Toymods » Tech & Conversions » AE 71 diff broken
SXY184
AE 71 diff broken Sun, 02 January 2005 23:25 Go to next message
hey all, i bought a AE71 panel van,...did like three or four burnouts.....the diff didnt like it and is makin some strange noises...what diff can i fit under there that is stronger and dont take much fukin round putting in ..?
TE72_Turbo
Re: AE 71 diff broken Mon, 03 January 2005 01:10 Go to previous messageGo to next message
Nothing Crying or Very Sad as far as i'm aware. The AE71 panelvan diff, being leaf sprung, can only be interchanged with the KE70 panelvan/wagon diff, which is no better.
Where are you located? I have a spare AE71 panelvan diff centre & axles in Canberra (3.9:1 ratio) if you are interested in a simple replacement.
Any larger diff will require some work to change the suspension mounting points, but may be worthwhile if you like your burnouts Very Happy How much oil on the road did you need to get the 4AC to spin the tyres???! Laughing
Re: AE 71 diff broken Mon, 03 January 2005 02:43 Go to previous messageGo to next message
I eventually got sick of busted needlestick diffs, and stuffed a Hilux diff out the back. Was well worth it, and a tightened up LSD isn't exactly a bad thing either Very Happy
SXY184
Re: AE 71 diff broken Mon, 03 January 2005 11:20 Go to previous messageGo to next message
[quote title=TE72_Turbo wrote How much oil on the road did you need to get the 4AC to spin the tyres???! Laughing [/quote]
...well if you need to know ..none actually...she jus bags up... its strange i know... but the plan is to maybe stick either a 20v or a GZE in her with a hilux diff...
TE72_Turbo
Re: AE 71 diff broken Mon, 03 January 2005 11:43 Go to previous messageGo to next message
on bitchumen or grass? Razz just kidding. The 1410mm hilux diff can be fitted without shortening if you change your wheel offset. I've got an F series corona diff in mine, 1415mm width.
Sam_Q
S.E suberbs, Vic
Re: AE 71 diff broken Tue, 04 January 2005 09:51 Go to previous message
I have an AE-71 wagon that I keep on snapping diffs in, once I thought the pannel van ones were tougher so I tried one of them, to make it fit I re-adjusted the center mount out a bit, with the factory adjustment and I also had the flange on the diff modified a bit. The holes are 1mm further away in one direction only and I also had to take step off it. What you could do is fit an ae-71 wagon diff in instead, which is a little better. The hilux option is so bloody heavy and hard, I think swapping the mounts on something like a T-18 diff might be better.
and no it that diff didnt last long in my car (8000km!!!)
Previous Topic:1jz ecu help
Next Topic:short circut?
Current Time: Tue Oct 27 10:15:10 UTC 2026
Total time taken to generate the page: 0.041315793991089 seconds
