Toymods » Tech & Conversions » Adjustable FPR's
mikey93
Adjustable FPR's Wed, 05 January 2005 20:03 Go to next message
Just scored myself an adjustable FPR off ebay upto 80psi.. figured my one would need changing.
It includes a gauge so it might be helpful.
Just wondering what settings should they be on for a forced motor. I was thinking between the lines of 44-48psi.
Even though its not a rising rate FPR.. Im going to try and counter the leaning out at top end.
Current A/F ratio is 12.0 at idle. and Rises to 14.3 At redline.
If i bumped it up a few psi to possibly get it to 10.5/11 A/F at bottom end.. would this help the top richen up due to more fuel?
assassin10000
Sacramento, CA (USA)
Re: Adjustable FPR's Wed, 05 January 2005 20:24 Go to previous message
I'd recommend starting at factory and just upping it 1lb at a time until you get the results you want, I just wouldn't try and go above 52-55psi. Because the higher the fuel pressure, the less actual fuel the fuel pump can provide.
I don't know if you're factory FPR is boost sensitive, for some reason some of the toyota's are, and you basically can get a free 1:1 FMU. Search google/yahoo for "Free FMU" to get how to hook it up - you'll need a fuel gauge to see if it works though. It's very commonly done on the TRD Supercharged Tacoma's (Hilux) here in the states Smile
If you have an upgraded fuel pump I wouldn't be worried. If you don't you'll want to keep an eye on EGT's and the A/F ratio.
12.0 at idle? thats really rich for idle... and 14.3 is way too lean for full throttle/redline (max power is usually found in the range of 11.5-13.5:1 - and also depends on what you're internals can handle, if egt's climb could toast your pistons)
Previous Topic:RA28 motors
Next Topic:AE86 Jap and Aus spec tanks
Current Time: Wed Nov 4 02:58:35 UTC 2026
Total time taken to generate the page: 0.012547016143799 seconds
