&S=c8c6a5e90be2d5530e531e8fed8 b6aac&pl_view=&start=0#msg_242361
That should give you an idea of the work involved. Generally I wouldn't recommend it, but in my case it was the cheapest option.
Callum
rokusan
western queensland
Re: gz20 IRS diff into ra28 Tue, 04 January 2005 11:04 Go to previous message
i know it's nissan, but have you thought of a silvia cradle? upper and lower control arms, good brakes, cheap and a heap of goodies available like mech lsd's Rolling Eyes
Previous Topic:GZE Stalling without oil cap
Next Topic:Peoples opinon on RT141 disc brake rear end in AE86
Current Time: Sat Nov 21 20:57:49 UTC 2026
Total time taken to generate the page: 0.0063130855560303 seconds
