Toymods » Tech & Conversions » RA23 Diff Center - What else is compatible?
JonsonRA23
Hobart, TAS
RA23 Diff Center - What else is compatible? Mon, 27 May 2002 05:14 Go to next message
My diff is noisy as, i cant find a RA23 being wrecked so i was wondering if any other model celica/corona/corolla has the same diff center as an RA23?
rob_RA40
c'town, NSW
Re: RA23 Diff Center - What else is compatible? Mon, 27 May 2002 05:21 Go to previous messageGo to next message
RA40 (4.1) and RA60 (3.9)
pay attention to trans axle codes on the cars ID plate as u may find different ratios around...
JonsonRA23
Hobart, TAS
Re: RA23 Diff Center - What else is compatible? Mon, 27 May 2002 05:34 Go to previous messageGo to next message
So RA40/60 diff center will go straight into ra23 diff housing?
What ratio would my ra23 be? Should i stick with the same ratio?
rob_RA40
c'town, NSW
Re: RA23 Diff Center - What else is compatible? Mon, 27 May 2002 05:46 Go to previous messageGo to next message
yep it will go straight in
RA23/28/40/60 all have T series diffs
RA23/28/40 --> 4.1
RA60 --> 3.9
ratio may vary with auto transmission so check the axle code
what engine do u have in there?
your ratio should be 4.1 and trans axle code T292
if you have anything more powerful than an 18R-C and want the car to be nicer on the highways then grab a RA60 3.9 (T312)
if not just keep it 4.1
i put a 3.9 into mine (1G-GE) and the car felt and shifted much nicer but i didnt notice any difference in revs at 110km/h on the highway Confused
[Updated on: Mon, 27 May 2002 06:25]
RA23_Sean
Western Sydney
Re: RA23 Diff Center - What else is compatible? Mon, 27 May 2002 06:21 Go to previous messageGo to next message
My RA23 ID plate says it has a T292 already. I thought that was what all the manual 23's had.
rob_RA40
c'town, NSW
Re: RA23 Diff Center - What else is compatible? Mon, 27 May 2002 06:25 Go to previous messageGo to next message
sorry fellas i got the RA23/40 and RA60 axle codes wrong way round ARGH
ive edited my post
[Updated on: Mon, 27 May 2002 06:29]
tanman
Re: RA23 Diff Center - What else is compatible? Mon, 27 May 2002 07:32 Go to previous messageGo to next message
Any old 18RC corona, TA22, TA23, RA23, RA28, RA40, RA60, or T18 diff will fit. Just make sure it is the same ratio, 5speeds had a 4.1 center.
HooN
The Rainy City
Re: RA23 Diff Center - What else is compatible? Mon, 27 May 2002 09:01 Go to previous messageGo to next message
as said above, i think any diff code starting with T will fit your car.... not sure tho so please dont bite Smile
Re: RA23 Diff Center - What else is compatible? Mon, 27 May 2002 11:17 Go to previous messageGo to next message
Yes, all T series diff centres are compatible.
Another common source of T series diffs is RT104 Coronas. Most of them have the same T292 unit as early Celica's. And like anything from a crappy old Corona, it's dirt-cheap from the wreckers! Smile
dcving
newcastle nsw
Re: RA23 Diff Center - What else is compatible? Tue, 28 May 2002 03:08 Go to previous messageGo to next message
t18s also have a 3 something ratio not sure if it was 3:9 or even lower, can anyone else confirm?
thetoyman75
Club President
Re: RA23 Diff Center - What else is compatible? Tue, 28 May 2002 14:00 Go to previous messageGo to next message
T18 Diff centre is a 3.7:1 Smile
celica28
Re: RA23 Diff Center - What else is compatible? Tue, 28 May 2002 22:43 Go to previous messageGo to next message
I have a good one. $40 and you can collect it.
Jonny2TG
Tasmania
Re: RA23 Diff Center - What else is compatible? Wed, 29 May 2002 03:18 Go to previous messageGo to next message
Johnson:
They have a few TA22 / RA23 / RA40 / RA60 celica cars being wrecked at Just Japanese, Grove Rd. Glenorchy. THat is a good place for toyota parts, but they are not cheap. Also Sunderland St. wreckers have a TA22 and RA60.
TE72_Turbo
Re: RA23 Diff Center - What else is compatible? Wed, 29 May 2002 11:56 Go to previous messageGo to next message
hey Phil, what ratio is that diff you got? If its 3.9 or 4.1 (pref 4.1) i'd be interested in it for the T18!
Phil
celica28
Re: RA23 Diff Center - What else is compatible? Thu, 30 May 2002 23:06 Go to previous messageGo to next message
Phil
It is a 4.1.
Come over, you know where I live.
TE72_Turbo
Re: RA23 Diff Center - What else is compatible? Sat, 01 June 2002 01:38 Go to previous messageGo to next message
no probs. I'm all outta cash till payday, so ill call you before i drop around, probably next weekend.
BOOSTN
Re: RA23 Diff Center - What else is compatible? Mon, 03 June 2002 17:09 Go to previous message
I've got one thats been made into a locker if anybody wants to buy. A good diff that I got welded up (gears all in tact), yet never been used since.
p.s. - I'm in adelaide.
Previous Topic:need silver top 20v part #'s
Next Topic:2TG Oil pressure????
Current Time: Thu Nov 19 08:21:32 UTC 2026
Total time taken to generate the page: 0.0060088634490967 seconds
