Toymods » Tech & Conversions » 3T-GTEU power outputs
Purple_Beasty
New Zealand
icon5.gif  3T-GTEU power outputs Sat, 19 October 2002 11:28 Go to next message
Just curious what sort of power those of you with 3T-GTE's are getting and the mods you have done. I am looking to retain the factory computer setup (no money to upgrade) and was wondering what others have done on a very limited budget. Motor is already in good condition (can't afford a rebuild anyway), totally standard other than water to air intercooler and running 10lbs boost, so I estimate less than 200hp at the moment. From research on the net stock turbo/injectors are only supposed to be good for 200hp, what sort of upgrades do you recommend? Considering a CT26 from a supra 7M-GTE at the moment, what injectors will run with the standard computer to support this? (max 14lbs boost). I understand you can fiddle the standard airflow meter to alter the mixture to suit the injectors, has anyone tried this?
Thanks in advance
Callum
gussyboy2
Oxenford/gold coast
Re: 3T-GTEU power outputs Sat, 19 October 2002 12:11 Go to previous messageGo to next message
here's the specs u asked for:
engine type-3tgteu
Valv/Cyl- 2
DOHC
Year-82-85
Disp.-1770cc
BHP-160@6000
Torque-152@4800
Bore-85
Stroke-78
CR-7.8:1
stock boost-~0.5bar (7.3psi)
hope this helps
gus
gussyboy2
Oxenford/gold coast
Re: 3T-GTEU power outputs Sat, 19 October 2002 12:12 Go to previous messageGo to next message
engine type-3tgteu
Valv/Cyl- 2
DOHC
Year-82-85
Disp.-1770cc
BHP-160@6000
Torque-152@4800
Bore-85
Stroke-78
CR-7.8:1
hope this helps
gus
Purple_Beasty
New Zealand
Re: 3T-GTEU power outputs Sun, 20 October 2002 09:41 Go to previous messageGo to next message
Thanks, I already have all the standard specs for the motor. I was more interested in the cheap reliable mods that other have done. Shouldn't need to go too overboard though, only pushing a sub 800kg rear wheel drive starlet...
Purple_Beasty
New Zealand
icon5.gif  Re: 3T-GTEU power outputs Tue, 22 October 2002 09:31 Go to previous messageGo to next message
Anyone, anyone at all?
celikar
sydney, my house
Re: 3T-GTEU power outputs Thu, 24 October 2002 03:51 Go to previous messageGo to next message
I have a 3tgte...
standard computer
standard injectors
rebuilt turbo running 14psi
no intercooler (yet)
blow off valve type 3 turbosmart,
turbosmart boost controller.
i would also like to find out what my power output is... i havent had it dyno'd yet... i will when the intercooler goes on.
i would reccomend going a better turbo tho... i dont get much boost below 4000rpm.
I would estimate i am developing 185-200bhp (not at the wheels)..
i am also aiming for 200 @ the wheels.
to do this i have upgraded the fuel lines, and will be adding a t28 turbo, bigger injectors and a well massive intercooler.
i will also be making a new plenum and bigger throttle body.
all this is on hold untill mid january.
lvn-ra65c
Wichita, Ks, USA
Re: 3T-GTEU power outputs Thu, 24 October 2002 21:09 Go to previous messageGo to next message
celikar, are you gonna keep your stock computer after doing those planned mods?
my current engine state is:
stock computer
stock injectors
big fmic
ct20@7.5psi (stock turbo and boost)
GFB Hybrid BOV(or bosche recirculating bov or sheepdog vent bov)
SARD Trigger boost controller
(this dyno'd at 140rwhp @ 13psi with low fuel pressure and pinging ..the torque was like 160 i think)
planned mods:
new ems?
larger injectors (have a set of 460cc)
rising rate fuel pressure regulator
new fmic
standard rebuilt ct26 @ 7psi (maybe more later)
celikar
sydney, my house
Re: 3T-GTEU power outputs Fri, 25 October 2002 00:31 Go to previous messageGo to next message
not sure about the computer... i may go for a cheap microtech as every one knows how to program them.
but yes i will need a new EMS after these mods...
i am also running bigger fuel lines and a bosh motorsport fuel pump.
i was going to go the ct26 but i have been told being a bigger turbo there is more lag involved...
lvn-ra65c
Wichita, Ks, USA
Re: 3T-GTEU power outputs Fri, 25 October 2002 02:15 Go to previous messageGo to next message
more lag but it shouldnt be too noticeable and your top end should be a lot better ...since my ct20 seem to run out of pull when i hit 115mph Smiley =
no word on the ct26 yet ..
3TGEscort
Re: 3T-GTEU power outputs Sun, 03 November 2002 23:19 Go to previous messageGo to next message
I have this engine in a Mk1 Ford Escort.
Standard injectors
Standard turbo (~13psi according to my boost gauge)
Standard internals
No intercooler
3" exhaust
Pod filter (with no proper cold-air intake)
Autronic SM2 computer.
Previous owner had it dynoed with this setup, and showed 140hp@wheels. Not sure of torque figures.
Future mods: Sell it. Crying or Very Sad
tanman
Re: 3T-GTEU power outputs Mon, 04 November 2002 01:16 Go to previous message
You guys are crazy running more than 10PSI with stock pistons and no intercooler.
[Updated on: Mon, 04 November 2002 07:00]
Previous Topic:ae86 questions
Next Topic:TA or RA Celica?
Current Time: Mon Oct 19 17:04:22 UTC 2026
Total time taken to generate the page: 0.016982078552246 seconds
