Toymods » General Car Talk » Charge light
Guest
Charge light Sun, 20 October 2002 02:44 Go to next message
The charge light on my car flashes while the car is running. If I rev above say 3000 the light stops flashing.
I am thinking that the belt is worn, or something but I'm not keen on pulling the whole lot out as it is the back belt and I have to take off 2 others to get at it!
Am I right?
[Updated on: Sun, 20 October 2002 02:44] by Moderator
frebbles
Re: Charge light Sun, 20 October 2002 03:14 Go to previous messageGo to next message
By "Charge Light" i assume you mean the little battery logo thing.
This is to say that the battery is discharging, I.E. There is more power being taken from the battery than going back into it.
This is why they come on when you turn the key "on" but the engine isn't running, cos there is no means of charging the battery.
Which in turn means soon you might end up with a flat battery...Could be a belt slipping, alternator failure, or some wiring defect somewhere, a multimeter and someone with an idea of electronics should be able to find where the fault may lie. Could be a dead battery too...
Apollo
Brisbane, QLD, Australia
Re: Charge light Sun, 20 October 2002 04:12 Go to previous messageGo to next message
Must be that massive stereo you put in without adding a larger battery to handle it. Wink
You would tend to hear a slipping belt, they tend to make sounds like your engine is seizing, (very loud squeals). Take it to a battery place for a test, or call the racq man if you don't want the battery place to hard sell you a new battery.
Also, how old is the battery? If it's ~4 years, then you've done well and need a new one.
But in any case, be prepared to buy a new battery for worst case scenario.
GIN51E
Berowra-Sydney
Re: Charge light Sun, 20 October 2002 04:23 Go to previous messageGo to next message
remember to check water levels in the battery
Guest
Re: Charge light Sun, 20 October 2002 09:48 Go to previous messageGo to next message
Well, I'm pulling it apart tomorrow morning...
I'll start by running a new earth from the battery, and a new cable from the alternator, clean terminals etc. Then see if it makes a difference. Then pull off the belts, check them out as you can't see them too well with 2 belts in front of it! A new belt can't be that expensive so I'll put one on...and see if that fixes it! Then if all else fails I'll look at getting a new alternator.
Water levels are fine and has just been charged with no difference. The battery came with the car so... Rolling Eyes I have no idea how old it is. But it doesn't look that old, I could try my boyfriends 500CCA one that is only 6 months old, that might work!
PS. I have to empty the radiator to get the belts... that is going to piss me off!
Guest
Re: Charge light Tue, 22 October 2002 07:20 Go to previous messageGo to next message
All fixed.
It was the regulator, somehow water got into it and fried everything!
Mind you, that was after I replaced the alternator, but the guys at the wreckers gave me the regulator for nothing! So in the end it only cost me $38.50 and a few hours.
Rolla Boy
Club Member
Sydney, NSW
Re: Charge light Wed, 23 October 2002 05:49 Go to previous messageGo to next message
Always remember to top up batteries with distilled water, NOT tap water... Tap water reduces the life of batteries...
Re: Charge light Wed, 23 October 2002 06:13 Go to previous messageGo to next message
i like to use 2 molar sulfuric acid to top up batteries hehehe
Guest
Re: Charge light Wed, 23 October 2002 06:55 Go to previous message
Ok, and you got sulphuric acid from the local supermarket?
Anywayz, it wasn't the battery in the end.... water got into the regulator and rusted / fried everything! It was a nice brown colour Rolling Eyes
[Updated on: Wed, 23 October 2002 06:56] by Moderator
Previous Topic:Project 22 progress pics
Next Topic:??? Dr 20v ???
Current Time: Fri Nov 20 13:51:08 UTC 2026
Total time taken to generate the page: 0.0088150501251221 seconds
