Toymods » General Car Talk » Road Worthy Inspection Help!!
TRD_Supra
On Probation
Hobart
Road Worthy Inspection Help!! Mon, 10 January 2005 05:25 Go to next message
G'day all,
I had my MA61 go for a RWC today and it failed Mad
Problems:
1. Ball Joints
2. Rack Boot
3. Front Struts
4. Power Steering Leak
What are the ball joints? Rack Boot
And are the front strusts the front shocks ?
jc80
W.A
Re: Road Worthy Inspection Help!! Tue, 11 January 2005 12:34 Go to previous messageGo to next message
I'm not sure on the exact location of the ball joints on that model but they are usually on the end of the tie rods, they turn the front wheels (usauly) there are others as well it depends witch ones exactly are gone, if u wiggle them and theres movement there fucked, if u have no idea what im talkim about can get some pics, Rack boots are on the steering rack there about 10cm long 5cm round, look neer the firewall,front struts would be the shockeys, the springs only fail if broken, if u need pics let me know
styler
Re: Road Worthy Inspection Help!! Tue, 11 January 2005 12:47 Go to previous messageGo to next message
if u need to replace ur tie rod ends - not too hard
u will need a wheel align after doin them
and a tie rod remover is handy too
boot - can be a bitch (pulling out rod)
struts? hmmm could be a few things
power steering - ha everyone seems to get leaks, glad i
dont have it (but i hate bump steer dammit)
most probably a hose or clamp leaking
[Updated on: Tue, 11 January 2005 13:02]
Re: Road Worthy Inspection Help!! Tue, 11 January 2005 12:53 Go to previous message
ball joints are at the base of the strut/coil tube - commonly referred to as a macpherson strut. The other ball joints in the system are out at the ends of the steering rack and they would be referred to as 'tie-rod ends'.
ball joints:
http://www.cygnusx1.net/supra/library/TSRM_MKII/fa /FA_014.html3
rack boot:
http://www.cygnusx1.net/supra/library/TSRM_MKII/sr /SR_027.html
Rack boots are flexible, bellows-like things go over the ends of the steering rack to prevent dirt-n-shit getting into the rack. They look similar to the boots used in some IRS suspensions and W drive shafts
these are the struts mentioned above - what part of the strut did they fail? the shock absorber insert. the psring, the spring seats, the upper bump stop, the top plate bearing
struts:
http://www.cygnusx1.net/supra/library/TSRM_MKII/fa /FA_010.html
btw: when you bought the car from brisbane did it come with a safety certificate (used to be called RWC in Qld)?
Previous Topic:Proton r3
Next Topic:Reupholstering (sp?)
Current Time: Fri Oct 23 07:48:44 UTC 2026
Total time taken to generate the page: 0.0049829483032227 seconds
