Toymods » Tech & Conversions » 1JZ - 2JZ Diffs...
Kyosho
Wollongong
1JZ - 2JZ Diffs... Tue, 04 January 2005 06:14 Go to next message
Hey guys/girls
The 2JZ has a square bore/stroke, (86mm * 86MM from memory)
The 1JZ has an unsquare bore/stroke (86 * 79 from memory)
Now the block is the same as far as I can tell, and so is the head, so is the only difference in the stroke?
Or are there some other internal differences?
Matt
Dumpy Dave
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 07:18 Go to previous messageGo to next message
All 1JZ have a bore of 86mm and a stroke of 71.5mm
The 2JZ are 86mm x 86mm
2JZ heads are different to 1JZ.
Thats all i know. Smile
Chris Davey
sunny coast, qld
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 08:41 Go to previous messageGo to next message
AFAIK block is same material but 2jz is about 25mm higher because of the extra stroke.
1jz head is designed by Yamaha.
2jz head is a toyota head.
Still haven't seen any flow tests done to see which is better. I am predicting a bees dick difference if any anyway.
ed_ma61
Lost in the K hole
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 09:07 Go to previous messageGo to next message
please use the search function Rolling Eyes
Kyosho
Wollongong
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 09:28 Go to previous messageGo to next message
ed_ma61 wrote on Tue, 04 January 2005 20:07
I find they rarely work for me...
To do with the block, so the base of the block is effectively the same, but with an extra 25mm deck height?
Would I be correct then to assume the 1JZ can not be stroked out to be square?
[Updated on: Tue, 04 January 2005 09:29]
86twinky
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 10:20 Go to previous messageGo to next message
Kyosho wrote on Tue, 04 January 2005 20:28
A search for the term "2j specs" quickly led to this thread:
http://forums.toymods.org.au/index.php?t=msg&t h=44901&rid=4176&S=b42217a6740c5c149f1fe85 030101bfe&pl_view=&start=0#msg_408126msg_4 08126
Which led to this page:
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/GasolineEngines.html#JZ-series
searching for "2j 1j block" led to:
http://forums.toymods.org.au/index.php?t=msg&t h=29954&rid=4176&S=b42217a6740c5c149f1fe85 030101bfe&pl_view=&start=0#msg_262255
in which it was stated that the 2J block is taller than the 1J block
A link within the previous thread led to:
http://forums.toymods.org.au/index.php?t=msg&t h=9588&rid=92&S=a6ede4e494b627b268fba5e92d 060950&pl_view=&start=0
which describes the head differences between the two.
There's plenty of info if you are prepared to search and be patient
[Updated on: Tue, 04 January 2005 10:21]
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 10:21 Go to previous messageGo to next message
Kyosho wrote on Tue, 04 January 2005 19:28
You probably could, but you'd need very short conrods which is bad news if you want to rev the engine. But why would you bother? 2JZ blocks are cheap and easily attainable.
[Updated on: Tue, 04 January 2005 10:22]
Kyosho
Wollongong
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 10:35 Go to previous messageGo to next message
Norbie wrote on Tue, 04 January 2005 21:21
I would of gone for the longer stroke to lower the rev threshold (Lower revs, but creates more torque)
When creating the torque lower down (And moving more "gas" at the same RPM as before) the turbo will spool quicker, which means boost on quicker, and because boost is not needed at higher RPM, an smaller turbo can be used, that would generally run out of "puff" at those high rpms...
I had also looked around at buying 1JZ-GTE front cut, and 2JZ-GTE front cut, and found the 2JZ to be around double the price from alot of places (Even more if I wanted the Getraq 6 speed)
So I thought the 2JZ block would be worth more, and if it was only a diff crank in use, then would it be cheaper to swap cranks, but with the extra deck height, there becomes an issue...
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 11:37 Go to previous messageGo to next message
Well, first up, how much grunt you aiming for at the end of all this?
Chris Davey
sunny coast, qld
Re: 1JZ - 2JZ Diffs... Tue, 04 January 2005 13:29 Go to previous messageGo to next message
I don't think a 1jz will be running out of puff up top with a big single turbo. They like to rev quite a bit. They won't make as much power or torque as a similar 2jz though.
so how much power do you want?
450rwhp or less get 1jz
450rwhp or more get 2jz
my 2c Razz
Kyosho
Wollongong
Re: 1JZ - 2JZ Diffs... Wed, 05 January 2005 04:45 Go to previous messageGo to next message
Chris Davey wrote on Wed, 05 January 2005 00:29
my 2c Razz
360 At the treads once a bit of work has been done...
And in the end... Push a MA70 JZ powered Supra into the 11s...
I know, the MA70 is heavy, and is harder to get going quick then the earlier supras, but I just love the MA70...
Chris Davey
sunny coast, qld
Re: 1JZ - 2JZ Diffs... Wed, 05 January 2005 05:42 Go to previous messageGo to next message
I think you may need a bit more than 360rwhp for 11's. maybe over 400 or so. Obviously, there is a lot of variables. The 1jz can certainly push a ma70 into the 11's though. Slicks would DEFINITELY help though Razz
Kyosho
Wollongong
Re: 1JZ - 2JZ Diffs... Wed, 05 January 2005 06:16 Go to previous messageGo to next message
Chris Davey wrote on Wed, 05 January 2005 16:42
I wasn't going to attempt to push the MA70 into the 11s without Slicks and Front runners...
I also want to have proper harnessed seats (Planning on track work) and I will also strip the interior when I go for that 11 (Back seat out, door trims, etc)
The 360RWKW is only the first milestone I want... I just want the crown in the Toymods area for power... Very Happy
Then I want an 11... (Mid - Low 11 preferred... But an 11 all the same)
..J..
opening a can of whoop ass
Re: 1JZ - 2JZ Diffs... Thu, 06 January 2005 01:39 Go to previous messageGo to next message
365 rear wheel horsepower was enough to push the silver cressida at jamboree to an 11.80 at 119 MPH, and that was on DOT approved tyres, not slicks. and i would guess it ways similiar to or maybe more than a supra, mine weighed 1600kg with a half full tank and with no one in it before i sold it.
[Updated on: Thu, 06 January 2005 01:39]
Chris Davey
sunny coast, qld
Re: 1JZ - 2JZ Diffs... Thu, 06 January 2005 01:56 Go to previous message
KYOSHO: I didn't know you meant rwkw not hp Smile Sounds like a nice project! Always good to hear about some quick cars being built Smile
J: that is very interesting info. I would have thought you would need a bit more power for those times but obviously not. shows what a well set up auto can do.
Previous Topic:86: Alternatives to T-series rear-end for LSD & discs?
Next Topic:ra23 loose steering?
Current Time: Fri Nov 20 07:32:27 UTC 2026
Total time taken to generate the page: 0.022353887557983 seconds
