Toymods » Tech & Conversions » More Power?
vin91
Darwin
More Power? Fri, 07 January 2005 08:53 Go to next message
Probably Silly but how to get more power from a 2S-C?
Has Weber 32/36 DGV and Extracters to Two inch straight through.
Don't want a Lot but is pulling 120 at rear wheels would like 150-170 is Possible?
What would need to be done?
Engine Changeover is not an option, However anything serious is appreciated
Re: More Power? Fri, 07 January 2005 12:18 Go to previous messageGo to next message
120hp at the treads? That's 90kw for all the non-metrics around here... Which ain't bad for a 2S, ain't bad at all, in fact borders on unbelievable!
Anyway, is the engine in good order? If so, stick in a cam, and if you're really keen, I'll even give you a free cylinder head you can practice porting on Laughing
Intensevil
Re: More Power? Fri, 07 January 2005 12:20 Go to previous messageGo to next message
do you have a dyno sheet? because i'd really like to see it
vin91
Darwin
Re: More Power? Sat, 08 January 2005 08:33 Go to previous messageGo to next message
get you a dyno sheet when finished. as is tuned to max on optimax to get that reading.
ae86drift
sydney.au
Re: More Power? Sat, 08 January 2005 08:36 Go to previous messageGo to next message
2s-c is from an 85 CS corona right?
vin91
Darwin
Re: More Power? Sat, 08 January 2005 09:40 Go to previous messageGo to next message
Yeah and sa63 celica's. Nit a bad engine but way to much polution gear.
negative boost
Hobart, TAS
Re: More Power? Sat, 08 January 2005 11:10 Go to previous messageGo to next message
you could try stripping the engine and rebuilding it without all the polution gear on it, that could give some more power. always wanted to do that to my 21-RC
munki
Gold Coast
Re: More Power? Sat, 08 January 2005 11:38 Go to previous messageGo to next message
personally i dont believe the power output, try taking it to another dyno place. carb exhaust and extractors wouldnt give you 160+ hp at the fly unless there is something your not telling us.
towe_001
Somewhere on a dirt bowl ...
Re: More Power? Sat, 08 January 2005 13:25 Go to previous messageGo to next message
NOS?
Intensevil
Re: More Power? Sat, 08 January 2005 13:29 Go to previous messageGo to next message
probbaly a shaved head an cam was missing from that engine description methinks
Hunty
Re: More Power? Mon, 10 January 2005 10:24 Go to previous message
maybe he was measureing with dwarf pony power not horse power
but yes my mum had a 86 corona with that engine, 4 banger 2litre carby thing yeh? and it was a pig, but with 165's on the rear it was a dori pig in the wet Razz
i reackon you be hard pressed to get 120hp at the fly let alone at the treds.
considering the 100kw 4age i got makes 140ish hp and feels about twice as quick as the coroner
but i could be wrong, i've seen a datto 1600 with the original motor worked off its tits, webber carbs, massive cams ect ect, doing crazy times down the 1/4.
Previous Topic:JZX 81
Next Topic:help with gearbox drainage
Current Time: Mon Nov 2 00:40:15 UTC 2026
Total time taken to generate the page: 0.0060000419616699 seconds
