Toymods » Tech & Conversions » Cressida MX63 mods...
floody
Cressida MX63 mods... Sun, 02 January 2005 03:36 Go to next message
I can get a MX6? cressida in actually very good condition quite cheaply, and I'm looking at messing with it to use as a cheapo "drift pig". Its very straight, rust free and extremely tidy inside, and mechanically pretty good.
I need to know a few things about them though.
-Its an auto, how hard to convert to manual? what other toyotas can donate parts, gearbox, crossmember etc - maybe a MA61 supra, or MZ20 soarer or something?
-How hard would a 5MGE, or even 7MGE conversion be? Should bolt straight up I guess onto the mounts right? but what about wiring, coolant hoses etc?
-Would I have any chance of finding some stiffer, lower springs for it aftermarket?
Re: Cressida MX63 mods... Sun, 02 January 2005 07:53 Go to previous messageGo to next message
Get in contact with Wilbo666, he can answer all of your questions above.
He has tackled almost everything you have asked for.
Re: Cressida MX63 mods... Sun, 02 January 2005 08:23 Go to previous messageGo to next message
Manual tans isn't too hard
5M and 7M, I wouldn't really bother with either myself
Springs you can get, ask any decent suspension place, or get them made up for you
floody
Re: Cressida MX63 mods... Mon, 03 January 2005 01:27 Go to previous messageGo to next message
Why not use the 5M-GE, 6M or 7M-GE ? I would have thought they would be the simplest, cheapest conversions, and a substantial upgrade from the 5M-E ? I don't want to do a 1G-GZE/GTE as it seems to me to be the most messing about of them all, as well as NA engines often tend not to have had such a hard life.
Possibly a 1/2JZ-GE could be considered, but they're a bit pricey.
I'm glad there's springs out there.
Re: Cressida MX63 mods... Mon, 03 January 2005 01:30 Go to previous messageGo to next message
Its just not worth the money putting an old motor in there.
The 2jzge would be a much better bang for buck conversion.
wilbo666
Re: Cressida MX63 mods... Mon, 03 January 2005 09:48 Go to previous messageGo to next message
Yeah I've done a few things to my mx62, check out my sig... Smile
manual stuff came mostly from a MA61 (clutch, flywheel, bellhousing, fork etc), clutch slave, master hard and soft clutch line, came from a SA63. Clutch pedal was a cut and welded ST141 (which I believe is the same as RA6X and MA61) and a little bit of a custom bracket... gearbox xmember was a custom job (welded on some steel plate and drilled holes...). also custom drive shaft (longer) was needed.
i'm on hols atm, and as such short on time! I'll get around to answering the rest of the questions later Smile
Re: Cressida MX63 mods... Mon, 03 January 2005 10:40 Go to previous message
Use a 5,6 or 7MG if you want, it's just that many of them are buggered nowadays anyway, and they're not really a massive upgrade in power terms. 2JZGE would be a smarter choice if you want a low key, NA, cheaper etc. swap. I'm going to help a mate put one in an MX73 soon, the engine with ECU etc. only cost him $800.
Previous Topic:Is this normal ???
Next Topic:Steering rack boots!!
Current Time: Tue Oct 20 11:49:41 UTC 2026
Total time taken to generate the page: 0.017354011535645 seconds
