Toymods » Tech & Conversions » 1uz on microtech miss
1uz on microtech miss Thu, 06 January 2005 02:14 Go to next message
My 1UZ has a constant miss (ie, its not intermittant)
When cold it happens from 3200 to 3500.
When hot it happens at almost exactly 3500.
Does not happen under light throttle.
Only happens for a split second, then continues fine to redline.
Only just started happening.
When it happens the tacho (autometer) drops 500-1000rpm then continues.
Pretty much happens every time, in every gear.
Thoughts?
Its running an LT8S btw.
My tuner is booked out for a few weeks, so I can't get him to look at it.
Nothing in the engine bay has been touched.
All I have done is reduce the idle speed from 1300 to 750, and played with the idle timing/fuel.
EDIT: The fuel has been in the tank for 6 weeks, so this *could* be it.
Am going to fill up with new fuel tonight.
[Updated on: Thu, 06 January 2005 02:16]
..J..
opening a can of whoop ass
Re: 1uz on microtech miss Thu, 06 January 2005 05:08 Go to previous messageGo to next message
are you sure when you played with the idle timing and fuel you have pulled the equilent out of the rest of the tune? seems funny how its happening now.
on the other hand i think its rude for the tuner to say cant help for two weeks, have you suggested maybe taking him for a road tune for 5 mins?
good luck with it.
Re: 1uz on microtech miss Thu, 06 January 2005 05:13 Go to previous messageGo to next message
I'm pretty sure it hasn't touched the rest of the tune, but I will put it back to about where it was, see if it makes a difference.
I doubt it will though.
Tuner hasn't told me he can't help, I just can't book the car in for 2 weeks.
I might just 'drop in' tomoz and see if he can look at it like you suggested.
Its hard for me to get him the car during the week, and like most places, he's booked solid on saturdays.
Skip
Re: 1uz on microtech miss Thu, 06 January 2005 08:26 Go to previous messageGo to next message
Can you data log with that thing?
Re: 1uz on microtech miss Thu, 06 January 2005 08:28 Go to previous messageGo to next message
Skip wrote on Thu, 06 January 2005 16:26
Ummm, to an extent I think I can.
Never used it tho.
You suggesting I see what the injector pulses, timing and the like does around the miss?
Re: 1uz on microtech miss Thu, 06 January 2005 08:32 Go to previous messageGo to next message
Quote:
Data Logging
Onboard "ECU-log" holds 5mins of memory.
User definately switching on and off point.
Data Log to memory (laptop) 100 samples per seconds
Viewed data log displays average readings 10 times per second
Data log viewable in text or graph
Playback data log
Print data log
Save data log to disc
Sounds like I can, now I just gotta find out how to use it.
Re: 1uz on microtech miss Fri, 07 January 2005 00:32 Go to previous messageGo to next message
Driving around the car last night and it feels like the timing retards around 5-10 degrees @ 3500rpm.
Haven't had the laptop out yet to see what is happening, but you can feel a loss of power at those revs.
Skip
Re: 1uz on microtech miss Fri, 07 January 2005 01:37 Go to previous messageGo to next message
Datalog the biatch!
Im positive you will find the problem in that area, check for rapid RPM fluctuations etc.
Re: 1uz on microtech miss Fri, 07 January 2005 11:03 Go to previous messageGo to next message
Well, after datalogging it, I can't really see any issues.
It was only up and down the street, but the car did its thing.
However, the injector pulse seems to drop at about 3500 upwards.
Might need to do a longer run.
Re: 1uz on microtech miss Sat, 08 January 2005 03:43 Go to previous messageGo to next message
Spoke to my tuner, and showed him this
http://www.conceptual.net.au/~peewee/2ndgear_datalog.jpg
That was 2nd gear, pulling from 20ish kph to redline (100ish kph)
Tuner couldnt see anything wrong with it.
He suggests that my fuel pump is wearing out and can no longer cope with the required output.
I suppose 240,000km's of 5mge and a sudden rush of 1uz could kill it.
Sounds like its Walbro time!
[Updated on: Sat, 07 May 2005 05:08]
Skip
Re: 1uz on microtech miss Sat, 08 January 2005 05:48 Go to previous messageGo to next message
Yeah looks okay, wild RPM fluctuations can signify electrical interference with your crank angle sensor wires which could cause problem like you suggest but rpm is fine. Yeah fuel pump could be a definite candidate, have you checked the filter?
Re: 1uz on microtech miss Sat, 08 January 2005 05:53 Go to previous messageGo to next message
Filter is brand new, like 3000km old.
Re: 1uz on microtech miss Sat, 08 January 2005 06:09 Go to previous messageGo to next message
are you sure the TPS is OK? or are you letting your foot off as the engine falters?
if you're simply depressing it down and the engine stumbles at circa 3k rpm then why does the TPS suddenly drop to 0%?
if the pump wasn't up to it, you'd think that any fuel consumption over/above the stumble point woudl be just as bad - an AFR log would show up any lack of fuel (e.g. will run lean above stumble point)?
cheers, charles.
Re: 1uz on microtech miss Sat, 08 January 2005 06:12 Go to previous messageGo to next message
thechuckster wrote on Sat, 08 January 2005 14:09
I changed from 1st to 2nd Rolling Eyes
Yeah, it would be the best way to test it, but lack of wideband o2 sensor doesn't help.
Re: 1uz on microtech miss Sat, 08 January 2005 06:41 Go to previous messageGo to next message
if you're flooring it (WoT) during the run to redline, then engine should be rich - even a narrowband O2 sensor will tell you that.
if the fuel pump is off, then it will be lean above the stumble point?
i'd suggest another run monitoring AFR (even if it's just narrowband)? can you get it to plot basic timing and any retard/advance that the ECU is applying to the base timing map?
you had timing issues previously? or was that due to wiring issues from the initial installation?
cheers, charles.
Re: 1uz on microtech miss Sat, 08 January 2005 06:52 Go to previous messageGo to next message
No idea what caused this, I only just noticed it earlier in the week.
Narrowband o2 wont be able to help, resolution is not good enough.
I doubt its lean over 4k, I'd just say its not a 12.0:1 like it should. Prolly up closer to 14:1
Re: 1uz on microtech miss Sat, 07 May 2005 05:13 Go to previous messageGo to next message
Just a follow up post to say that I just fixed it.
Turns out the Crank Angle Sensor was wired backwards, which I'll go to my grave saying is something I have tried before. Embarassed
But I just played around with the cam and crank angle sensor wires in every combination possible (there is only 4, was already running one, and it wouldnt start with 2, which left the last one to be perfect)
So if anyone ever gets an RPM ERROR on a Microtech, its the cam or crank angle sensor backwards.
takai
Re: 1uz on microtech miss Sat, 07 May 2005 07:11 Go to previous message
Hahaha, so yours as well.... seems to be common. When my car first went for its tune the tuner couldnt figure out why the ignition wasnt working properly (happened to be a bullet connector loose) so he fiddled with the CAS wiring, and it always ran weird below 3000ish, with frequent backfires etc.
When i finally got it retuned we found out that the CAS was wired in backwards (theoretically it shouldnt work). After rewiring the CAS it was fine again (until it flamed out.)
Previous Topic:5k Engine with SC14
Next Topic:need help ??? wired noise in gearbox
Current Time: Thu Nov 19 06:48:45 UTC 2026
Total time taken to generate the page: 0.038100004196167 seconds
