Toymods » Tech & Conversions » 4AGZE running incredibly rich
Phoenix01
Brisbane, Australia
4AGZE running incredibly rich Sat, 08 January 2005 08:58 Go to next message
I've currently got an AE101 4AGZE under the hood, fed by a VL commodore fuel pump with a stock fuel pressure regulator. I had the thing dynoed this morning. Basically its running 10:1 AFR. The guy who was dynoing it suggested a malpassi fuel pressure regulator.
I've searched around the forum and I've read some bad things about temperature affecting fuel pressure on the malpassi. What would you guys recommend?
tanman
Re: 4AGZE running incredibly rich Sat, 08 January 2005 10:09 Go to previous messageGo to next message
use a sard fuel pressure regulator.
Phoenix01
Brisbane, Australia
Re: 4AGZE running incredibly rich Sat, 08 January 2005 10:22 Go to previous messageGo to next message
Thanks for that info. Are they widely availble in australia?
TE72_Turbo
Re: 4AGZE running incredibly rich Sat, 08 January 2005 11:19 Go to previous messageGo to next message
What reason did the dyno operator give for needing an aftermarket adjustable reg? Have you actually tested that your rail pressure is too high, and if so, have you eliminated any other problems that could contribute, such as a partially blocked return line etc?? There are several possible causes for your rich mixture, I wouldn't go and spend hundreds of dollars on a regulator unless you are SURE that it is the problem.
Maybe you've already done all this, in which case, ignore all I said Very Happy Cool
Phoenix01
Brisbane, Australia
Re: 4AGZE running incredibly rich Sat, 08 January 2005 23:22 Go to previous messageGo to next message
He seemed pretty certain about it.
The AFR graph starts out ok @ around 12.5:1, then as the rpm climbs it suddenly plummets down to 10:1 and stays there until redline. I have a feeling that this is when the 5th injector opens up.
DiZ_
The Eastwood MASSIVE !
Re: 4AGZE running incredibly rich Sun, 09 January 2005 00:18 Go to previous messageGo to next message
That fifth injector is a cold start injector.
mikey93
Re: 4AGZE running incredibly rich Sun, 09 January 2005 00:32 Go to previous messageGo to next message
Phoenix01 wrote on Sun, 09 January 2005 10:22
10:1 isnt too bad.. Very Happy are you planning on modding it? your lucky to have more fuel then lean out at top Crying or Very Sad
Phoenix01
Brisbane, Australia
Re: 4AGZE running incredibly rich Sun, 09 January 2005 01:01 Go to previous messageGo to next message
DiZ_ wrote on Sun, 09 January 2005 10:18
Well, I'm an idiot. Embarassed
mikey93 wrote on Sun, 09 January 2005 10:32
Yeah it certainly is better than leaning out... but the engine isn't making anywhere near the power it should. It climbs fairly quickly to 75kw atw, then drops of momentairly (this is when it starts to go stupidly rich), and then climbs back up to around 75-80kw atw and hangs around there until redline.
Fixing this problem should give me another 15-20kw atw going by what everyone else gets on their stock GZE's.
feral4mr2
Bundaberg, Qld.
Re: 4AGZE running incredibly rich Mon, 10 January 2005 09:09 Go to previous messageGo to next message
a faulty 02 sensor can cause them to run rich, just another option to look at.
mikey93
Re: 4AGZE running incredibly rich Mon, 10 January 2005 09:40 Go to previous messageGo to next message
Phoenix01 wrote on Sun, 09 January 2005 12:01
Yeah too much fuel does cause power loss.
I made 92@fwkw 4th gear on BP Ultimate. But heatsoak cuased retardation Crying or Very Sad
new i/c should help if not. ill install a FPR like you have mentioned.
is it an 92 or ae101 with 4 wire 02?
Re: 4AGZE running incredibly rich Mon, 10 January 2005 12:26 Go to previous messageGo to next message
4agze ecu's only take O2 sensor into account on low throttle cruising, like higways and constant speed etc - the ECU runs open circuit when at WOT.
SC_Trueno
Re: 4AGZE running incredibly rich Mon, 10 January 2005 12:45 Go to previous messageGo to next message
does anyone know what kw is 4AGZE engines off a AW11, AE92 and AE101 rated ?
irishtwincam
Ireland
Re: 4AGZE running incredibly rich Mon, 10 January 2005 15:39 Go to previous messageGo to next message
club4ag.com members and mr2oc.com members frequently talk about 5500rpm power dropoff in MAP gzes. 5500rpm engine hiccups, then runs insanely rich killing power.
Might be related?
Phoenix01
Brisbane, Australia
Re: 4AGZE running incredibly rich Tue, 11 January 2005 02:02 Go to previous messageGo to next message
Basically its a complete AE101 setup. Everything under the hood came from the front cut. Unless ofcourse it needed replacing with a new item. But other than that, the exhaust and airbox are the only non-stock parts. (It's an air box from an AE101 4AFE, the GZE airbox was cracked.)
I'm certain the problem is related to the VL commodore fuel pump, while using a stock fuel pressure regulator.
While it could be related to what you've mentioned, I can't see a stock motor running a 10:1 AFR from the factory. Not only that but all these people with stock MAP GZE's making 90-100kw atw tells me that theres definitely something wrong. Especially considering the AE101 GZE is supposed to make a little more power than the AE92 GZE, which most people are using.
[Updated on: Tue, 11 January 2005 09:45]
monkeymajik
Re: 4AGZE running incredibly rich Tue, 11 January 2005 02:32 Go to previous messageGo to next message
I ran a VL fuel pump and stock regulator on my GZE and continue to use it on my GTE. The richest it gets to is 11:1 on full boost, not that bad. I'd be looking elsewhere first.
Phoenix01
Brisbane, Australia
Re: 4AGZE running incredibly rich Tue, 11 January 2005 02:39 Go to previous messageGo to next message
Yeah, but what was it doing in stock form (before the turbo).
4agte
Toronto, Downtown
Re: 4AGZE running incredibly rich Tue, 11 January 2005 09:06 Go to previous messageGo to next message
i cant remeber getting any sort of fuel economy from my gze but mybee thats cause ive allways got my foot burried Laughing
Phoenix01
Brisbane, Australia
Re: 4AGZE running incredibly rich Tue, 11 January 2005 09:35 Go to previous messageGo to next message
Well you know whats funny?
While running stupidly rich, I'm getting 7L/100km. Shocked
4agte
Toronto, Downtown
Re: 4AGZE running incredibly rich Tue, 11 January 2005 09:39 Go to previous messageGo to next message
i probably do get decent fuel economy but with a 35ltr tank it seems to go kinda quick
sideshow
Re: 4AGZE running incredibly rich Tue, 11 January 2005 11:55 Go to previous messageGo to next message
before u go testing everything this could be a normal thing
some car manufactures use something called wide open throttle
i have had a good air fuel meter on my hilux and mixtures are perfect except
when under about 90% throttle all is perfect
over 90% then i think the ecu is programmed to dump fuel in so as not to blow up the engine
this i swhy alot of engines get more horsepower when u fit an aftermarket ecu and lean it off up hi
i can be on and revs and load mixtires are perfect but
as soon as i get over 90% its goes to 10 : 1 air fuel instanlty
wagonboy
Re: 4AGZE running incredibly rich Tue, 11 January 2005 13:09 Go to previous messageGo to next message
Ive heard the Toyota ECU's are one of the worst for over fueling.
4agte
Toronto, Downtown
Re: 4AGZE running incredibly rich Tue, 11 January 2005 13:20 Go to previous messageGo to next message
nissans are prettey bad too
irishtwincam
Ireland
Re: 4AGZE running incredibly rich Wed, 12 January 2005 09:54 Go to previous messageGo to next message
several club4ag and mr2oc members speak of hitting 10:1 AFR at 5500rpm.
Does an S-AFC override the ECUs wide open throttle settings?
wagonboy
Re: 4AGZE running incredibly rich Wed, 12 January 2005 15:17 Go to previous messageGo to next message
Yes they have high and low throttle setting, i know of some ppl that their AFC is taking 25% fuel put Shocked
mikey93
Re: 4AGZE running incredibly rich Thu, 13 January 2005 13:09 Go to previous message
have you tried running a hotter plug?
just a thought? maybe in the 5/6 series
Previous Topic:TA12 - TA14 Carina around 70-75 Rear Quarter windows
Next Topic:3S-GE / 3S-GTE head interchangability?
Current Time: Thu Oct 22 22:01:58 UTC 2026
Total time taken to generate the page: 0.0069880485534668 seconds
