Classifieds » Wheels, Tyres, Suspension and Brakes » +++++Sold+++++
bbaacchhyy
+++++Sold+++++ Fri, 07 January 2005 02:43 Go to next message
Hiya all,
Having a major shed cleanout and stumbled across this hidden away.
Basically it is a Full Floater diff setup from an RX7 Improved Production race car. It does not have a centre, but comes with 3 axles (one has a bit of twist in the splines - maybe 5 degrees), has small solid discs fitted (about 230mm maybe ?) and has about a degree of neg camber in the housing.
I bought it with the option of trying to fit it into my RX2 that I had at the time, but that never eventuated.
Considered a MUST HAVE for any real high performance beam axle car.
It came from SelectMaz, and at the time was surplus to their requirements.
It is now surplus to mine (MA61's are IRS, so hence are already full floaters..), and whilst the housing is not Toyota, the end hubs can be adapted, and new axles made if required.
Anyone interested ?
I can diasassemble the housing and supply only the hubs if anyone is interested
Other than that it is going to the dump
I will accept any reasonable offer (meaning bugger all compared to what it is worth)
Michael Bachmann
042 111 9249
[Updated on: Mon, 17 January 2005 01:33]
bbaacchhyy
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Sat, 08 January 2005 03:28 Go to previous messageGo to next message
Ok, here are some details as promised for those that have shown interest.
Specas are :
12mm studs with a stud pattern of 4 x 110mm
Discs are 240mm dia x 10mm thick (solid)
Overall flange to flange width is 3190mm Rolling Eyes 1500mm is correct (approx)
Axle length is 1760mm Rolling Eyes 760mm is correct
Axle minor dia is 25mm (approx)
Spline OD is approx 28mm and 28 spline
Floater hubs bolt on to axle housing and are 110mm long each side
Edit : Corrected above dimensions Embarassed
RH End Housing/Floater hub ;
http://img30.exs.cx/img30/4658/200501081209xu.jpg
RH End Housing/Floater hub drive plate ;
http://img30.exs.cx/img30/9186/200501081218rk.jpg
RH End Housing/Floater hub drive plate & axle ;
http://img30.exs.cx/img30/6012/200501081226hh.jpg
Housing overall ;
http://img30.exs.cx/img30/3144/200501081243xe.jpg
Axle splines showing the axle with a slight twist ;
http://img30.exs.cx/img30/6867/200501081261bq.jpg
There have been a few peple expressing interest, and in order they are ;
Terry O'Bierne
taylz
Chris (phone contact)
Have a look at the pics and best bid wins ?
Michael B
[Updated on: Tue, 11 January 2005 10:38]
TerryOBeirne
Redbank Plains,near Ipswi...
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Sat, 08 January 2005 04:40 Go to previous messageGo to next message
thanks Michael for the pics, what a strange arrangement., they have bolted the floater kit onto a stock RX7 axle to get a wider track. I'll look into it over the week-end and get back to you. thanks. terry
bbaacchhyy
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Sun, 09 January 2005 21:09 Go to previous messageGo to next message
Yes it is a bit odd, but it seems to work OK, and helps increase track without getting wierd offset rims !!!
Any offers ?
It is going to the dump this Saturday if not offer materialises....
Michael B
TerryOBeirne
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Tue, 11 January 2005 07:59 Go to previous messageGo to next message
I'll try to get back to you tomorrow after I measure up a diff I have lying at work. definintely interested & can make offer. cash ready
bbaacchhyy
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Tue, 11 January 2005 10:35 Go to previous messageGo to next message
In a moment of dyslexia, I wrote the dimensions wrong. Corrected at the top of the thread.
Thanks Terry, awaiting offer from yourself and one other
MB
dave368
Canberra, ACT
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Tue, 11 January 2005 11:25 Go to previous messageGo to next message
Email sent.
bbaacchhyy
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Tue, 11 January 2005 21:28 Go to previous messageGo to next message
dave368 wrote on Tue, 11 January 2005 21:55
Email sent.
Email rec'd.
Best offer so far is $200 + freight.
Best offer by Friday takes it. It will be sold !!!!!
TerryOBeirne
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Thu, 13 January 2005 07:53 Go to previous messageGo to next message
I'll send my offer to you fiday (I promise), flat out 18hrs/day at work. terry
bbaacchhyy
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Thu, 13 January 2005 21:20 Go to previous messageGo to next message
TerryOBeirne wrote on Thu, 13 January 2005 18:23
Know what it is like at the moment. The main lines are in the middle of commisioning !!!
bbaacchhyy
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Fri, 14 January 2005 04:49 Go to previous messageGo to next message
Rob has the bid at $250.
I'll stop it at 5pm, so whomever is highest gets it.
Any otehr enquiries, call me on 042 111 9249.
Rob, PM me or SMS me your number so that I can contact you
Michael B
bbaacchhyy
Re: FS : Full Floater Diff/hubs - Going cheap or to the trash..... Fri, 14 January 2005 20:19 Go to previous message
OK, Rob (alias Sharpie) has it. Will ring you later on today (Saturday) to pick it up this weekend.
If that fails, then it goes to Terry OBierne
Michael bachmann
Previous Topic:Potenza Gymkhana rear shocks for ae86 and other stuff
Next Topic:JZZ30 Soarer Brakes, Rack etc.
Current Time: Wed Oct 21 03:42:49 UTC 2026
Total time taken to generate the page: 0.091191053390503 seconds
