Toymods » Tech & Conversions » Is this possible - telling a bad O2 sensor
HighRolla
icon5.gif  Is this possible - telling a bad O2 sensor Tue, 11 January 2005 07:46 Go to next message
Is it possible that an 02 sensor could oscillate beteen 0.2 and 0.8 volts but yet still be running the car rich.
I mean it should be reading .45v when there is a certain oxygen content - simulating 14.7:1 A/fuel ratio. What if it reads .45v when at lower oxygen content, say 12:1 ? Is this possible , so then the 02 sensor is trying to maintain a rich mixture.
Its just that all thetests I see say to check if fluctuates b/w 0.1 and 0.9 volts at 2500rpm.
[Updated on: Tue, 11 January 2005 08:36]
YelloRolla
On your mum!
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 09:07 Go to previous messageGo to next message
the efi doesn't run by the 02 sensor. If at 2500rpm the voltage is oscillating I imagine that it is as a result of the engine running in closed loop - this is where the management will run the engine incrementally leaner until a certain point and then will track back to slightly rich and then again incrementally leaner and so on and so forth.
HighRolla
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 09:26 Go to previous messageGo to next message
Yeah that's how I see it. I understand that much. But if it;s oscillating like that then it *should* be running close to 14.7 at that time. So if you put exhaust gas analyser on you should be seeing around 14.7:1. If not then the oxy sensor must be reading incorrectly right? I read somewhere it has ability to add or subtract 20% fuel based on 02 readings
Kyosho
Wollongong
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 09:36 Go to previous messageGo to next message
HighRolla wrote on Tue, 11 January 2005 20:26
An N/A car will run 02 sensor closed loop to get back to 14.7, thats alls the standard O2 sensor will go to...
Turbo cars usually run in Open loop unless a 5V linear O2 sensor is installed...
HighRolla
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 10:09 Go to previous messageGo to next message
I'm just saying if it is faulty is there a chance that it could be trying to get the fule mixture back to an incorrect level?
Most turbo cars still run a standard 02 sensor I believe...e.g skylines use same oxy sensor as a falcon
Kyosho
Wollongong
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 10:23 Go to previous messageGo to next message
The turbo cars might do a "fudge" so that it won't lean the engine out... Because I know, soarers, skylines, S13s.. They all run insanely rich...
As for the O2 sensor...
1) It will send no signal, and stuff the ECU around (Make it run wierd map)
2) if it sends the incorrect value, it will make the car extraordinarily rich or lean...
colouring_in_book
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 11:04 Go to previous messageGo to next message
On the contrary, if your O2 sensor does not oscillate, then you can assume that it is fucked.
An O2 sensor, as a generalisation should fluctuate between 0.1V and 0.9V.
As a basic rule of thumb, O2 sensors are merely mixture trimmers attempting to reach your stoichiometric ratio of 14.7:1.
"Most" cars will run OK with the O2 sensor disconnected, but then again most cars will illuminate the "check engine" lamp if this is disconnected.
Also keep in mind that your O2 sensor only detects the amount of oxygen remaining in the exhaust gas, expressed to the ECU as a percentage of your exhaust gas as a whole.... I hope that made sense.
However, don't be fooled by your stoichiometric ratio of 14.7:1 as keeping you out of trouble. A high performance engine can run in and closely around the perfect "14.7:1", but on the other end your HC's (hydrocarbons) and CO's (carbon monoxides)can be at a highly unacceptable level.
In oreder to answer your question as to whether an O2 sensor can give a false reading,..ofcourse it can. Especially if the readings are not constantly fluctuating.
But generally if your O2 sensor is faulty, it will be one or possibly both of two reasons.
You have contaminated your Titanium or Zirconia composite O2 sensor, or your wiring has failed you.
With contamination, you usually will not get a fluctuating reading, or an incorrect reading.
If there is a wiring problem, your ECU will usually recognise a "no activity" situation, which the ECU will usually log a code!
A "no activity" situation can also occur on a contaminated O2 sensor!
Hope this helped out in some way!
[Updated on: Tue, 11 January 2005 11:10]
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 11:27 Go to previous messageGo to next message
just an aditional note about O2 sensors - the 'narrow band' type found in most cars will either indicate lean, stoich or rich. The variation from 0.45V will not indicate how from off stoich the gasses are.
'Wideband' sensors will indicate the actual amount of O2 found in the gas - but these guys (until recently) are very expensive and require a lot more electronics to control and use (e.g. you cant just replace a narrow band unit with a wideband).
Also, until an engine is at operating temps and the O2 sensor likewise is at proper temps it will not read correctly and any decent ECu will ignore the O2 readings until then.
HighRolla
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 11:37 Go to previous messageGo to next message
Thanks guys. Yeah the 02 is flutctuating between about 0.1v and 0.9 volts. So I guess it is probably ok.
Don't know why the fuel consumption isn't better then
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 13:05 Go to previous messageGo to next message
maybe it's outside the engine?
rubber still good?
wheel/diff bearings OK?
brakes not dragging?
wheel alignment good?
aircon or other engine loads OK?
maybe it's running rich to counter the effect of something else?
HighRolla
Re: Is this possible - telling a bad O2 sensor Tue, 11 January 2005 13:13 Go to previous messageGo to next message
I'm getting wheel alignment soon,
rubber is good
The reason i am looking in engine dept is due to the small amounts of throttle opening being used. If I was using a lot of throttle travel the whole time then I'd be checking other things like you say. But I'll check the wheels spin freely. I know the fronts are good.
A/C hasn't been used much. PS pump makes a little noise on full lock that's about it.
Thanks Chuckster for the ideas. Smile
[Updated on: Tue, 11 January 2005 13:13]
Kyosho
Wollongong
Re: Is this possible - telling a bad O2 sensor Wed, 12 January 2005 05:13 Go to previous messageGo to next message
thechuckster wrote on Tue, 11 January 2005 22:27
On the note of prices...
My boss bought a wide band UEGO 5V O2 sensor to help tune customer cars...
$200 for the sensor...
Then it was $800 for the actual computer piece that transferred it into a proper signal that the ECU could use...
pannelvan_screema
Campbelltown, NSW
Re: Is this possible - telling a bad O2 sensor Fri, 14 January 2005 23:37 Go to previous messageGo to next message
just out of curiosity how many kilometres are on the car???
and how many k's you getting to a tank.
HighRolla
Re: Is this possible - telling a bad O2 sensor Sat, 15 January 2005 00:30 Go to previous messageGo to next message
Ok car is AE92 4AFE auto corolla. 220k kms and getting about 10-11L/100kms
I got a mechanic I know to wack it on the exhaust Gas analyser. Running about 15.1 A/F ratio at idle. Unburnt HC are about 140ppm. But when you give it a bit for a while and then back off the hC are up about 500ppm and increased CO meaning incomplete combustion. He reckons that it's covered a fair few clicks so might be down on compression a bit.
colouring_in_book
Re: Is this possible - telling a bad O2 sensor Sat, 15 January 2005 01:52 Go to previous message
In all honesty, with 200 000kms+ on the dial, I would not worry too much.
If the car is driving OK then only persue the matter if you are concerned.
Previous Topic:Kiwi ute
Next Topic:werid electric problem
Current Time: Sat Oct 24 19:58:54 UTC 2026
Total time taken to generate the page: 0.0066018104553223 seconds
