Toymods » Tech & Conversions » 4age/4agze bearings are gone again WTF!?
fatmr2
4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 02:26 Go to next message
Has anyone had problems with their bearings going in a 4a motor?
Also, does anyone know how good the standard oil pump is?
Mr Revhead
nelson, new zealand
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 03:33 Go to previous messageGo to next message
what brand bearings did u use?
did u just go to repco and ask for standards?
toyota crank bearings come in 5 grades on standars... and 3 grade for the rod bearings...
so aftermarket ones are hardly ever correct off the shelf. that could be your problem. otherwise id be looking for an assembly fault or incorrect tolerances.
the stock oil pumps are fine up too around 9500rpm
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 03:51 Go to previous messageGo to next message
bearings should never touch anyway, so sounds like an oil supply problem.
pressure relief valve stuck open? oil galleries blocked?
fatmr2
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 07:01 Go to previous messageGo to next message
I'm running an oil filter relocation kit and a cooler. I thought that might cause a problem cause there might not be enough pressure??
other than that i just don't know why it happened again. It happened to my original standard big port and now to my gte.
Oh, and the bearings are a better aftermarket brand. not sure what though? so it should have been ok! obviously not Laughing
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 07:33 Go to previous messageGo to next message
might be good to double check a few things... the oil pressure circuit, are you bleeding too much off? doe the relocator have the overpressure relief for the bypass flow to the cooler? or is the cooler in series with the filter?
if stock 4AG's work fine, and your doesn't, then your deviation from stock seems to be a likely culprit Wink
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 07:41 Go to previous messageGo to next message
Are you running a stock sump and giving it an unreasonably hard time??
fatmr2
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 09:26 Go to previous messageGo to next message
The cooler is in series with the filter.
And no, i wasnt giving it a hard time. I was just running it in. Low boost, low revs. I spent a lot of time and money so i wasnt in a hurry to blow it up. and it still runs the stock sump. Why would that effect it?
The only thing is that ive had the same prblem from a stock set up and now from a setup that is FAR from stock?
[Updated on: Sun, 02 January 2005 09:27]
Toobs
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 11:28 Go to previous messageGo to next message
Have you had your flywheel and crankshaft balanced?
If not then they could be off balance and could be a factor contributing to your bearing failure.
fatmr2
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 11:43 Go to previous messageGo to next message
Toobs wrote on Sun, 02 January 2005 22:28
Yes the whole engine was done.
[Updated on: Sun, 02 January 2005 11:44]
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 12:09 Go to previous messageGo to next message
fatmr2 wrote on Sun, 02 January 2005 20:26
so it happened on a stock setup with the cooler? or totally stock?
feral4mr2
Bundaberg, Qld.
Re: 4age/4agze bearings are gone again WTF!? Sun, 02 January 2005 12:13 Go to previous messageGo to next message
Mr Revhead wrote on Sun, 02 January 2005 13:33
i used the ACL bearing listed in the book at work when i rebuilt my 4agte. i didnt even plastiguage them and it's been thrashed for about 14 months with no problem at all.
if i where you fat, i would drop the sump and have a look see.
syncro
ireland
Re: 4age/4agze bearings are gone again WTF!? Mon, 03 January 2005 03:58 Go to previous messageGo to next message
did you clean out your oil cooler after the bearings went the first time?
fatmr2
Re: 4age/4agze bearings are gone again WTF!? Mon, 03 January 2005 04:12 Go to previous messageGo to next message
syncro wrote on Mon, 03 January 2005 14:58
New cooler on a new engine.....
fatmr2
Re: 4age/4agze bearings are gone again WTF!? Mon, 03 January 2005 04:16 Go to previous messageGo to next message
feral4mr2 wrote on Sun, 02 January 2005 23:13
Bastard Twisted Evil
This type of shit only happens to me! I just hope they can fix it fast and i'll ba back on the road Very Happy
I would but i had to give all the car stands and jacks back Sad
4agte
Toronto, Downtown
Re: 4age/4agze bearings are gone again WTF!? Mon, 03 January 2005 12:00 Go to previous messageGo to next message
I would cry then start pointing fingers Very Happy
allencr
tallahassee FL usOFa
Re: 4age/4agze bearings are gone again WTF!? Mon, 03 January 2005 15:34 Go to previous message
an oil filter with an "anti-drain back valve" makes it one way only. be sure of your remote stuffs hook up.
else, it's an assembly/clearance problem.
Previous Topic:4k-eu wiring loom diagram
Next Topic:Is this normal ???
Current Time: Mon Oct 19 19:05:51 UTC 2026
Total time taken to generate the page: 0.036439180374146 seconds
