Toymods » Tech & Conversions » 18R-GU running on
christo
18R-GU running on Sun, 02 January 2005 10:04 Go to next message
when i turn off my car, the engine runs on for about 4 secs. It shutters and shakes and then stops. (its an 18R_GU) anyone give me some idea of what would be wrong?? Thanks
YelloRolla
On your mum!
Re: 18R-GU running on Sun, 02 January 2005 10:05 Go to previous messageGo to next message
shit fuel + too much compression
or
need to clean the combustion chambers
I would try better fuel
crazedrt104
Darwin
Re: 18R-GU running on Sun, 02 January 2005 11:29 Go to previous messageGo to next message
i had the same problem when i advanced the dizzy too much .... retard the timing a little and fixed the problem
christo
Re: 18R-GU running on Mon, 03 January 2005 02:40 Go to previous messageGo to next message
im running it on unleaded fuel. it can run on leaded fuel. does anyone know which fuel would be better to use? or would it be best to go for the high octane fuel such as optimax or ultima?
Re: 18R-GU running on Mon, 03 January 2005 03:43 Go to previous messageGo to next message
all the flavous of fuel (UL, LRP and PULP) can be consumed by an 18RG (there's a few threads about fuel - search will find 'em).
the high octane PULPs will simply give the car a little more go at higher RPMs (or when undertaking any sort of brisk driving) and someimes make idling a little smoother.
as for running on... any of the above listed.
pclabrat
Re: 18R-GU running on Mon, 03 January 2005 06:13 Go to previous messageGo to next message
the higher the octane rating of the fuel the less 'flammable' it is (more potential or stored energy). Better octane will reduce running on and reduce the carbon build up in your cylinders (the carbon promotes running on).
As said above, try less ignition advance, better fuel, and maybe a lower idle speed. Different heat range spark plugs can help, and maybe a combustion flush with decarbonising solution.
Jason
Re: 18R-GU running on Mon, 03 January 2005 23:47 Go to previous messageGo to next message
fix the timing.
christo
Re: 18R-GU running on Mon, 10 January 2005 07:17 Go to previous message
well the problem seems to have fixed mostly. all i did was but shell unleaded in, instead of caltex unleaded. but im going to change to optimax very soon. thanks to all for the tips.
Previous Topic:Crack in exhaust, can i weld it?
Next Topic:Engine mounts
Current Time: Sat Oct 31 14:43:15 UTC 2026
Total time taken to generate the page: 0.089372873306274 seconds
