Toymods » Tech & Conversions » Steering rack boots!!
HighRolla
Steering rack boots!! Sun, 02 January 2005 09:04 Go to next message
Can they be replaced without taking the tie rod out of the connection to hub?
I.e When you put a car in for a wheel alignment is it just a matter of unthreading the steering arm out of the tie rod (where they would normally just wind the steering arm in or out a few turns and then slipping the boot on?
Just wondering if it's worth my time putting the boots on or pay extra and get them put on (depending on how much), as I need a wheel alignment anyway.
[Updated on: Sun, 02 January 2005 10:54]
HighRolla
Re: Steering rack boots!! Sun, 02 January 2005 10:58 Go to previous messageGo to next message
Just wanted to know if anyone has replaced them this way..
Toobs
Re: Steering rack boots!! Sun, 02 January 2005 11:02 Go to previous messageGo to next message
Personally I would replace the boot myself and then go get a wheel alignment as most of the commercial tyre and alignment places are pretty clueless when it comes to anything more than mr and mrs bogans ford or commodore.
e.g. The local wheel alignment joint acted like I was stupid when I argued that the toe could be altered on the rear of my ST185 when they said it couldn't.
Toobs
Re: Steering rack boots!! Sun, 02 January 2005 11:05 Go to previous messageGo to next message
And yes on most cars you could/do unthread the steering arm to change the boot... just take note of where it is screwed up to so you can roughly realign the wheels before going to the wheel alignment joint.
HighRolla
Re: Steering rack boots!! Sun, 02 January 2005 11:28 Go to previous messageGo to next message
Thanks for the advice Toobs. I have tried to undo the lock nut on the tie rod before but haven't succeeded. Do you usually use an adjustable to hold the tie rod and the open end of a metric spanner to undo the lock nut?
Cheers!
Toobs
Re: Steering rack boots!! Sun, 02 January 2005 11:29 Go to previous messageGo to next message
I hate adjustable spanners / shifters... but you could use one if necessary.
HighRolla
Re: Steering rack boots!! Sun, 02 January 2005 11:31 Go to previous messageGo to next message
Is that basically what you use though, just normal sized spanners. Maybe I need to get some muscle
Re: Steering rack boots!! Mon, 03 January 2005 07:52 Go to previous messageGo to next message
I used adjustables, and maybe some vice grips.
A hammer is the key though, break that son-of-a-bitch.
You can get a tool to spread the boot over the tie rod end, but if you need to get an alignment anyway, just take them off like you proposed.
Re: Steering rack boots!! Mon, 03 January 2005 09:09 Go to previous messageGo to next message
When the going gets tough, I always break out the trusty stilson Cool
HighRolla
Re: Steering rack boots!! Mon, 03 January 2005 10:06 Go to previous messageGo to next message
Thanks guys - I'll give it a go when I get a chance Smile
I won't let a tyre/wheeel alignment place do it...
Re: Steering rack boots!! Mon, 03 January 2005 10:28 Go to previous message
It's OK to let an alignment place do it... Just go to one of the few that has a rough idea what they're doing...
Previous Topic:Cressida MX63 mods...
Next Topic:1g-gte on an R series crossmember
Current Time: Mon Oct 19 17:04:00 UTC 2026
Total time taken to generate the page: 0.015756130218506 seconds
