Toymods » Tech & Conversions » W58 short shift kit???
sbyder
Ipswich QLD
W58 short shift kit??? Sat, 19 October 2002 00:00 Go to next message
Are they around and how much would they cost?
The box's shifter position i just put it is a little tall and foward for my liking, ie; i really have to reach forward to put it in 3rd and 5th gear Confused
I dont mind it at the moment, but i'd like to find a quick shift kit for it pretty soon. If anyonhe knows a place to get one/buy one please tell!
Ben
5KinKP60
Finland
Re: W58 short shift kit??? Sat, 19 October 2002 11:38 Go to previous messageGo to next message
I shall (in time) install a DIY-type linkage which will bring gear lever backwards as much as I like.
All what is neededis a uniball joint, weld a gear lever there, install combo to your ideal location. Cut off present gear lever at abbout 10cm height. Design connecting bar between the two to make it work.
I have seen few such achievements on domestic rally cars. They all have been selfmade.
Short shift pattern can be achieved by making necessary mods on that stick that protrudes from transmission. I'm not familiar with W58 tranny, but in most rwd Toyota trannies there is a ball machined at the bottom end of the stick. Cut this ball away and weld on a piece of rod. Weld ball back on at the end of this lenghtened gear lever bottom end. If you added total lenght of lever bottom end by 15mm's, that's the thickness of spacer you need to fabricate on the surrounding assembly enclosure.
Calculations are a good indication to see just how much gear throw will get shortened. It just takes a few simple drawings of lever ratios from/to a balljoint. (To have a starting point, you need to take measurements of present gear knob travel as you work the gears).
Labour intensive - yes. Extremely difficult to do - no.
-A.
5KinKP60
Finland
Re: W58 short shift kit??? Sat, 19 October 2002 11:39 Go to previous messageGo to next message
No Message Body
[Updated on: Sat, 19 October 2002 11:40]
5KinKP60
Finland
No Message Body
lvn-ra65c
Wichita, Ks, USA
Re: W58 short shift kit??? Sat, 19 October 2002 14:36 Go to previous messageGo to next message
suprasport.com has a short shift kit for the w58/r154 tranny.
http://www.suprasport.com/suprasport/catalog/produ ct_info.php/cPath/31/products_id/204
lvn-ra65c
Wichita, Ks, USA
Re: W58 short shift kit??? Sat, 19 October 2002 14:37 Go to previous messageGo to next message
lvn-ra65c
Wichita, Ks, USA
SUPRAGTE
North Sydney
Re: W58 short shift kit??? Sat, 19 October 2002 23:04 Go to previous messageGo to next message
Dellows automotive in Sydney sell the w58 short shift kit. It's around the 225-250 bracket i think. Fairly pricy for just a gear lever mod! But it is bolt in and of decent quality.
SUPRAGTE
North Sydney
Re: W58 short shift kit??? Sat, 19 October 2002 23:05 Go to previous messageGo to next message
SUPRAGTE
North Sydney
Re: W58 short shift kit??? Sun, 20 October 2002 10:25 Go to previous messageGo to next message
You had to be a copy cat now didn't ya SUPRAGTE? Razz
Re: W58 short shift kit??? Sun, 20 October 2002 10:39 Go to previous messageGo to next message
I've been meaning to make one for mine for some time now - one of those 'will get round to' tasks.
As for the dellows one, I'll make a point of dropping in and seeing it next time I'm up that way - but quality/cost ratio is not looking good for me actually buying it!
Re: W58 short shift kit??? Sun, 20 October 2002 10:40 Go to previous messageGo to next message
Aargh, now I'M guily of repeating myself!
SUPRAGTE
North Sydney
Re: W58 short shift kit??? Sun, 20 October 2002 10:47 Go to previous messageGo to next message
I'm not being a smart arse frankie seriously, something wrong with this thread, errors everytime i try and post a reply. Seems to be happening to others too.
Re: W58 short shift kit??? Sun, 20 October 2002 10:54 Go to previous messageGo to next message
Nah, its cool dude. I was just mucking around with you, but then it started screwing up when I tried to reply to you!
sbyder
Ipswich QLD
Re: W58 short shift kit??? Sun, 20 October 2002 12:00 Go to previous messageGo to next message
thanks guys.... i think
sbyder
Ipswich QLD
sbyder
Ipswich QLD
Previous Topic:Blinkers - 73 TA22
Next Topic:ct 20 base gasket???
Current Time: Thu Nov 19 09:35:58 UTC 2026
Total time taken to generate the page: 0.37838888168335 seconds
