Toymods » Tech & Conversions » 2JZGE flywheel weight
BlackSupra
2JZGE flywheel weight Sun, 02 January 2005 04:56 Go to next message
This is just a FYI post because im going to forget this unless posted, it can then be found in future.
Alot of the yanks crap on about how the flywheel weighs in at 13kg.
Well after weighing the stock one and an aftermarket billet one the results are in:
2jzge flywheel weight: 8.1kg
2jzge aftermarket weight: 7.1kg
The claimed weight of the aftermarket one was 6.9kg, so that may be a variable between scales to take into account.
So thats it ladies, i won't need to answer this in the future if people would learn to search. Cool
EDIT: or i could search as well: Embarassed http://forums.toymods.org.au/index.php?t=msg&t h=769&rid=1134&S=950d1f401c1886efa744ef9f1 e11c419&pl_view=&start=0#msg_37713
[Updated on: Sun, 02 January 2005 05:02]
Re: 2JZGE flywheel weight Sun, 02 January 2005 06:12 Go to previous messageGo to next message
LOL.
Re: 2JZGE flywheel weight Sun, 02 January 2005 07:51 Go to previous messageGo to next message
BlackSupra wrote on Sun, 02 January 2005 12:56
Yeah, I was quite surprised when you told me how heavy it was.
All off the factory cast flywheels I've played with have been around the 8kg mark (3Y, 1G, 4M, 5M)
So, was the uber cost of the flywheel worth the weight savings?
Re: 2JZGE flywheel weight Sun, 02 January 2005 08:08 Go to previous messageGo to next message
fwiw, K motor flywheels are around 8-10kg also...
wastegate
Gold Coast
Re: 2JZGE flywheel weight Sun, 02 January 2005 09:29 Go to previous messageGo to next message
Sure they were not talking about the GTE flywheel? Due to the Turbo flywheel having built in dampers.
ed_ma61
Lost in the K hole
Re: 2JZGE flywheel weight Sun, 02 January 2005 10:15 Go to previous messageGo to next message
6.9kg may have been the weight before installation of the ring gear Confused
also, dont diregard the importance of where the weight has been lost from (ie radius)
ed
BlackSupra
Re: 2JZGE flywheel weight Sun, 02 January 2005 10:21 Go to previous messageGo to next message
ed_ma61 wrote on Sun, 02 January 2005 21:15
ed
Radius?
1kg from the rotating mass of the driveline is still a respectable loss, just thought the stocker weighed in even heavier thats all.
Toobs
Re: 2JZGE flywheel weight Sun, 02 January 2005 11:14 Go to previous messageGo to next message
Why don't we change the topic of this post so we can all post up our flywheel weights for comparison?
Maybe we could even post up diameters and bolt patern etc. so we can see which flywheels may be interchangable?
I'll measure and post up the weight of my stock 3SGTE gen 2 and 3 flywheels vs the moly one that came with my exedy twin plate clutch if anyone wants to know.
Re: 2JZGE flywheel weight Sun, 02 January 2005 11:16 Go to previous message
BlackSupra wrote on Sun, 02 January 2005 18:21
Radius?
What Ed means is that 1kg lost from thae outer edge of the flywheel is worth much much more than 1kg lost closer to the centre.
Previous Topic:KW tricks
Next Topic:surge tank install questions (ae93)
Current Time: Wed Oct 28 14:22:43 UTC 2026
Total time taken to generate the page: 0.016853094100952 seconds
