Toymods » Tech & Conversions » Can sump gasket goo be used on a gearbox?
BlackSupra
Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 03:05 Go to next message
Just wondering if genuine toyota sump goo can be used on gearbox sandwhich plates?
It seems to be identical sealent for seperate part listings, with a new part number sticker over the top.
Yet toyota assures me its different?
I understand its a different part number but i feel its an identical product in the tube!
Re: Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 03:07 Go to previous messageGo to next message
Will be fine. Its all I use.
BlackSupra
Re: Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 03:11 Go to previous messageGo to next message
Cool1 wrote on Sun, 02 January 2005 14:07
Good times.
Didn't feel like being extorted for another genuine tube of goo.
ChuckLandwehr
Re: Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 03:14 Go to previous messageGo to next message
Hi BlackSupra, you will probably find the goo is an RTV type Silicon product.
In general, most automotive workshops will use a similar goop, and it will do both jobs.
Your primary concern, is to ensure that the surfaces are FREE of dirt and oil, before you apply the sealant.
Plumbers "Acetone Primer Fluid", thinners, or prepwash, are ideal for cleaning parts prior to assembly. A handy aerosol product is carby-throttle body cleaner, does a really good job.
regards Chuck.
Re: Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 03:15 Go to previous messageGo to next message
I understand as its expensive shit Confused
BlackSupra
Re: Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 03:48 Go to previous messageGo to next message
ChuckLandwehr wrote on Sun, 02 January 2005 14:14
regards Chuck.
Thanks Chuck, yup both surfaces are sparkling clean, 2 stroke does a good job as well, not the best on the hands though. I used degreaser and elbow grease this time, worked fine.
Re: Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 03:53 Go to previous messageGo to next message
carby cleaner is the greatest stuff in the world
also the fastest way to wash your hands after getting down and dirty with the love of your life
Re: Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 10:03 Go to previous messageGo to next message
Probably a good way to give you (Terrence & Phillip voice) CANCER as well!
Re: Can sump gasket goo be used on a gearbox? Sun, 02 January 2005 15:39 Go to previous messageGo to next message
so is getting oil on your skin Razz
Re: Can sump gasket goo be used on a gearbox? Mon, 03 January 2005 07:50 Go to previous messageGo to next message
draven wrote on Sun, 02 January 2005 11:53
Brake parts cleaner is good too.
V8_MA61
Re: Can sump gasket goo be used on a gearbox? Mon, 03 January 2005 08:12 Go to previous messageGo to next message
i used the loctite blue shit on both my box and my sump...it retails for $15 a tube..not a *huge* expense
drift86levin
brisvegas
Re: Can sump gasket goo be used on a gearbox? Mon, 03 January 2005 11:39 Go to previous messageGo to next message
draven wrote on Sun, 02 January 2005 14:53
but don't you hate it when it gets into that tiny little cut/scrape/graze on your knuckle/finger/palm... Shocked OUCHY!!! Razz
allencr
tallahassee FL usOFa
Re: Can sump gasket goo be used on a gearbox? Mon, 03 January 2005 15:46 Go to previous messageGo to next message
i wouldn't.
the sump/pan is a very bendable, when torqued, piece of sheetmetal that will have large gaps to fill, and the gearbox is a very stiff & well machined piece of alum., that theoretically won't have any gap at all to fill.
that silicone/rtv stuff is great for gaps, but doesn't like close tolerance stuff.
i think, on machined parts, it does all its sealing on the inside & outside edges where the goop has been squeezed out, and nothing between the surfaces.
Jason
Re: Can sump gasket goo be used on a gearbox? Mon, 03 January 2005 23:41 Go to previous message
I like to use Loctite 518 on most stuff. Works well on aircraft so it works well on my engines too.
Previous Topic:need help with fillingout rear guards on ae86
Next Topic:1jz coolant leak
Current Time: Sat Oct 24 04:43:55 UTC 2026
Total time taken to generate the page: 0.0053720474243164 seconds
