Classifieds » Wheels, Tyres, Suspension and Brakes » Wheel compatibility?
Akina_HachiRoku
Wheel compatibility? Thu, 06 January 2005 23:58 Go to next message
I just need some expert advice.
I currently have an ae82 hatchback and I would like give her a face lift, so I'm considering purchasing her a new set of boots.
So at the moment she is got the stock 13" wheels and I'm interested
in a set of 205/60/R15 4 X 114.3 which came of a 90' model silvia.
Just wondering will these wheels fit on to my ae82?
If not, can you please tell me which wheel arrangement will be better suited to my ae82?
[Updated on: Fri, 07 January 2005 04:28]
deltathing
adelaide
Re: Wheel compatibility? Fri, 07 January 2005 00:20 Go to previous messageGo to next message
those wheels will be a bit of a tight fit on an ae86, for that width of tyre the offset will mean it will sit very close to the strut. im assuming the ofset is +20something if it is off a silvia. but yeah correct me if im wrong.
umm btw do you have an ae86.. ae82 or both>?
because ae82 are 4x100pcd so the rims will not fit.. at all
unless you weld them to the hub, which by the way was a joke. please dont try it.
fergo308
Eastern Sydney
Re: Wheel compatibility? Fri, 07 January 2005 07:57 Go to previous messageGo to next message
where did you get the idea he has an ae86? he says twice in his post that he owns an ae82...
as said,an ae82 runs a 4/100 PCD. S13 silvias runs 4/114.3mm PCD,so the rims will not even come close to bolting on.
the offset would be similar though.
the tyres are too tall as well. you'd want a 205/50/R15 for your corolla.
if you're browsing silvia forums for wheels,try for something that's multistud,as it's likely that both of the above PCD's will be the ones drilled into the wheel.
Justin...
deltathing
adelaide
Re: Wheel compatibility? Sun, 09 January 2005 02:48 Go to previous message
umm maybe because it was written there before he EDITED the post
and that his name is AKINA HACHI ROKU...
Previous Topic:3S exh. manifold plates, moved to engine..
Next Topic:FOR SALE: 14" x 6.5" STUD MAGS
Current Time: Thu Oct 22 05:03:39 UTC 2026
Total time taken to generate the page: 0.011415004730225 seconds
