Toymods » Tech & Conversions » GZE conversion prob
trueno_gze
icon5.gif  GZE conversion prob Mon, 21 October 2002 00:59 Go to next message
i just started to put the gze in my trueno and the eng sits on a slight angle, as it was a mission to line the mounts up because i left the alt in the original spot. then only after the eng was on the hoist that i realised the alt needed to be moved because it hit the crosmember.
also the coil packs hit the fire wall.
so heres the qu's
-is the eng supposed to sit on a slight angle?? if it is not how do i correct it??
- what do i do with the coil pack (ie where should i mount it)?
thanks for the help guys
az
Jonoze
Re: GZE conversion prob Mon, 21 October 2002 01:22 Go to previous messageGo to next message
The slight angle is nothing too worry about, its normal.
The coilpack can be mounted on top of the engine rocker covers, or alternatively on the firewall just above or beside the engine. Either way a custom bracket can be made or the original bracket adapted.
Mine are mounted on top of the engine on a custom bracket made of aluminium plate.
trueno_gze
Re: GZE conversion prob Mon, 21 October 2002 02:12 Go to previous message
thanks mate.
and does ur car have a/c because i had to d/c mine.
Previous Topic:Cleaning Throttle Bodies?
Next Topic:delco efi on toyota engines
Current Time: Thu Nov 19 08:29:10 UTC 2026
Total time taken to generate the page: 0.0047459602355957 seconds
