Toymods » Tech & Conversions » Electronic Auto Gearboxes...
Kyosho
Wollongong
Electronic Auto Gearboxes... Tue, 11 January 2005 06:40 Go to next message
Alrighty now then guys...
I've done a search, and I bottomed out...
I'm wondering if anyone could explain to me HOW the ECU in certain Toyota cars, controls the Auto box?
Main thing I want to know, when selecting a gear, does it hold a current to the solenoid or just "Hit" it with a 12V and then stop?
What things does the ECU look at when choosing gears?
RPM, TPS, VSS?
I just want to know HOW it DECIDES on a gear (I have a fair idea) and how it makes the gearbox shift (I have not much clue really cept it does it with solenoids)
HighRolla
Re: Electronic Auto Gearboxes... Tue, 11 January 2005 07:30 Go to previous messageGo to next message
http://www.autoshop101.com/autoshop15.html
check the above out.
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Tue, 11 January 2005 07:37 Go to previous messageGo to next message
HighRolla wrote on Tue, 11 January 2005 18:30
Thanks heaps for that link, has heaps of stuff there...
Reading now...
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Tue, 11 January 2005 10:11 Go to previous messageGo to next message
Well I had a read through on that site...
Seems pretty simple how they are controlling it, with a few variables (Temp, VSS, RPM, TPS) and a couple of "fail safes" and then a "If everything goes pear shaped" back up... (If the whole electrics die... You can still drive... Very Happy)
So yeah...
That was really helpful that stuff...
Just need to find out some of the other info like duty cycle and frequency the solenoids are pulsed at...
sideshow
Re: Electronic Auto Gearboxes... Tue, 11 January 2005 11:42 Go to previous messageGo to next message
im pretty sure the soleniods are just on or off
theres 3 soleniods
a b and lock up soleniod
by hold a or b or both or none i determines what gear
the lock up solenoid locks torque converter when in overdrive
the ecu takes into account alot of things so tryin to replicate them would be a pain
i do know of aftermarket ecus that are just for the auto
like fittin a microtech but to the auto and not the engine
and are fully programmable
Toycrash
Finland
Re: Electronic Auto Gearboxes... Tue, 11 January 2005 14:26 Go to previous messageGo to next message
That link talks about A340E, A340H, A540E and A540H trannies, but what is 03-70LE ???
I've got such tranny and cant find anything about it Sad
Only what i know it that it has been after 1G-G engine.
Aisin-warner model no. 03-70LE licence 3500 2A200
serial no. 84AM 01276
That what the plate says Wink
Edit: found makings from dismantler.. GX61 But not much info awailable about MKII
[Updated on: Tue, 11 January 2005 15:35]
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 04:47 Go to previous messageGo to next message
sideshow wrote on Tue, 11 January 2005 22:42
theres 3 soleniods
Replicating them is all in the logic... Hence the research now...
Am researching to make an aftermarket ATC (Auto transmission Controller), to build them up isn't heaps expensive... The hardest part is to find out all the info to build up the logic behind... Someone had to do it before us to get the AT to work...
What I mainly need to know...
What current is required through the specific solenoids and for how long (I keep getting told the 4L60E *Holden T700* runs at 60% Duty cycle, but duty cycle to what?)
Thanks people...
sideshow
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 04:54 Go to previous messageGo to next message
well 100% duty is fully on
your best bet is to get a toyota with auto tranny
get an oscilloscope and start testing
its much easier to buy one hehe
atleast that way u can have a laptop with all the adjustmnets infront of you
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 05:03 Go to previous messageGo to next message
sideshow wrote on Thu, 13 January 2005 15:54
Buy one? Buy a Toyota with auto box? Or a shift controller?
The reason I am doing the research for the shift controller is to build one for a company I work for... It is a project of mine... For the price of parts etc, the ones I have seen are way over priced (I've seen some companys selling for $2500, and since our company is in the modified car pool, why not help out the guys with autos...)
As for the oscilloscope... A decent one is worth 1G... Not wanting to spend that sorta money on one...
Maybe if I can get someones car to test when I'm in sydney might be able to arrange to get it done at work...
As for the duty cycle... I know that the 100% is fully on, 0% is half on, 25% 1/4 on etc... But I want to know, is it the duty cycle of the engine, or of the gearbox input shaft, or of what?
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 05:14 Go to previous messageGo to next message
Toycrash wrote on Tue, 11 January 2005 22:26
I think the 03-70LE is the A43DE, or A43DL found in early to mid 80's RWDs Toyota's.
Its the predesscor to the A34xx series.
sideshow
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 06:36 Go to previous messageGo to next message
what you are askin i think that no one here will have doine any research on in the past
so best bet is to get a toyota vehicle with an auto tranny
say a cressida
then do some tests
you can get oscilloscopes from 300 bucks
the people who sell the fully programmable tranny controllers had to do it the hard way so i doubt you will find much info
plus the best info is to road test the car and take measurements
this is not something that can be done over a weekend
the auto ecu has many inputs and outputs to work as a fully automatic gbox
if you want to make it manual shift then its easier
but this information is hard to find and i would recon anyone who has it will not give it out
the reason they are worth 2500 bucks is the months and months of testing they did
when it comes to solenoids i think its jsut a straight 12v to trigger them
but i know on a 1uz v8 2 are pos triggered and 2 are neg triggered
[Updated on: Thu, 13 January 2005 06:41]
Toycrash
Finland
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 07:05 Go to previous messageGo to next message
I found some hint, that it might be A42DE?
Anyhow, point is that does it have same computer and same type solenoids.
as for A34XX two solenoids drive gears at "D" and pretty easy to use pushbuttons + and - gearshifts. By using only solenoid wirings and leave ecu control line pressures etc.
+/- counter and couple logic ports handle that job nicelly Wink
on page15 in #1 pdf you can see the operating order for each gear
when you get 00,01,10,11 from up/down counter you just use ports to convert signals to suite gear order. 1st=01 2nd=11 3rd=01 and 4th=00
conversion made like this: (counter missing)http://koti.phnet.fi/crash/electrical/looranohjaus ta1.jpg
[Updated on: Thu, 13 January 2005 07:06]
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 07:11 Go to previous messageGo to next message
The A42DE will be the same as an A43DE with different ratios.
The D means it has overdrive, and the E means it is electronically controlled, ie, it has its on ECU.
The A43DL is not electronically controlled and is usually found behind 5me's.
Toycrash
Finland
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 08:04 Go to previous messageGo to next message
Mkay. then mine is A4XXE Razz
Now we need to know does it run with same computer as A340E is...
MS-75
Re: Electronic Auto Gearboxes... Thu, 13 January 2005 23:04 Go to previous messageGo to next message
Grab yourself any of the toyota workshop manuals and all of the wiring diagrams, hysteresis graphs and diagnostic explanations are in there. From there its pretty simple to determine your inputs and shift paramters (all the required numbers are there for fault diagnosis-so you can compile all the required shift point tables). The trick will then be to construct the box to drive it and write the program. A gameboy would probably be a good cheap basis to work from.....
Maybe you could use a commonly available trans computer and then do a programmable interceptor unit-that behaves similar to a unichip unit?
Sean
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Fri, 14 January 2005 03:45 Go to previous messageGo to next message
MS-75 wrote on Fri, 14 January 2005 10:04
Sean
Hey Sean...
Thanks for the idea on grabbing the toyota manuals... A friend is a Toyota mechanic... Forgot about that...
As for making an interceptor... I don't like that idea really... I've seen people have them, and they ended up with problems at certain conditions. I already have the "Box" made up, I just need to get my logic sorted, make it into a C program, and then write the program to talk to a laptop... So the expensive part is done...
I am really against piggy back chips as well... I don't like them, but the main reason people go for piggy backs is because of the price of a new ECU, and because of this automatic problem as well... Both will soon change (Cheap, but really flexible ECU coming out soon, and this ATC being made)
Thanks Again
Matt
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Sun, 16 January 2005 00:42 Go to previous messageGo to next message
Alrighty now then...
I've done a bit of a search... Couldn't find required thing...
Downloaded the electrical diagrams for the MA70 7MGTE and GE...
They had the ECT listed on a certain page... But those pages where missing...
SO does anyone have the Wiring diagram, specifically for the MA70 7M-gte or GE auto box?
Re: Electronic Auto Gearboxes... Sun, 16 January 2005 01:15 Go to previous messageGo to next message
wiring diagram?
start reading form here:
http://www.cygnusx1.net/supra/library/TSRM/at/AT_0 21.html
you'll have to match the purpose of wires to actual colour coding of the loom - but that's an easy job - the preceeding pages of the TSRM explain how the box works,
http://www.cygnusx1.net/supra/library/TSRM/at/AT_0 29.html has the pin-outs for the trans ECU
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Sun, 16 January 2005 03:07 Go to previous messageGo to next message
thechuckster wrote on Sun, 16 January 2005 12:15
wiring diagram?
Thanks for those...
Helps heaps...
Even found the Shift schedules and a couple of other things...
Still trying to work out what a couple of things are on the diagram (L1, L2, L3, OD)
They are cables connected to the ECU and ECT... Hmm... Still thinking...
Re: Electronic Auto Gearboxes... Sun, 16 January 2005 03:33 Go to previous messageGo to next message
Kyosho wrote on Sun, 16 January 2005 13:07
L1,2,3 pull sensor data from the ECU - my undestanding is that it need RPM and throttle position - the wire coming straight from the TPS to the ECU and Trans ECU would only indicate if throttle closed. You might want to look at the 7mgte wiring diagram, note down the acronyms used agains't thos poinout and then search for the list of common acronyms used in toyota ECUs - is on autoshop somewhere i think.
OD is overdrive- note: must be engaged above a present speed limit. i think it locks the torque convertor up.
btw: kDog sells a box that runs your A3xx autobox as a manualized auto - shifter is used to select PRND, two switches are then used to change up from 1 to 4.
his info page on bigpond appears to be up, but you'd have to contact him to see if the hardware is still available for sale:
http://users.bigpond.com/K_Dog/engconversion/FAQ.h tm
i think this car runs a manualised auto-transmission setup:
http://forums.toymods.org.au/index.php?t=msg&t h=53574&rid=2087&S=87c79e6c965b1baecfe6331 81d0c0619&pl_view=&start=0#msg_491206
cheers, charles.
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Sun, 16 January 2005 03:56 Go to previous messageGo to next message
Ahh thanks Charles....
I'll chase that guy up...
See if I can get any info from him...
I did notice on the wiring diagram, the only sensor the ECT ECU gets is Idle switch, and the VSS 1 and 2...
That leaves RPM, TPS, and something else...
I'll check the rest of my notes...
I can't think of what the extra sensor might be... Hmm...
Because the PWR button is straight to the ECT ECU... SO can't be that... I'll check my 7M-GTE diagrams now...
Kyosho
Wollongong
Re: Electronic Auto Gearboxes... Sun, 16 January 2005 04:03 Go to previous message
I worked out the third sensor as my diagrams where opening...
It's the engine temp sensor...
When below a set temp, the engine WONT engange OD...
Previous Topic:AE86 Digital Dash conversion
Next Topic:something went wrong.......... electrical.....
Current Time: Fri Nov 20 07:32:16 UTC 2026
Total time taken to generate the page: 0.052349090576172 seconds
