Toymods » Tech & Conversions » 1JZ PCV Valve Diff
Skip
1JZ PCV Valve Diff Thu, 06 January 2005 00:05 Go to next message
Have 2 engines 1 has a straight PCV valve the other has 90 degree bent one, whats the diff? Both engines are soarer type.
Also after hard boosting my first engine would blow that wiff off white smoke out the exhaust. When i put the second engine in the car I swapped over inlet manifolds due to sensors etc. therefore keeping the old PCV valve (straight one). The new engine is also doing the same (white smoke) so i pulled the PCV valve off last night. It would seem i couldnt blow into it which is good, but then i put my finger over the end and blew into it, leaving my mouth on the end i could hear and feel a puff off air coming out when removing my finger. Sound stuffed? BTW when i do the same to my other 90 degree one yet to be tested on the car it does not do this.
Manny
Re: 1JZ PCV Valve Diff Thu, 06 January 2005 10:56 Go to previous messageGo to next message
Toyota revised the PCV design midway through the TT 1JZ production, it's a generic Toyota part used across various models - I had similar issues with my PCV leaking; PCV would appear to be stuffed, swap them over and you should be fine.
Chris Davey
sunny coast, qld
Re: 1JZ PCV Valve Diff Thu, 06 January 2005 11:32 Go to previous messageGo to next message
skip: you wouldn't be able to get a photo of the two for future reference would you?
Skip
Re: 1JZ PCV Valve Diff Thu, 06 January 2005 23:29 Go to previous messageGo to next message
Thanks Manny
Swapped PCV's over last night but still white smoke continues Sad
Will start a new thread on my smoking addiction
Chris: Yer i can do that.
Chris Davey
sunny coast, qld
Re: 1JZ PCV Valve Diff Fri, 07 January 2005 02:53 Go to previous message
thanks skip Smile
Previous Topic:which engines run DLI (waste spark) ignition?
Next Topic:Running in a new motor
Current Time: Fri Oct 16 13:05:02 UTC 2026
Total time taken to generate the page: 0.0055339336395264 seconds
