Toymods » Tech & Conversions » TA22 Reconditioned Steering Boxes
Hodgie
TA22 Reconditioned Steering Boxes Tue, 04 January 2005 14:24 Go to next message
Seen a few threads talking about TA22 steering boxes being worn and needing reconditioning. Don't know if this is of any help but Fulcrum Suspension sell reconditioned boxes for around the $300 mark and they come with a 60000km warranty. This is all from my incredibly dodgy memory so you would be best off checking with Fulcrum rather than take the above figures I have mentioned as gospel. Cheers.
fade-e
Re: TA22 Reconditioned Steering Boxes Tue, 04 January 2005 16:40 Go to previous messageGo to next message
well stock from factory the TA22 steering box should have about 2-5deg play before the wheels turn... on my celica its bout 15-20deg before the wheels turn so you can imagine how much i have to turn to get it round a corner Rolling Eyes
with my current celica the alignment guy gets the shits when i bring it in cuase it takes him ages to really get it straight as but he does an awsome job
with the recod box it should be nice and tight otherwise you can go for a rack and pinion setup with a couple mods to get it in... the other option is to get the box recod to your specs by getting the size changed instead of having it stock, this will obviously change the difficulty of turning and the final turning circle but depending what you want from the car in respect to turning then the stock is fine
i might give them a call when i get to that stage... i wonder if he will trade? i got 3 steering boxes here, ill give the 2 for one new one Very Happy
brett_celicacoupe
townsville NQLD
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 02:53 Go to previous messageGo to next message
fade-e wrote on Wed, 05 January 2005 03:40
Very Happy
my dads datsun 1200 ute has like 40 degrees play and when u go down the highway at 90 km/h Razz it wanders all ova the road No No No No No No even while u have the steering wheel tight in your grasp
brett
fade-e
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 07:56 Go to previous messageGo to next message
yeah i get that, when people jump in the car with me and im always turning the steering wheel they all freak out Laughing
ChuckLandwehr
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 11:15 Go to previous messageGo to next message
You guys obviously do not have annual rego inspections, or you have found some real dodgy guys to pass your cars. Steering with that much play, is dangerous!
regards Chuck.
brett_celicacoupe
townsville NQLD
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 12:29 Go to previous messageGo to next message
ChuckLandwehr wrote on Wed, 05 January 2005 22:15
regards Chuck.
no annnual inspections in queensland Razz so once the car is registered it is neva checked again, apart from the occasional queensland transport mobile inspection vehicle doing the rounds.
i agree with u that it is very dangerous especially when u get blown across the road by an oncoming truck's wind Surprised but the dato ute aint my car so meh, not my problem
brett
fade-e
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 12:35 Go to previous messageGo to next message
well the steering does not get checked for rego. all the steering components are checked to ensure they are on right, no rust at those areas, tie rods, control arms and what not but they dont actually jump in and turn the steering and reject it cause the wheels dont turn how they want.
also unless your a specialist in toyotas how would you know what the play from factory is. i found out the play values from a guy who works for toyota and loves the cars. Like Rod (thetoyman75) he knows practically everything bot them too
besides when you are aware of an imperfection in your car then you know what to do in certain situations. like the truck for example, when i see one coming past or what ever i already know whats going to happen so i am prepared for it
ozboy
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 13:30 Go to previous messageGo to next message
Im interested in converting my TA22 to rack and pinion any tech articles on this or can any one give me advice ive alredy searched but nothing clear came up.
Hodgie
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 13:39 Go to previous messageGo to next message
I found a few things about the rack and pinion conversion using the search function, not much though. Under keywords type "rack and pinion" or "Mazda 323". Hope this helps.
ozboy
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 13:49 Go to previous messageGo to next message
just tried both only found ra28 and ke30 stuff nothing for my poor little 22 thanx any way
fade-e
Re: TA22 Reconditioned Steering Boxes Wed, 05 January 2005 15:04 Go to previous messageGo to next message
joel (TurboRA28) has rack and pinion on his car probably give him a PM and he could be able to guide you. also in members rids i believe under joels thread there are pics and some details bout his conversion... though the wheel bases are different between a '22 and his car
in regards to Mazda 323 apparently the wheel base is almost identical and would be the easiest conversion for rack and pinion in a '22. the only problem there is that i dont know what model 323 it is. if you can get your hands on 323 data sheets and find the one with a rack and pinion setup and the closest wheel base to the '22 then thats the one you want
hope this helps you out a bit
ra23celica
Re: TA22 Reconditioned Steering Boxes Thu, 06 January 2005 00:03 Go to previous messageGo to next message
As far as I remember, the Mazda 323 you want is the original late 70's one, I think 78-80 the rounder one, before they became angular and were shared with Ford as Lasers.
And, has anyone checked with Fulcrum Suspensions to see if they still do recond. steering boxes ?
Mitch.
riceburna73
Re: TA22 Reconditioned Steering Boxes Thu, 06 January 2005 04:00 Go to previous messageGo to next message
how big a job is it to do this rackn pinion set up,as I am doing the missus box, cough...steering box this weekend and will wack the rNp in instead if i can do it in a weekend??
fade-e
Re: TA22 Reconditioned Steering Boxes Thu, 06 January 2005 04:13 Go to previous messageGo to next message
i doubt a weekend is enough. first you gaoot get the RnP, measure it up, fabricate a seat for it to sit on that would more than likely be welded to the engine cross member, get it sitting at the right height and in the right position, then get tir rod ends to suit the RnP and the steering arms on the control arms, then theres the fabrication of a rod with uni joints to bolt on to the steering column
so f you have a welder and all the parts then for sure you can do in a wekend otherwise NOT
riceburna73
Re: TA22 Reconditioned Steering Boxes Thu, 06 January 2005 04:17 Go to previous message
cool,I have my trusty welding buddy over for the weekend but the rest...oh well,i might just wait and do it to the blue one instead...
Previous Topic:Sticky Windows
Next Topic:Car Offsets and PCDs...
Current Time: Fri Nov 20 09:00:28 UTC 2026
Total time taken to generate the page: 0.0067009925842285 seconds
