Toymods » Tech & Conversions » compression
iSPY
Euroka NSW Australia
compression Mon, 27 May 2002 03:54 Go to next message
can someone give me the formula for working out the compression by using the cubic capacity and compression ratio of an engine?
Some clever person out there must know?
Re: compression Mon, 27 May 2002 04:06 Go to previous messageGo to next message
By compression, I presume you mean dynamic compression as measured with a comp guage....no, there isn't a formula because it is dependent upon a swag of other things, not all of them tangible. You need to check your engine manual to know what it should be.
iSPY
Re: compression Mon, 27 May 2002 11:41 Go to previous messageGo to next message
OK thanks for the info. I would have thought it would be a simple matter of multiplying the cubic capacity by the compression ratio then dividing by something or other. Guess I've got a lot to learn about engines.
Jonny2TG
Tasmania
Re: compression Mon, 27 May 2002 14:16 Go to previous messageGo to next message
The valves don't open and shut at TDC. Plus the air speed of the air entering the chamber is not constant. Plus the air density changes with heat. And air leaks past the pistons. Its a very dynamic thing. But surely there would be a rule of thumb, considering compression ratio and camshafts used?
Re: compression Mon, 27 May 2002 23:03 Go to previous message
John, it's incredibly variable from engine to engine, for exactly all the reasons you have outlined. The best you can say is that dynamic compression is directly related to the compression ratio, to a point. Also, it has nothing to do with the cubic capacity of the engine.
Previous Topic:VL Fuel Pump
Next Topic:Engine oil for 4ac ae86
Current Time: Sat Oct 17 15:29:41 UTC 2026
Total time taken to generate the page: 0.0044689178466797 seconds
