Toymods » Tech & Conversions » GZ power drop at 5500rpm
rolla kid
Brisbane (AUS)
GZ power drop at 5500rpm Tue, 11 January 2005 06:47 Go to next message
Hey guys i am tryin to find wats wrong with my gz when i put my foot down the car will rev up to 5500rpm and then just die in the ass like there is no power at all. Just wondering if anyone has come across this and what i can do to fix it. Its a 4agze Map sensored 1991-2 i think from a AE92.
mikey93
Re: GZ power drop at 5500rpm Tue, 11 January 2005 07:19 Go to previous messageGo to next message
its running too hot
do a search i've posted a dyno
timing retarding and fuel leaning
rolla kid
Brisbane (AUS)
Re: GZ power drop at 5500rpm Tue, 11 January 2005 07:27 Go to previous messageGo to next message
It isnt running hot becasue the temp gauge was no were near hot plus it has a 2 core raditor in it that is better then stock so i dont think it is a temp problem
4agte
Toronto, Downtown
Re: GZ power drop at 5500rpm Tue, 11 January 2005 08:35 Go to previous messageGo to next message
could well be belt slip on the supercharger belt do u have a boost guage? how bad does the power drop?
The belt will slip at high rpm with a boost guage u can see the boost going backwards but u cant hear it if you have an exhaust like mine.
mikey93
Re: GZ power drop at 5500rpm Tue, 11 January 2005 08:47 Go to previous messageGo to next message
get it dynoed to be sure its not leaning out
irishtwincam
Ireland
Re: GZ power drop at 5500rpm Tue, 11 January 2005 09:06 Go to previous messageGo to next message
Ive seen exactly that problem on my friends gze corolla.
We had the car at 5500rpm in fifth by the time the problem manifested itself.
There could be truth in saying the car is too hot.
This has been discussed on club4ag also, do combined searching.
Corolla had relocated cone intake, 175mm pulley, 13.5psi verified on a good HKS gauge, Front Mounts Intercooler.
Exhaust manifold was prone to glowing after such sprints!
HTH
wagonboy
Re: GZ power drop at 5500rpm Tue, 11 January 2005 11:10 Go to previous messageGo to next message
mikey93 wrote on Tue, 11 January 2005 19:47
I have this same problem, turns out that its leaning out really badly and just dies high in the rev's.
Try a bigger fuel pump if you are still running a n/a fuel pump,
mikey93
Re: GZ power drop at 5500rpm Tue, 11 January 2005 11:53 Go to previous messageGo to next message
here's my graph and you'll see
i reckon it could also be with -
knock sensor, possibly fpr. but not really fuel pump as it can supply fuel rich enough.
up!http://img75.exs.cx/my.php?loc=img75&image=dsc 000334hu.jpg
but aftermarket ecu's always fix this
[Updated on: Tue, 11 January 2005 11:54]
wagonboy
Re: GZ power drop at 5500rpm Tue, 11 January 2005 13:03 Go to previous messageGo to next message
My standard GE pump sure cant supply enough fuel to support the 1.2 bar that i get sometimes Shocked
rolla kid
Brisbane (AUS)
Re: GZ power drop at 5500rpm Wed, 12 January 2005 01:24 Go to previous messageGo to next message
It is running a 7mgte fuel pump which should be heaps for a stock 4agze it also wouldnt rev out past 5500rpm like it would rev to it and die down the rev to it and die down really quickly like you are hitting the rev limiter.
rolla kid
Brisbane (AUS)
Re: GZ power drop at 5500rpm Wed, 12 January 2005 01:26 Go to previous messageGo to next message
I am also looking at gettin the greedy e manage ecu do you think this is a good replacement for the stock gx ecu
kayot1k
Re: GZ power drop at 5500rpm Wed, 12 January 2005 05:54 Go to previous messageGo to next message
yo bro,
same with mine,
but mine cuts out near 6 grand i would say roughly 5800
i had mine dyno tuned, with EMS ecu.
i only get 90 kws at front wheel with 164mm nevo pulley.
i dont get whats the deal and im hitting 10psi.
full exhaust minus extractors. 2.5 hi-flow cat.
also, in regards to the later model gze they have been said to rev out to 7 grand with aftermarket larger pulleys.
damnz man too much expectations i guess.
i feel ya brother.
regards
[Updated on: Wed, 12 January 2005 05:59]
mikey93
Re: GZ power drop at 5500rpm Wed, 12 January 2005 06:00 Go to previous messageGo to next message
looks like we got the slow generation 4AGZE's lol.
my mates old ae101 stock made 96kw at the rear with microtech stock 8psi boost.
DiZ_
The Eastwood MASSIVE !
Re: GZ power drop at 5500rpm Wed, 12 January 2005 06:20 Go to previous messageGo to next message
Dunno what you guys are doing wrong , my 4AGZE is fine right to redline in every gear.
Celica_John
Re: GZ power drop at 5500rpm Wed, 12 January 2005 06:32 Go to previous messageGo to next message
Do you have the bonnet scoop on it? That could ontribute to the problem if its heat related.
4agte
Toronto, Downtown
Re: GZ power drop at 5500rpm Wed, 12 January 2005 06:46 Go to previous messageGo to next message
ahh i dun know if this applies to the levin gze's but certainly does with mr2 gze's if you are running bigger pulleys you need to do an abv mod otherwise it will bleed boost above 9 psi
[Updated on: Wed, 12 January 2005 06:47]
adamb131
Re: GZ power drop at 5500rpm Wed, 12 January 2005 07:12 Go to previous messageGo to next message
Might sound obvious but... fuel filter!!!???
mikey93
Re: GZ power drop at 5500rpm Wed, 12 January 2005 07:13 Go to previous messageGo to next message
possibly.. i haven't changed it yet still using the front cut one Laughing
rolla kid
Brisbane (AUS)
Re: GZ power drop at 5500rpm Wed, 12 January 2005 09:50 Go to previous messageGo to next message
Yeah i will soon see how mine goes on the dyno i am just gettin a 2.5" exhuast put on it so hopfully the prob will go away with that if not it is back to the drawing board
rolla kid
Brisbane (AUS)
Re: GZ power drop at 5500rpm Wed, 12 January 2005 09:53 Go to previous messageGo to next message
it is brand new fuel filter and yeah it has a bonnet scoop but i dont think it is a heat problem becasue even with the bonnet off and just reving on the spot it wouldnt rev past 5500rpm
mikey93
Re: GZ power drop at 5500rpm Wed, 12 January 2005 10:41 Go to previous messageGo to next message
from what i noticed.. it leans out top end
timing retards, so does the the TPS. it starts to fall from 100% down to 70% or so as the revs rise.
There is a fuel cut of some sort. Or running limp
Do the diagnostics code check and see what it spits out
bayka
perth
Re: GZ power drop at 5500rpm Wed, 22 June 2005 03:41 Go to previous messageGo to next message
Hey dudes, i suspected this would be the case, but after dyno i have the same goddamn problem.
Power drop from 100% -> 70% at 5500rpm
-Not supercharger as im still making 9psi all way to redline, and ive bypassed relay so i have full control of electronic clutch.
-Not fuel system as i have decent pump (not sure about fuel filter)
-Exhaust is 2.5" cat back so far so it cant be THAT restrictive
-mines ae101 with stock ecu, stock boost, stock top mount with ae92 scoop, cold conditions (not heat)
-it feels like a computer thing, leaning fuel or something but i heard these babies run rich as hell?
Did you guys end up working out the problem?
Sad
[Updated on: Wed, 22 June 2005 03:44]
4agte
Toronto, Downtown
Re: GZ power drop at 5500rpm Wed, 22 June 2005 03:45 Go to previous messageGo to next message
try replacing the fuel filter its a cheap thing to replace
then check the diagnostic for error codes from the ecu. it may well be a faulty knock sensor or falty signal from the oxygen sensor
10sec_rx7
Syndey
Re: GZ power drop at 5500rpm Wed, 22 June 2005 04:04 Go to previous messageGo to next message
this has been covered in great lengths on the twincam.org forums, it is to do with the knock sensor pulling all the timing out, every GZE i have had on the dyno with the stock ecu does it, every microtech one i have tuned dosent do it,
Re: GZ power drop at 5500rpm Wed, 22 June 2005 04:16 Go to previous messageGo to next message
so you are saying that with microtech, you can allow knock to happen so you make power higher up?
or that the stock ECU is too sensitive to knock detection.. does the MT use the same algorithms to determine if knock is occurring?
10sec_rx7
Syndey
Re: GZ power drop at 5500rpm Wed, 22 June 2005 04:24 Go to previous messageGo to next message
to stock ecu is too sensitive to knock and air temps as soon as the air temp goes up it retards timing, as soon as it hears any noise on the knock sensor it retards timing most of the time it is just normal engine noise,
MT dont monitor knock, its all up to the tuner to take care of that
4agte
Toronto, Downtown
Re: GZ power drop at 5500rpm Wed, 22 June 2005 04:53 Go to previous messageGo to next message
agreed does that on mine
wagonboy
Re: GZ power drop at 5500rpm Wed, 22 June 2005 05:15 Go to previous messageGo to next message
When i first did my conversion and did the exhaust , had it dynoed and didnt have any problems like ppl have been saying.
I have since done pulley, cams, cooler, bigger fuel pumps and SAFC2 and need to get it tuned , so will see wat happens then
[Updated on: Wed, 22 June 2005 05:41]
bayka
perth
Re: GZ power drop at 5500rpm Wed, 22 June 2005 05:44 Go to previous messageGo to next message
Ive just searched twincam.org for "power loss" "power drop" got nothing? Do you know the thread name?
This problem must be rectifiable (is that a word?) because wagonboy runs stock ecu and his works beautifully.
Can u just rip out or trick the knock sensor? Where is it located?
10sec_rx7
Syndey
Re: GZ power drop at 5500rpm Wed, 22 June 2005 05:50 Go to previous messageGo to next message
i cant remember the thread name, it wasnt that long ago,
it dosent happen to all GZE's thats the tricky bit,
4agte
Toronto, Downtown
Re: GZ power drop at 5500rpm Wed, 22 June 2005 06:11 Go to previous messageGo to next message
if you rip the knock sensor out you will get an annoying check engine light and the ecu will spit out error code 52.
before trying anything i reccomend you start by shorting the terminals in the diagnostic plug to see if it spits out an error code and go from there...
it will take you all of 5mins to do aswell
wagonboy
Re: GZ power drop at 5500rpm Wed, 22 June 2005 07:43 Go to previous messageGo to next message
If your not sure how to do diagnostic Daniel i can show , its easy enough, needa come round so you can look at this relay setup anyway. . .
bayka
perth
Re: GZ power drop at 5500rpm Mon, 18 July 2005 14:08 Go to previous messageGo to next message
Hey All
I found the post about this power drop problem on twincam.org with title : "Attn all MAP 4agze"
With the added research they have done i think its fair to say
The problem has NOT been solved by
-higher fuel octane
-changing superchargers, belts
-putting resistors on intake temp sensor (making ecu think 20 degrees celcius)
The problem HAS been solved by
-aftermarket ECU
-replacingt knock sensor. There is a dude in brisbane who ordered a genuine replacement knock sensor and it fixed his problem immediately and gave 20kw / wheels alledgedly Wink
Just wanted to let others in the same situation know.
Anyone know how to go about sourcing a genuine 4agze knock sensor from here?
Anyone got the part number?
-daniel-
4agte
Toronto, Downtown
Re: GZ power drop at 5500rpm Mon, 18 July 2005 21:40 Go to previous messageGo to next message
i know castle hill toyota can order it for you and post it aswell seeing as they arent that big i cant see it costing much try emailing jame sloane he is very helpfull and responds quickly to emails i will pm you his address
bayka
perth
Re: GZ power drop at 5500rpm Sat, 29 October 2005 18:43 Go to previous messageGo to next message
--- 7mgte knock sensor update ---
Just reviving this age old post to let everyone know that this definately works. I barely ever get power cut at 5500rpm since doing this (think 7mgte knock sensor is less sensitive) and on the odd time I do, couple of quick revs to redline in neutral solve it for the rest of the drive.
--- notes ---
When pulling out factory ze knock sensor i could pull it apart with my bare hands and look at the internals. Looks like they may perish during transit or perhaps when sprayed down at the docks?
All thats necessary to get 7mgte knock sensor working is take its plug aswell, or simply butcher the existing ze plug. Cutting the outer plastic sheeth off the existing plug allows the centre part of the plug to perfectly schnick inside the 7mgte knock sensor.
All this done on ae101 ze
I didn't realize these engines were so good in stock form when you can freely rev to limiter 1st and 2nd gear...fucking FAST
Surprised
-daniel-
4agte
Toronto, Downtown
Re: GZ power drop at 5500rpm Sun, 30 October 2005 02:10 Go to previous message
bayka wrote on Sun, 30 October 2005 05:43
Surprised
-daniel-
welcome to the dark side Evil or Very Mad
Previous Topic:AE102R Performance Mods/Suggestions
Next Topic:ST141 Corona wagon: Engine Options.
Current Time: Wed Oct 28 00:04:51 UTC 2026
Total time taken to generate the page: 0.028414964675903 seconds
