Toymods » Tech & Conversions » Idling Help 4 AGE
Keep Rollin'
icon4.gif  Idling Help 4 AGE Fri, 18 October 2002 13:29 Go to next message
Hey Guys,
I have an 86 'Rolla with the 100kw 4 AGE engine. Car runs fairly well so far (bought recently) however when I start it, it idles at about 2500rpm when cold, then once up to temp, maintains an idle range of approx 1500rpm. Any suggestions as to why this is would be greatly appreciated. Thanks
Rolla Boy
Club Member
Sydney, NSW
Re: Idling Help 4 AGE Fri, 18 October 2002 13:52 Go to previous messageGo to next message
My 100kW also does this... Around 2500rpm at start up I imagine would be to assist with warming up the motor quicker but 1500rpm normal idle range I'm not sure about... That seems high... I think that they usually idle at around 800rpm... You may need to adjust the idle-up (???) screw to set the idle to the correct range... This is very easy to... You just need to find the screw and adjust it... You would need to have the car running at normal operating temp, turn the screw so the revs drop and check on the tacho what revs it's pulling... Then just turn the screw again, check the tacho and keep doing this until you get it at around 800rpm and that should do it... But after that, when the motor is cold, start it up and check what revs it's pulling at start-up... It may drop to around 2000rpm but should still be okay...
I'm pretty sure that a 4A-GE uses the idle adjusting screw but I'm not promising anything...
Can anyone back this up???
SW20R
Re: Idling Help 4 AGE Fri, 18 October 2002 14:12 Go to previous messageGo to next message
The high idle is normal when cold..
Ive seen neat and good kept condition 4AGE's
when you start it on a cold day it would start at anywhere between 2k-3k then drop down lower and lower.
about it idling at 1.5K.. mines doing that now if i have the ports open at the throttle body. if i close it by looping it.. it drops down to 900RPM. check the lines from the airbox to the tb.
yeah it does use the idle adjusting screw.
so play around with that
Keep Rollin'
Re: Idling Help 4 AGE Sat, 19 October 2002 03:23 Go to previous messageGo to next message
Thanks for the advice guys, i'll have a fiddle with it today. Its refreshing to post on a forum & get actual, real advice, cheers!
faulksy
Re: Idling Help 4 AGE Sat, 19 October 2002 17:14 Go to previous message
sounds like you have been on the fast or hot 4s forum. that was proabably why u didnt get any good advice. Laughing
Previous Topic:Debadging
Next Topic:Damn crappy radiators
Current Time: Thu Nov 19 14:41:04 UTC 2026
Total time taken to generate the page: 0.14085912704468 seconds
