Toymods » Tech & Conversions » AE82 problems, please help!!!
GEE120
AE82 problems, please help!!! Sat, 19 October 2002 12:27 Go to next message
Posting this for a mate, PLEASE HELP...
I own a 1988 Corolla SX AE82 model which has a problem of stalling when I pull up to traffic lights, etc. Several different mechanics don't have a clue and Im getting pretty pissed off with it. After driving around for 10-15 minutes the idle slow goes down from around 1000 rpm to about 600 rpm. After this, everytime I pull up to a set of traffic lights, a drive way or whatever & put the clutch in it stalls. It even happens when your reversing after its warmed up. This happens on occassions. It seemed to occur more often after I got rid of the factory air filter for a Rush O2 filter.
They've looked at the temperature and air flow sensors and also the idle system (manual/computer???) and maybe more but I cant remember.
Any help will do as summers coming and the days are getting hotter and it gets worse and annoying to drive.
Thanks.
Confused Mad
Bounty
_Sydney _
Re: AE82 problems, please help!!! Sat, 19 October 2002 12:38 Go to previous messageGo to next message
sounds like ur just sucking in to much hot air put back the stock air box. all i can sugest
SW20R
Re: AE82 problems, please help!!! Sat, 19 October 2002 12:45 Go to previous messageGo to next message
Give the throttle body a clean..
could be any of these..?
Vaccum leak?
Sparks?
Injectors dirty?
Timing could be out?
fan belt is slipping?
SW20R
Re: AE82 problems, please help!!! Sat, 19 October 2002 12:47 Go to previous messageGo to next message
to much hot air?
my pod is sitting right ontop of the gearbox.. in the middle of the engine getting heat..
Though i've taken off the bottom shields to draw in air from below.
for some reason mines rises in rpm as it gets hotter
GEE120
Re: AE82 problems, please help!!! Wed, 23 October 2002 03:05 Go to previous messageGo to next message
Thanks for the suggestions so far. Much Appreciated.
Has anyone got any other suggestions that might help
AE82TwinCam
Canberra, ACT
Re: AE82 problems, please help!!! Wed, 23 October 2002 08:27 Go to previous messageGo to next message
make sure alternator is producing enough voltage... I had a similar problem when my alternator started to die on my old 4age.. I doubt that will be it but hey, you never know
-Andrew
[Updated on: Wed, 23 October 2002 08:30]
Rolla Boy
Club Member
Sydney, NSW
Re: AE82 problems, please help!!! Fri, 25 October 2002 17:09 Go to previous messageGo to next message
AE82's and AE92's have the problem of low reving when the radiator is not totally full to the brim... Something happens when there is air sitting in the top of the radiator (Inside of course)... It just doesn't like it for some reason...
EvilJack
Sutho/Hills NSW
Re: AE82 problems, please help!!! Sat, 26 October 2002 01:27 Go to previous message
my gf had the same sorta problem last nite in her ae71, it was just a lose spark plug. try checking them.
Previous Topic:2T-GEU - Need Help....
Next Topic:ta22 carbs and sway bays
Current Time: Sat Nov 21 06:56:00 UTC 2026
Total time taken to generate the page: 0.0054059028625488 seconds
