Toymods » Tech & Conversions » SWAYBARS....................................
FLY PSI
icon4.gif  SWAYBARS.................................... Sun, 20 October 2002 09:01 Go to next message
I have an AE71 Rolla, Its been lowered 65mm with Kmac springs,and has munro Gas shocks fitted. I will be doing an engine swap to a 4AGZE and was woundering what size swaybars i should fit? I drift the car Very Happy so i was wanting a good setup to suit.
I also use the car as a daily driver
any help is much appreciated Smile
Re: SWAYBARS.................................... Sun, 20 October 2002 10:44 Go to previous messageGo to next message
First up, do you 'dorift maaaaate' the car or DRIFT the car?
Re: SWAYBARS.................................... Sun, 20 October 2002 10:53 Go to previous messageGo to next message
A 40 mm rear sway bar should just about do it. Rolling Eyes
ed_ma61
Lost in the K hole
Re: SWAYBARS.................................... Sun, 20 October 2002 11:19 Go to previous messageGo to next message
40mm rear!!??!!
with a stock 22mm front, yeah, that should get the back end happening.... Rolling Eyes
ed
Re: SWAYBARS.................................... Sun, 20 October 2002 11:34 Go to previous messageGo to next message
What the hell, just ditch the shocks, replace them with steel bars to attach the rear end solid to the car...
Karl_skewes
New Zealand
Re: SWAYBARS.................................... Sun, 20 October 2002 11:43 Go to previous messageGo to next message
just get one from whiteline, don't forget you'll need all the brackets to mount it as well, and I'm not sure if your diff housing has the mounts for the swaybar.... so these may need to be welded on.
If you do have an existing swaybar, get another off an ae85 or something and hoseclamp it together... add as many as you think is driveable... 2 seems to do the trick.
ed_ma61
Lost in the K hole
Re: SWAYBARS.................................... Sun, 20 October 2002 12:01 Go to previous messageGo to next message
damn karl, thats the most sensible idea ive ever heared wrt swaybars. sure, eventaully, probably more correct to get a single bar made to spec, but addition of bars is a great idea! esp if youre playing with setup etc and arent quite sure what you need, or what will work.
ed
FLY PSI
Re: SWAYBARS.................................... Sun, 20 October 2002 12:44 Go to previous messageGo to next message
Karl_skewes wrote on Sun, 20 October 2002 21:43
I might just try that :)As i have a spare AE71 which im wreaking at the moment and it does have a rear swaybar standard.
can anyone recomend a size for the front? Or is the standard one good enough?
I also want it to handle alright and not just go sideways Very Happy Very Happy
i will be gettin a pair of swaybars made to spec when i know what setup is best
Re: SWAYBARS.................................... Sun, 20 October 2002 12:57 Go to previous messageGo to next message
FLY PSI wrote on Sun, 20 October 2002 22:44
Something about cake and not being able to eat it comes to mind.
[Updated on: Sun, 20 October 2002 12:58]
FLY PSI
icon4.gif  Re: SWAYBARS.................................... Sun, 20 October 2002 13:13 Go to previous messageGo to next message
what i ment by that comment was that if i just want to drive it normally, i dont want the car trying to step out on me Shocked as i dont want to cause an accident when im driving in traffic Sad
Re: SWAYBARS.................................... Sun, 20 October 2002 13:55 Go to previous messageGo to next message
Well assuming that theory of taking diameter to the power of 4 works, then my 19mm one is a fair bit healthier than the stocky 12mm one - which looks like some kind of dental floss accessory. I can probably suggest you try the KMAC 19mm one, worked fine for me. Oh, and ditch the monroe shocks too!
FLY PSI
icon4.gif  Re: SWAYBARS.................................... Sun, 20 October 2002 13:59 Go to previous messageGo to next message
mrshin: the shocks came with the car :)and at $300 i cant complain Very Happy i was thinking of swaping them down the track. can you recomend some good ones that arent too expensive.
i used peddars in my ET Pulsar and they are great.
Karl_skewes
New Zealand
Re: SWAYBARS.................................... Sun, 20 October 2002 20:39 Go to previous messageGo to next message
Run a bigger one on the front, whiteline replacement.
You'll find running 2 on the back you will get no understeer. And it won't be very neutral unless you upgrade the front.
Re: SWAYBARS.................................... Sun, 20 October 2002 22:34 Go to previous message
Guess if you don't want to spend too much, try the peddars, otherwise go for Koni or similiar
Previous Topic:This turbo OK for my 4AGTE?? (NOW WITH PICTURES)
Next Topic:Piggyback ECU's
Current Time: Thu Nov 19 06:29:49 UTC 2026
Total time taken to generate the page: 0.0064289569854736 seconds
