Toymods » Tech & Conversions » balance tube for twin sides
Moonbreaker
balance tube for twin sides Tue, 11 January 2005 13:42 Go to next message
i am currently using a 2tg side draft manifold with holes on the first and fourth intake runner and was wondering if placing a balance tube would be beneficial or would it be better if i put holes in all four runners then a balance tube?
and i was also wondering with regards to the vacuum signal fromt he carbs themselves can i interconnect both carbs from there, will there be any benefit? i also have both of them closed as of now
Moonbreaker
Re: balance tube for twin sides Thu, 13 January 2005 14:20 Go to previous messageGo to next message
bump. anyone?
YelloRolla
On your mum!
Re: balance tube for twin sides Thu, 13 January 2005 22:22 Go to previous message
I see no merit in the balance tube - also I have never seen dual carbs with the balance tube. I actually think that it would be detrimental to the function of the carby (why are the runners individual in the first place? and why would you want to balance the signal after the throttle plates? when #1 is on intake stroke #4 is on power stroke.)
There is merit however in drawing a combined vacuum signal - it will probably assist in giving a consistent vac sig at all RPM (this is mostly relevant if you are running quad throttle bodies AND a MAP based reference to an EFI computer).
Previous Topic:Top Feed Injectors
Next Topic:1 GGTE clucth questions
Current Time: Tue Oct 13 08:44:32 UTC 2026
Total time taken to generate the page: 0.08626389503479 seconds
