Toymods » Tech & Conversions » Drum brakes
HighRolla
Drum brakes Mon, 03 January 2005 23:49 Go to next message
I tried to get a drum cover off to check the brake shoes on a friends 90 model lancer. There is no screw on the front to undo. I had the handbrake off but I couldn't get the cover off. I tried to pry it a bit with a screwdriver and gave a few hits with a hammer, but no good. Any ideas??
[Updated on: Mon, 03 January 2005 23:50]
granmra40
Re: Drum brakes Tue, 04 January 2005 02:37 Go to previous messageGo to next message
Handbrake off good idea. Don't know about that car, but here is a idea. Use adjusters move shoes in. Often drums have a inside lip.
Maurice c
Re: Drum brakes Tue, 04 January 2005 03:02 Go to previous messageGo to next message
I'm not exactly familiar with the Lancer but have changed plenty of others. If theres threads in the hubs, you can insert a couple of bolts in them and break the hub free like this. If not then try hitting the hub at a 45 degree angle on the edge or rotating the hub with some something while hitting it. If their badly lipped then its going to be hard. You might be able to undo the adjusters from the backing plate. Good luck mate.
Bert
Re: Drum brakes Tue, 04 January 2005 03:06 Go to previous messageGo to next message
the drum isnt part of the hub assembly is it, like early barinas...
if so, you have to take the split pin and nut off that hold the bearing on, then the entire drum and hub comes off as a single item.
then you have to ensure correct adjustment of nut when replacing so as not to sieze bearings. and use new split pins.
HighRolla
Re: Drum brakes Tue, 04 January 2005 03:48 Go to previous messageGo to next message
They sound pretty hard. I might let him take it to the shop . ALready tried the hammer tirck..
jcmunga
adelaide
Re: Drum brakes Tue, 04 January 2005 04:50 Go to previous message
i used to have a 93 lancer and has the same problem, the car was written off not long after so i never actually got them off
Previous Topic:AE92 SX Rear control arm bushes (disc rear end)
Next Topic:ST162 gearbox and engine oil
Current Time: Sat Oct 24 11:50:15 UTC 2026
Total time taken to generate the page: 0.0052599906921387 seconds
