Toymods » Tech & Conversions » 18RG Head-Bolt Torque Settings
clancey
icon5.gif  18RG Head-Bolt Torque Settings Mon, 21 October 2002 05:19 Go to next message
Does anyone know what the torque wrench settings are to be used on the head bolts of an 18RG motor?
Specifically an 18R-GEU if there are any differences in the torque settings between the different types of 18RG.
Also would using a copper head gasket require me to tension the bolts to a different setting?
Any help would be appreciated,
Clancey
blackRA28
adelaide
icon4.gif  Re: 18R-GEU Head-Bolt Torque Settings Thu, 05 June 2003 04:16 Go to previous messageGo to next message
Hey i havent been able to find this out and would really appreciate if anyone knew.. Who rebuilds 18RGs??? because someone must have the specs somewhere..
I need to put the head back on the 18Rgeu soon, What torque settings should the bolts be tensioned to? Also, what should they be re-tensioned to after run-in?
I am using a new genuine toyo head-gasket.
All help greatly appreciated,
___________________
BlackRA28
WANTED: 18RGeu -88270 inlet valves, top-left 18RGeu timing guide.
Jason
Re: 18R-GEU Head-Bolt Torque Settings Thu, 05 June 2003 04:20 Go to previous messageGo to next message
I have the settings at home i will get them and post them up tomorrow unless someone else beats me to it.
Re: 18RG Head-Bolt Torque Settings Thu, 05 June 2003 05:49 Go to previous messageGo to next message
If you're doing this sort of work it might be a good idea to buy a workshop manual from Toyota (they might still be available). I bought one a few years ago and it's been invaluable. I can look up the head bolt torque settings tonight if no-one has done it for you by then.
celicaboy
Re: 18RG Head-Bolt Torque Settings Thu, 05 June 2003 10:52 Go to previous messageGo to next message
63ft then 82ft then 100ft then 118-120ft
im not dead sure.. i got it written down i will find out on the weekend for ya.
blackRA28
adelaide
Re: 18RG Head-Bolt Torque Settings Thu, 05 June 2003 12:17 Go to previous messageGo to next message
CHEERS GUYS,
Some published-Toyota specs sound good but i have no idea where i can pick up an 18R-GEU service manual from??!
Are these torque settings for the 18RG early motor, and would it be different for the later efi motor?
If you guys have exact specs and can be bothered posting them that would be exxcelent!!
Thanks for your help celicaboy.. We shoudl tabulate all info like this and make an archive i think....
Jason
Re: 18RG Head-Bolt Torque Settings Thu, 05 June 2003 22:26 Go to previous messageGo to next message
Clancey and blackRA28 you both have a email of the scanned 18rg engine manual which you can post if you want.
Steve M
Re: 18RG Head-Bolt Torque Settings Fri, 06 June 2003 03:24 Go to previous messageGo to next message
I have just finished putting together an 18rgu and the tork settings we used for the head bolts were around the 63lb/ft mark.
The 18r-c ones are about 80 something from memory but that has the cast iron head not the alloy one.
I don't have our book handy at the moment but I wouldn't go over 63 until someone can give you a definite answer.
anything over 80 is way too high.
The tightest bolt on the 18rgu was the one holding on the harmonic balancer and that waas 83ish lb/foot.
celicaboy
Re: 18RG Head-Bolt Torque Settings Fri, 06 June 2003 10:52 Go to previous messageGo to next message
yeah im not sure if that was ft or nm... but i can find out for sure tomorrow i ahve both measurements written down
wiseman
tennessee
Re: 18RG Head-Bolt Torque Settings Sun, 08 June 2003 13:12 Go to previous messageGo to next message
if you torque the bolts at 70 foot pounds, it will be fine.
Blaze
Re: 18RG Head-Bolt Torque Settings Mon, 09 June 2003 00:29 Go to previous messageGo to next message
I have the book in front of me it states.
Cylinder head Kg-m 7.2 - 8.8
Ft-lb 52.1 - 63.7
celicaboy
Re: 18RG Head-Bolt Torque Settings Thu, 12 June 2003 08:24 Go to previous messageGo to next message
i found the settings here goes. this is the stages to set them at.
60, 100, 118nm
44, 74, 85ft
sequence of tightening
8 4 1 5 9
7 3 2 6 10
Steve M
Re: 18RG Head-Bolt Torque Settings Tue, 17 June 2003 04:01 Go to previous messageGo to next message
Those settings are fine for the 18R-c but are too heavy for the 18RG
63ft/lb is the tightening torque for the alloy headed 18RG.
blackRA28
adelaide
Re: 18RG Head-Bolt Torque Settings Tue, 01 July 2003 14:52 Go to previous messageGo to next message
Steve M wrote on Tue, 17 June 2003 13:31
Is this the final torque setting?? Or is this what you tension it to first..??
Can anyone give a definative answer on this? it seems 63. ft/lb is the go, but do you need to re-tension it to a tighter seting? or do it at a lighter setting first, then re-tension after 500k's upto 63 ft/lb??
Anyone have any specific information for the 18R-GEU ?
Guy
Steve M
Re: 18RG Head-Bolt Torque Settings Wed, 02 July 2003 04:14 Go to previous message
Final torque setting is 52.something - 63.1 ft/lb.
as for fist tension, probably around 35, then 45-50 (if you're going to finish at 63.1, less if you're going to finish at 52ish)
I would suggest going for the 63.1, as unless you've had your head surfaced and your block surfaced less might leave you with leaks.
Previous Topic:Microtech Digi1 specs
Next Topic:lowered susupension for a hilux
Current Time: Sun Oct 25 11:35:28 UTC 2026
Total time taken to generate the page: 0.043109893798828 seconds
