Toymods » Tech & Conversions » im back, injector probs??
Thruan
mackay
im back, injector probs?? Mon, 03 January 2005 23:45 Go to next message
ok ppl ma61 with 5m-e, running like a piece of shi- stuff...no. 6 cyl is not doing any thing. its not the leads or plugs(swapped both around for other cyl's and it was still 6) so it has to be injectors rite? it sounds like its injecting( long screwdriva on top of injector- tick tick sound same as all the others), thought about the HG but no.5 is running fine. i got almost no money so i cant just take it to a shop. but getting the injector out myself is a bit beyond me. i dont have the tools or knowlage to remove the intake,fuel rail is fine but i cnat get the intake off to get to the other bolts holding the rail on. is there other ways to find out what it is?? thanks
Re: im back, injector probs?? Tue, 04 January 2005 01:16 Go to previous messageGo to next message
pull the spark plug out to see if it's wet with fuel
intake is two parts-just remove the plunum/runners section to get access to the fuel rail - you can do it by just removing the throttle body but looks to be a PITA.
you'll need 12/14/17mm spanner/sockets and screwdrivers/pliers for removing various pipes.
the banjo joins on the fuel rail will need 17 or 19mm for the exit and Cold start injector, the inlet is a huge thing which i dont have (e.g. use stilson or vicegrips).
with it being he host season, jsut check that (like me) you HG has't gone - you have any water in the oil (check filler cap) or exh fumes in the water (checkfor bubbles)?
Bert
Re: im back, injector probs?? Tue, 04 January 2005 03:02 Go to previous messageGo to next message
could possibly be a broken valve spring or valve not seating properly. we have had a few engines (at my workshop) with the same problems that you are complaining of, after doing all the stuff you have (leads, plugs), the engine still ran like crap.
pulled the rocker cover off, only to find a valve spring broken and not allowing air into cylinder.....
suggest compression test on all cylinders and comparing no.6 with others.
also if you get injectors out, swap no.6 with another cylinder and see if misfire moves to other cylinder, then you will know for sure its the injector
Thruan
mackay
Re: im back, injector probs?? Tue, 04 January 2005 23:04 Go to previous messageGo to next message
hey ppl. yeah i thought of the valve sticking of something after i posted. havent had a chance to look yet. ill look this arvo. if its that then its all good, but if its not my dads got a mate thats gona look at it on sat...
Thruan
mackay
Re: im back, injector probs?? Thu, 06 January 2005 05:09 Go to previous messageGo to next message
hey guys. well it was the HG. theres more water in my sump than oil (well not really but yeah) so while the heads off im changeing it to the 5M-GE head... anyway any of use got a HG that you wanna sell?? un-used of course... i can quite easily order one in but thought someone on here mite be sellin 1 for less than what auto barn wants... thanks.
Re: im back, injector probs?? Thu, 06 January 2005 10:00 Go to previous message
Perhaps try someplace better than Autobarn Very Happy
Previous Topic:AE82 4AC How Can i Beef It Up
Next Topic:ra65 tank into sa63 coupe
Current Time: Fri Nov 20 14:56:27 UTC 2026
Total time taken to generate the page: 0.0051310062408447 seconds
