Toymods » Tech & Conversions » Why you cant rebuild your AE86 T50 with TE72 internals
Henn
Rosanna, Melb
Why you cant rebuild your AE86 T50 with TE72 internals Fri, 07 January 2005 04:32 Go to next message
Now I assume everyone knows the external differences between AE86 T50s and TE72 T50s (input shaft bearing, bellhousings wont swap, output spline number).
Given I have a AE86 box with teeth off second gear and a really good TE72 box lying around I decided to strip them both and rebuild the AE86 box with the good internals.
There are a few minor internal differences, but nothing seemed insurmountable until I found two things:
- The hole in the TE72 5th gear is smaller than the AE86 output shaft and so wont fit on the right spot. Quick solution, use the AE86 5th gear.
- The hole in the centre of the TE72 second gear is about 1mm larger in diamter than the corresponding place on the AE86 output shaft, meaning it'd slap around.
Since my AE86 2nd gear is rooted the project ended there. Everything else seems possible to switch over.
Hen
toyoda
Re: Why you cant rebuild your AE86 T50 with TE72 internals Fri, 07 January 2005 04:49 Go to previous messageGo to next message
Henn,
You would seem to have an early TE72 Box.
According to my info the TE72 between 8106 - 8305 is exactly the same part Number for the 2nd Gear.
Failing that - you could always donate the AE86 Box to me Laughing Laughing Laughing
Toyoda ( senior Very Happy )
[Updated on: Fri, 07 January 2005 04:55]
Henn
Rosanna, Melb
Re: Why you cant rebuild your AE86 T50 with TE72 internals Fri, 07 January 2005 05:07 Go to previous messageGo to next message
That's very interesting, unlucky I had the old box.
And yes, I now have the entirity of both boxes sitting around in very neatly labelled sandwich bags, so if anyone could use bits please PM me.
Hen
IRA11Y
Club Member
Re: Why you cant rebuild your AE86 T50 with TE72 internals Fri, 07 January 2005 06:03 Go to previous messageGo to next message
hmm shame your so far away, ive got two boxes here that ive been planning to do the same test project on but havent pulled finger and stripped them to check if the ratios will interchange. been meaning to go get some syncros and start the rebuild for 12 months Smile
Any chance you could take some pics??
im trying to do mine opposite to you, take the AE86 internals and swap them into the TE as I have a good AE box and a slowly dying TE
[Updated on: Fri, 07 January 2005 06:06]
Re: Why you cant rebuild your AE86 T50 with TE72 internals Fri, 07 January 2005 13:29 Go to previous message
Hmmm, I've got a TE71 2TG box that's in good order, and an AE71 box in my KE70 that's gradually not liking my treatment. I'll be interested to know the possibilities!
Previous Topic:how much CCA's is enough for a gze.
Next Topic:R154 into JZA80 2JZ-GE?
Current Time: Thu Oct 22 10:52:03 UTC 2026
Total time taken to generate the page: 0.0083739757537842 seconds
