Toymods » Tech & Conversions » AE82 Twincam recommendations for shocks?
jim80
AE82 Twincam recommendations for shocks? Sat, 19 October 2002 12:08 Go to next message
Hey Guys,
My mate gave me a set of Whiteline Springs for my corolla, and as far as i know the car is running on the original shocks still.
I was wondering what brands/models of springs you reccommend to go with the springs and where is a good place for to get them installed. I believe the springs are about 1" lower than standdard.
I went to ozzytyres in Bexly and the guy quoted me $980 on a set of Koni's all round installed.
Just want some advice before i go out spending big bucks,
Jim
rollaboy
Coffs
Re: AE82 Twincam recommendations for shocks? Sun, 20 October 2002 12:32 Go to previous messageGo to next message
Well my front shocks were stuffed and my mates dad that works for toyota said that Pedders Comfort gas are good some a got some of them trade price (or a little cheaper than normal price) for $260 for 2....and they are hell sweet.
They also have the Sports Ryder's which are a bit stiffer.
I fitted mine myself..was pretty else.(Never none it before).
Re: AE82 Twincam recommendations for shocks? Sun, 20 October 2002 14:08 Go to previous messageGo to next message
Go the Koni's I reckon, if you're willing to spend that much. As for putting them in, it's not that hard to do yourself if you're keen to have a go - I'm sure someone could show you how its done.
haggis
Re: AE82 Twincam recommendations for shocks? Sun, 20 October 2002 23:40 Go to previous messageGo to next message
If you can afford it, go the Konis.
Cheap and reliable, KYB. (this is what i run)
Wouldn't touch with a barge pole, Monroe.
The ultimate? (IMHO)
http://www.dmshocks.com/docs/dms50.html
But pricey...
All should be easy to install.
Craig.
jim80
Re: AE82 Twincam recommendations for shocks? Mon, 21 October 2002 08:44 Go to previous messageGo to next message
Do i need to get one of those spring compressors to fit it into the braces?
rollaboy
Coffs
Re: AE82 Twincam recommendations for shocks? Mon, 21 October 2002 09:39 Go to previous messageGo to next message
Yes you will need a spring compressor to compress the springs to get them off.
Hunty
Re: AE82 Twincam recommendations for shocks? Mon, 21 October 2002 14:32 Go to previous messageGo to next message
When buying shocks do they come with the strut thing the springs sit on and the bracket down the bottom that the steering knuckle bolts onto? or do i keep these and take off that nut thing and put the shock thingy in, is this a hard job ie can i do it myself? *confused*
haggis
Re: AE82 Twincam recommendations for shocks? Tue, 22 October 2002 01:17 Go to previous message
Hunty: on nearly all FWD corollas, the rear shock comes as a sealed unit IE: it has the lower spring seat and the flanges to bolt onto the hub carrier.
On the front, the shock is a replaceable insert, and so is seperate to the lower tube which has the spring seat and flanges on it.
Yes, you will have to remove that large nut to replace the insert and keep the lower tubes with the spring seat and hub flanges. NOTE that the Twin Cam and Single Cam versions are different! (at least on the AE82)
No, its not a hard job once you have spring off. Use somthing like a pipe wrench with care, and it will work. (worked for me any way)
Craig.
Previous Topic:Maximum Power acheieved in a AE86 shell?
Next Topic:Bluebird TRX LSD into AE86?
Current Time: Thu Nov 19 20:52:15 UTC 2026
Total time taken to generate the page: 0.0067291259765625 seconds
