Toymods » Tech & Conversions » ajustable cam gears
mx83toy
ajustable cam gears Sun, 20 October 2002 13:50 Go to next message
what gains can be had in paying with the camgears on a closer to stock engine??? how hard are they to get working correctly and set up right
ie my 1J
5KinKP60
Finland
Re: ajustable cam gears Sun, 20 October 2002 16:00 Go to previous messageGo to next message
You need programmable engine management to benefit from adusted cam settings.
Even very light port 'n' polish headwork preferred too.
-A.
SUPRAGTE
North Sydney
Re: ajustable cam gears Mon, 21 October 2002 12:34 Go to previous messageGo to next message
I'm hoping to gain about 10rwkw's with a cam timing adjustment on the exhaust side with about +3deg adjustment.
Will_AW11
Sydney, Australia
Re: ajustable cam gears Tue, 22 October 2002 02:53 Go to previous messageGo to next message
My limited experience indicates that not much can be gained with stock engines by adjusting the cam timing, but you can move the torque peak around in the rev range by advancing or retarding both cams. So if you want more peak power you can move the torque peak higher in the RPM range, you can gain a little here at the expense of mid range torque.
Some minor gains are available by really accurately timing your cams as there is always some small error from a factory setup. i.e Finding TDC with dial guages etc.
Manny
Re: ajustable cam gears Tue, 22 October 2002 10:09 Go to previous messageGo to next message
I run an adjustable gear on my exhaust cam. As Will states, it allows you to move the torque curve around a bit. We got up to 6rwkw on it but sacrificed a little to bump the torque curve up and left the gain at 3rwkw.
Don't know about a stock engine though - I had exhaust, intake, fuelling and minor boost mods already.
HKS and JUN do adjustable cams at about the $300 each mark but I've also seem custom jobs using machined/modified stock gears.
Techie_Mark
Peakhurst, Sydney
Re: ajustable cam gears Tue, 22 October 2002 12:06 Go to previous messageGo to next message
What I have heard about playing with cams (esp replacing the cams for longer duration ones) is that during the course of engine modification, it is generally about the last thing that you would do after everything else, because a) high expense b) minimal gains c) more gains to be had from an engine with all the other mods done first anyway...although I don't know much about just changing the cam timing. SUPRAGTE, I'd be very interested to hear your results both power-wise and driveability.
SUPRAGTE
North Sydney
Re: ajustable cam gears Thu, 24 October 2002 12:52 Go to previous messageGo to next message
Ill keep you guys posted with the results.
Also the latest microtech which im running i can choose the exact point at which the injectors fire within the 360 degree crankshaft revolution which will hopefully take even more advantage of the cam gear adjustments.
Bill Sherwood
Brisbane / Gold Coast
Re: ajustable cam gears Thu, 24 October 2002 13:14 Go to previous messageGo to next message
Sequential injection doesn't do anything to improve the power of the engine, only improve the emissions and fuel economy.
(From the guys at Motec)
Will_AW11
Sydney, Australia
Re: ajustable cam gears Fri, 25 October 2002 00:31 Go to previous messageGo to next message
and improved idle quality. (From MoTeC's competitor Cool )
SUPRAGTE
North Sydney
Re: ajustable cam gears Sat, 26 October 2002 09:06 Go to previous messageGo to next message
But with the adjustment of the cam timming if i then align the injector timing to take advantage of the altered intake valve opening there would be some gains.
More thorough cylinder filling hopefully and a resulted increase in power.
Will_AW11
Sydney, Australia
Re: ajustable cam gears Sat, 26 October 2002 23:04 Go to previous messageGo to next message
But don't forget that as revs go up, the window for correct injection timing gets narrower over time (stays the same as an angle) while your injection times are getting larger. Ultimately, as your injectors approach 80% duty at max power for example, your injector is open for 80% of 720 degrees anyway which makes any advantage of correctly timing the fuel pulse negligable compared to your A/F, ignition timing etc.
Pete
gold coast
Re: ajustable cam gears Sun, 27 October 2002 05:39 Go to previous message
I ordered one for my engine(1JTT) last night. It will be here on friday, i'll tell you how well made it is.
It costs $230.
I want to improve the midrange torque.
Previous Topic:help needed: crank pulley dia = boost?
Next Topic:half cut vs engine parts, and 2jz vs 1jz
Current Time: Sat Oct 31 03:53:09 UTC 2026
Total time taken to generate the page: 0.0065279006958008 seconds
