Toymods » Tech & Conversions » 82.0mm head gasket on 81.5mm bore?
cswan
82.0mm head gasket on 81.5mm bore? Mon, 03 January 2005 01:41 Go to next message
I've just had a 4AGE block bored and honed for new 81.5mm pistons.
Is it going to be ok to use an 82.0mm head gasket on an 81.5mm bore?
I can only find 82.0mm metal head gaskets (HKS 2mm thick), which I need to lower the compression for higher supercharger boost.
Alternately, does anybody know where I can get a 2mm thick gasket for the 4AGE in 81.5mm?
Any knowledgeable advice would be appreciated. Rolling Eyes
YelloRolla
On your mum!
Re: 82.0mm head gasket on 81.5mm bore? Mon, 03 January 2005 13:35 Go to previous messageGo to next message
The 82mm gasket will be fine. While I have not built 4A's, it is better to have the gasket marginally O/S than to have it breach the cylinder and is more than likley why parts companies have not bothered with the intermediate size.
ed_ma61
Lost in the K hole
Re: 82.0mm head gasket on 81.5mm bore? Mon, 03 January 2005 13:41 Go to previous messageGo to next message
please tell me the 2mm gasket is not being used to drop the compression? are you still maintaining something like a 35thou squish clearance?
feral4mr2
Bundaberg, Qld.
Re: 82.0mm head gasket on 81.5mm bore? Mon, 03 January 2005 21:29 Go to previous message
i used approx 2.6mm of head gasket/s to lower my 9.4:1 c/r for boost... oops. Wink
Previous Topic:1jz coolant leak
Next Topic:Fuel Usage...
Current Time: Wed Oct 21 10:54:55 UTC 2026
Total time taken to generate the page: 0.0048730373382568 seconds
