Toymods » Tech & Conversions » !HELP! crossed snaped bolt in block
jcmunga
adelaide
!HELP! crossed snaped bolt in block Tue, 04 January 2005 06:40 Go to next message
ok, im fitting a 1g into my ra28 so need to move the mounts to the front holes, the brackets from the back dont fit the front without mods, but my mate being the genius that he is, thought hed make it fit, he has put the bolt in on an angle forcing it around by hitting the spanner with a hammer. it got half way in and snapped. needless to say he was beaten with the spanner.
How the F@#k do u get the bloody thing out
Bert
Re: !HELP! crossed snaped bolt in block Tue, 04 January 2005 06:50 Go to previous messageGo to next message
first of all.....no offence to your mate but.... dude, seriously thats pretty stupid.
you will probably need to buy a stud remover or use a pair of vice grips, hopefully its easier to undo than do up. bit of crc or rp7 too.
if that doesnt work, youll have to cut the bolt off flush and drill a small hole in it and use an "ezy out"
you can get em from hardware stores. pretty nifty tool.
and then you will need to re drill and tap a new thread into the hole cause it will be completly rooted now.
Danners
Central Coast, NSW
You may need to drill a smaller hole through the centre of the bolt, tap it and then screw a small bolt in there to get it out
Either that or you'll need to get a set of easy outs from somewhere!
jcmunga
adelaide
Re: !HELP! crossed snaped bolt in block Tue, 04 January 2005 06:54 Go to previous messageGo to next message
yes he has been told how slightly retarded he is. there is no hope of gripping it as its snapped off about half a mm inside the hole, how do these ezy out things work??
Bert
Re: !HELP! crossed snaped bolt in block Tue, 04 January 2005 06:59 Go to previous messageGo to next message
ezy outs...basically you buy one thats smaller than the size of the bolt. bout half size.
1. buy corresponding drill bit, good ezy outs come with correct bit.
2. drill hole into snapped off bolt, make sure its straight too
3. clean out all the swarf
4. wind or hit the ezy out into the hole you just made, make sure its a good fit.
5. now you should be able to turn the ezy out anticlockwise (like you are undoing the bolt) and the snapped off bit SHOULD come out.
be a bit gentle tho, you dont want to break the ezy out. i have used them before and they have been great, can be re-used too
jcmunga
adelaide
Re: !HELP! crossed snaped bolt in block Tue, 04 January 2005 07:02 Go to previous messageGo to next message
cool, hopefully it comes out cos its in there pretty hard
cheers guys
Dust
Re: !HELP! crossed snaped bolt in block Tue, 04 January 2005 07:04 Go to previous messageGo to next message
lets see a pic of your mate with the spanner shaped bruises u inflicted Laughing Laughing Laughing
brett_celicacoupe
townsville NQLD
Re: !HELP! crossed snaped bolt in block Tue, 04 January 2005 10:39 Go to previous messageGo to next message
thats what u get for letting mates help u No No No No No No
do everything ureself and u wont have problems
allencr
tallahassee FL usOFa
Re: !HELP! crossed snaped bolt in block Tue, 04 January 2005 15:03 Go to previous messageGo to next message
http://www.motorcycle.com/mo/mcnuts/stuckscrews.ht ml
MIKGTR
Re: !HELP! crossed snaped bolt in block Tue, 04 January 2005 22:43 Go to previous messageGo to next message
The most important thing with getting any bolt that is stuck, cross threaded or broken is HEAT!! Especially when using ezy outs you must heat up the block. Preferably use an oxy set but if you dont have one even a electric heater will help.
And another 2 cents worth on easy outs...
Ezy outs work well in some applications and not in others
If he hammered the spanner around until the bolt broke half way in, as in the head of the bolt had not made contact with the surface there is about a one in million chance an ezy out will work. But there is a really good chance you will end up with an ezy out broken off in the bolt then you've got a real problem!
If you haven't done it before take it along to a machine shop/engine reco shop, these blokes do it all the time and charge bugger all to do it ($20 - $50)
alex_ta22
Newcastle, Hunter Valley
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 01:09 Go to previous messageGo to next message
yeah if it ends up fucking up good and proper, and nothing else will work. You can get it drilled > threaded and then sleeved so you can keep the original bolt size. Bloke at the muffler shop quoted me ~$20 for it
jcmunga
adelaide
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 05:22 Go to previous messageGo to next message
taking it somewhere means taking the whole motor, not to keen on doing that. are there people that can come to you??
Bert
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 05:32 Go to previous messageGo to next message
oh man. didnt realise you were from adelaide. ring a guy called "captain thread"...sounds pretty stupid, i know.
this guy does good work, we use him at my workshop. no bolt or thread to tight for him.
jcmunga
adelaide
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 05:35 Go to previous messageGo to next message
where can i find his number??
YelloRolla
On your mum!
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 05:37 Go to previous messageGo to next message
If your stuck needing to drill it I would go straight past the Ezy out option and just drill it to within a mm of it's life and tapping it to the correct size (carbon steel tap about $10) most engine mount-to-block holes that I have seen are M8 x 1.25mm OR buying the HeliCoil (about $50-60) set.
I recommend this BECAUSE it sounds like the bolt is well galled in there and if you mate tries the reverse technique with the Ezy out (ie hit's it with the hammer) then you problems will be compunded beyond belief)
Bert
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 05:41 Go to previous messageGo to next message
captain thread should be in white pages
jcmunga
adelaide
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 05:50 Go to previous messageGo to next message
cheers mate
YelloRolla: yeah i think i might skip the ezyout and give this captain thread guy a call and see what he reccons
jcmunga
adelaide
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 05:56 Go to previous messageGo to next message
and the winner is: BERT.
capyain thread will be here in an hour. he reccons shouldnt cast anymore that $80
edit: for anyone thats interested his number is 0407 077 414
[Updated on: Wed, 05 January 2005 07:13]
Bert
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 07:11 Go to previous messageGo to next message
no worries mate. glad to be of some help. next time you got a tricky bolt to get in, make sure you hide the hammers!
SL666
Re: !HELP! crossed snaped bolt in block Wed, 05 January 2005 11:16 Go to previous message
Sometimes i take my old man for granted, pulled the exhaust and intake manifold off my 4K (one of the reasons i picked the car up hell cheap) to do the gasket on the heat exchange thing, oh 2 bolts are missing... oh, the two bolts are snapped off in there... TOPS... he drilled and cleaned out the thread for me.. top bloke..
Previous Topic:20v VVT tech question
Next Topic:RA28 wheel size qestions.
Current Time: Sun Nov 1 11:49:47 UTC 2026
Total time taken to generate the page: 0.0057330131530762 seconds
