Toymods » Tech & Conversions » 550cc injectors out of which lexus for 7m bolt in?
SUPRAGTE
North Sydney
icon5.gif  550cc injectors out of which lexus for 7m bolt in? Sun, 20 October 2002 09:41 Go to next message
Anyone know exactly which engine has the "Reimer upgrade lexus injectors, the 550cc ones that bolt straight into the 7m rail?
stevevp
Brisbane Qld
Re: 550cc injectors out of which lexus for 7m bolt in? Sun, 20 October 2002 10:09 Go to previous messageGo to next message
unfortunately none of them.
The Lexus part of the upgrade is the air flow meter, the injectors are aftermarket items.
Re: 550cc injectors out of which lexus for 7m bolt in? Sun, 20 October 2002 10:13 Go to previous messageGo to next message
Lexus injectors are actually around 250 cc. But here is a helpful link. I think you want some RX7 ones.
SUPRAGTE
North Sydney
Re: 550cc injectors out of which lexus for 7m bolt in? Sun, 20 October 2002 10:29 Go to previous messageGo to next message
Kewl, thanks for that. Plenty of info on that site. Smile
Might have to go for some RC ones if no-one out there has any, anyone got any they would like to sell?
TE72_Turbo
Re: 550cc injectors out of which lexus for 7m bolt in? Sun, 20 October 2002 11:11 Go to previous messageGo to next message
the 7M injectors are o-ring type arent they? could you then use mazda series 4/5 RX7 injectors, they are 550cc high impedance.
mx83toy
Re: 550cc injectors out of which lexus for 7m bolt in? Sun, 20 October 2002 12:02 Go to previous messageGo to next message
after market sard ones are about 240 from memory each
ed_ma61
Lost in the K hole
Re: 550cc injectors out of which lexus for 7m bolt in? Sun, 20 October 2002 12:11 Go to previous messageGo to next message
eBay
source of all things good. seen them regularly for ~US$200 for 6
ed
RiGo
Re: 550cc injectors out of which lexus for 7m bolt in? Sun, 20 October 2002 14:37 Go to previous messageGo to next message
ed_ma61 wrote on Sun, 20 October 2002 22:11
eBay
ed
The ones that go for this sort of money are generally high impedance Nippon Denso injectors. Altough they'll work, they are a little slower acting. Better to have low impedance injectors...
SUPRAGTE
North Sydney
Re: 550cc injectors out of which lexus for 7m bolt in? Mon, 21 October 2002 12:42 Go to previous messageGo to next message
Yeah, i'd prefer to get some low impedeance type ones, RC Engineering are selling them for $95US each! What a rort! I'll wait it out or temporarily put in an adjustable fuel pressure regulator and squeeze some more out of them.
Might try ebay, thanks ed.
mx83toy
Re: 550cc injectors out of which lexus for 7m bolt in? Mon, 21 October 2002 13:43 Go to previous messageGo to next message
fuel pressure regulator???
i don't understand the pupose of these to much, i had some one tell me they help with the tuning of the a/r ratios???
grande91
Re: 550cc injectors out of which lexus for 7m bolt in? Mon, 21 October 2002 15:16 Go to previous messageGo to next message
I got six RX7 low impendance 550's for $440 and than got them cleaned up for another $150 and they work fine on the 7mgte,...if you dont mind looking around you'll get'em for cheap...i got them from promaz,........ Sad Sad
ed_ma61
Lost in the K hole
Re: 550cc injectors out of which lexus for 7m bolt in? Tue, 22 October 2002 00:33 Go to previous messageGo to next message
mx83toy- fuel pressure regulator: higher fuel pressure = higher injector flow rate = more fuel per duty cycle
make it a rising rate regulator that goes up with boost pressure, and it makes a little more sense.
ed
K_Mart90
Minnesota, USA
Re: 550cc injectors out of which lexus for 7m bolt in? Wed, 23 October 2002 14:16 Go to previous messageGo to next message
The companies that I know of that make 550's that will fit the 7M are Nippon and RC. Also if you want to go even bigger, www.maxxautoworks.com sells 720's. They are based out of Seattle, WA area.
For the Lexus AFM, I have been able to get a couple here and there. I have one for sale on ebay right now. If anyone has 550's or 720's that would fit a 7m, we could work out a trade.
Usually 550's in the US go for $535usd new (all 6, RC) and then you have to get the wiring clips ($50 usd). I've seen used one go for $300+.
Kevin
SUPRAGTE
North Sydney
Re: 550cc injectors out of which lexus for 7m bolt in? Thu, 24 October 2002 12:41 Go to previous messageGo to next message
Think ill start giving all the rotor shops in Sydney a call and get some prices. Its annoying cause i just cleaned my 7MGTE ones only 3000kms ago. Didn't cost me anything anyways. Thanks Grande.
wil8115
Seattle area, USA
Re: 550cc injectors out of which lexus for 7m bolt in? Sat, 02 November 2002 04:59 Go to previous messageGo to next message
if you run the 440's at 60psi they will be approx 515cc and will handle approx. 445hp. For now run RRFPR while your looking for the 550's. And when they become not enuff up the FP again until even larger Iny's can be found... Evil or Very Mad
SUPRAGTE
North Sydney
Re: 550cc injectors out of which lexus for 7m bolt in? Sun, 03 November 2002 06:00 Go to previous messageGo to next message
Cheers mate, ill definitely be doing that in the short term.
Roughly 445hp is about what i'm aiming for at the flywheel. 380rwhp Smile
Danners
Central Coast, NSW
Re: 550cc injectors out of which lexus for 7m bolt in? Fri, 30 July 2004 08:18 Go to previous messageGo to next message
ooooold old thread here Smiley =
I'm in the process of doing the Lexus AFM + 550cc injectors job on my 7M and have just purchased a Walbro 255lph HP fuel pump. Will i need a fuel pressure regulator to go with it? If so what brand/model would people recommend I go for? Paul i notice you're using the Malpassi rising rate model? Can i ask where you purchased it from?
Thanks Very Happy
Dan
Re: 550cc injectors out of which lexus for 7m bolt in? Fri, 30 July 2004 10:23 Go to previous messageGo to next message
Your car already has a fuel pressure regulator, and unless you have some specific reason to change your base fuel pressure, there's no need to buy another one.
7mgtema71
Re: 550cc injectors out of which lexus for 7m bolt in? Fri, 30 July 2004 11:36 Go to previous messageGo to next message
That exactly right! The standard fuel pressure regulator on the 7mgte is more than suitable for your task at hand. I know of someone who almost pulled 250rwkw using the standard regulator and it was fine.
By the way, i had my original 440cc (rated by toyota) flow tested and they were actually 486cc on average. Now before people go blasting me, I'd like to clarify that most injector manufactors rate their injectors with a thicker liquid. Ask any good Bosch specialist.
One other thing I'd like to clarify about injectors. Yes, low impedance are a better injectors for higher revving motors as they can be better controlled under those conditions, but only work well if the injector driver in the ecu is suited to low impedance injectors. Due to the two types of injectors ('peak and hold' and the other i think is called 'peak and shut') the ecu controls them differently.
I used low impedance injectors with an ecu originally designed for high impedance injectors and she ran, but not well. The car actually gained power by using the factory injectors. Don't diss the high impedance ones, but yes the low impedance do offer accurate response once you decide to rev over 9rpm or so. But don't forget the engine output is as good as it's tuner.
Allan
Re: 550cc injectors out of which lexus for 7m bolt in? Fri, 30 July 2004 12:28 Go to previous message
wil8115 wrote on Sat, 02 November 2002 15:59
http://members.optushome.com.au/supra80/carstuff/afpr/DSC00382.JPG
http://members.optushome.com.au/supra80/carstuff/afpr/DSC00383.JPG
1uz-fe afm, 440cc injectors only 40psi fuel pressure is required to get 11.5:1 AFR stock anyway
Previous Topic:rwd 4ag with air con... pics please
Next Topic:Engines to fit my W55
Current Time: Mon Oct 26 00:56:42 UTC 2026
Total time taken to generate the page: 0.011634111404419 seconds
